Does 'PA080 Replace Hybrid Battery Pack' always indicate a replacement necessary?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by kamrul, Jun 4, 2024.
  1. kamrul
    kamrul Junior Member
    98
    17
    Bangladesh
    In other words, can the triangle of death aka, PA080 code appear for different reasons like, high temperature inside the battery pack?
    One of my friends has got the following check light on the cluster.
    After scanning, it is the infamous 'PA080 Replace Hybrid Battery Pack' code. However, the battery health was tested immediately afterward, resulting in an astonishing 81% SOH.
    I do not put my utmost confidence in Dr. Prius here since the result indicated that it could be wrong.
    Here is the important part of my query. I have read (probably on PriusChat too) that people have been driving their Prius cars just fine even after a PA080 popped up. All they did were erase the code, cleaned the fan, cleaned the fan filter too if there is any plus the adjacent area inside the battery case and the corroded busbars/connectors. Though I admit, it could not be that common.
    So how often have you found a PA080 to be a false alarm?
  2. kamrul
    98
    17
    Bangladesh
  3. bisco
    51,567
    it's best to get the sub codes with a prius aware scanner
    kamrul likes this.
  4. bisco
    51,567
    close to always, not sure i trust doc prius either. certainly worth cleaning everything up and seeing what happens
    kamrul likes this.
  5. kamrul
    98
    17
    Bangladesh
    Can you please name a few Prius aware scanners? I use BafX on mine.
  6. bisco
    51,567
  7. bisco
    51,567
  8. JohnPrius3005
    JohnPrius3005 Active Member
    423
    235
    California and Hawaii
    get techstream bootleg on ebay or amazon and a cheap laptop if you're paranoid
  9. Leadfoot J. McCoalroller
    8,020
    7,496
    Pennsylvania
    2018 Prius c
    You can reset the code and drive a bit further.
    But how much further?
    You can also keep squeezing a tube of mustard until you get every last milligram out. It comes down to how much work you put in vs. the benefit you get out.
    When you reset a dying battery like that, you'll see a pattern of shorter and shorter drives between the resets. Eventually it does the bad smell and then it won't go READY anymore.
    How old is that battery? Toyota built them to last about 10 years. Some have made it to 12 years. The Aqua/Prius c battery does not last as long as the big Prius battery.
    kamrul and nancytheprius like this.
  10. Mr. F
    Mr. F Active Member
    387
    255
    Washington
    P0A80 is triggered only when the voltage difference between two modules grows larger than a set threshold on two separate trips. Sufficiently high temperatures will trigger different codes, not P0A80.
    You could figure out which modules are weak and replace them, and this method might extend the pack life by up to a year, or not at all. Unfortunately, it is nearly impossible to find replacement modules whose charge-discharge characteristics match those of your existing good modules closely enough.
    Erasing the code does not remove the problem, so it will pop up again very soon. The fan or fan filter don't really have anything to do with a P0A80 detection. If any of those are resulting in insufficient cooling, there will definitely be other codes first. And corrosion is only relevant if it is under the bus bar nuts or on the terminal threads (it usually is not).
    NiMH batteries start degrading from the moment of manufacture. The battery smart unit monitors the pack continuously throughout its life, and there eventually comes a time when it detects that one or more of the modules have degraded enough to warrant replacement of the entire pack, and that is when you get the P0A80.
  11. Brian1954
    Brian1954 Senior Member
    2,017
    790
    South Central PA, USA
    The P0A80 trouble code for a Gen 3 prius only has one detail or sub code, which is 123, so there is only one troubleshooting procedure listed in the Toyota service manual for this trouble code. So, in this case, a better scan tool will not help with a P0A80 code.
    That being said, it is always best to use a scan tool (like the Autel AP200 that you linked to in post #4) that is capable of reading all the trouble codes that might occur in the Prius.
  12. bisco
    51,567
    thanks! i thought it would give you info on the bad modules.
  13. nancytheprius
    nancytheprius Active Member
    363
    156
    iowa
    Second this. I diagnosed my failed hybrid battery and replaced it on my way own, saving lots of $. Bootlegged techstream should run around 40 including scanner
  14. Leadfoot J. McCoalroller
    8,020
    7,496
    Pennsylvania
    2018 Prius c
    I wonder how they came to choose that particular number, a tidy little sequence of numbers?
    I know Japanese culture is somewhat tetraphobic, given that in Japanese, the spoken word 'shi' means 'death' or 'four' depending on context.
    I couldn't know if it's deliberate, but I posit that it could be seen as a wonderfully sneaky way of suggesting what's next for the battery. Nerds rule.
    ein... doi... tres... shi♩
    ♩ time to buy a bat-tery♫
    Mr. F likes this.
