Ground the throttle body
Discussion in 'Gen 3 Prius Accessories and Modifications' started by AzusaPrius, Jun 20, 2024.
  1. AzusaPrius
    AzusaPrius Senior Member
    2,232
    930
    I have seen user @Eric "v" talk about this and others say it helps.
    The idea is to add a ground wire to the throttle body and ground it.
    The throttle body is floating and not actually grounded as it sits on the plastic intake manifold.
    Anyone else try this and what are your thoughts.
  2. soft_r
    soft_r Active Member
    188
    155
    Beverly Hills
    2024 Prius
    It's horse shit.
    Placebo effect garbage that every car forum somehow talks about.
    #2 soft_r, Jun 20, 2024
    Grit likes this.
  3. AzusaPrius
    2,232
    930
    The throttle body is getting zero ground from it being mounted to the intake manifold.
    Being attached to metal studs is not being grounded, since the manifold is plastic.
    There is one black wire in the harness and that is it and it is thin and long.
    A shorter thicker ground is better.
  4. ChapmanF
    18,545
    Is this about gen 3? Are you thinking the black wire to D4 is a ground? Have you thought of looking it up?
    There are two electrical devices on the throttle body: the throttle actuator motor, and the throttle position sensor.
    Which do you expect to work better if you "add a ground wire"? Both? One? Which one?
    Mr. F, fuzzy1 and Brian1954 like this.
  5. AzusaPrius
    2,232
    930
    I have no idea but a simple ground wire to the body of the TB can be added or removed very easy.
    Just wanted to see if anyone else has done it.
  6. ChapmanF
    18,545
    Do you think there's anything there that would work better with a ground wire? What would that be?
  7. AzusaPrius
    2,232
    930
    No chap I just want to add an extra doodad to my engine buddy.
    All placebo for sure and thank you for pointing it all out for me.
  8. ChapmanF
    18,545
    I already understand that pointing it all out for you is a lost cause.
    On the other hand, other people also read PriusChat threads (if they didn't, how would they be able to find your products and discount codes?) and there could be hope for them.
    The fun thing about this particular mod is the way it keeps getting recycled on PriusChat (2005, 2012, 2015).
    The pattern is sort of repetitive, in the way the poster who eventually makes a commercial plug of some sort always starts the thread with a post like "gee, I've heard of people doing this, anybody tried it?".
    I just noticed this is in the gen 3 forum, so there aren't really any questions here that weren't answered in the 2015 go-round that was in the v forum (same throttle body and manifold). I was sort of expecting the next appearance to be in one of the gen 4 or 5 forums, so at least it could say "who knows? maybe the new wiring's different."
    fuzzy1 and Mr. F like this.
  9. AzusaPrius
    2,232
    930
    I will just get a ground cable and try it out.
    Anything I say cant be true though with guys like you around to toss their two cents and condescending sarcasm.
    I will wait for your next expected reply.
  10. Mr. F
    Mr. F Active Member
    389
    263
    Washington
    Some say this gets you:
    This little mod seemingly combines all the benefits of a RedBullet solenoid, a NexCell battery pack, Pulstar spark plugs, a FuelGenie system, AND a Ganador muffler (did I miss one?)! So I guess there's no need to buy all that other expensive crap anymore?
    Isollas, Grit and Brian1954 like this.
  11. AzusaPrius
    2,232
    930
    You get an F for effort little buddy.
  12. ChapmanF
    18,545
    Cool! Looking forward to the photo of the installed cable and where it connects.
