Can anyone help me? My 2010 lit up codes P0A93, P0C73, P314A
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Daniel Trachuk, Jul 3, 2024.
  1. Daniel Trachuk
    Daniel Trachuk New Member
    Portland OR
    those are the codes that lit up on my Prius. I bought this Prius several months ago off auction and ended up replacing the front end with a nose cut. Wanted to see if anyone had similar codes and what you did to configure the problem?
    51,561
    are you sure about that first one? what code reader are you using?
  3. bisco
    51,561
  4. Daniel Trachuk
    Portland OR
    Oops, I meant P0A93
  5. Brian1954
    Brian1954 Senior Member
    2,017
    788
    South Central PA, USA
    I am guessing the first code should be P0A93.
  6. Mendel Leisk
    41,011
    What’s the miles?
  7. Daniel Trachuk
    Portland OR
    Prius has 111,000 miles
  8. Tideland Prius
    16,505
    *Title fixed*
  9. Mendel Leisk
    41,011
    Had to look that one up:
    what is an automotive nose cut
  10. bisco
    51,561
  11. Daniel Trachuk
    Portland OR
    Any advice with these codes?
  12. ChapmanF
    17,783
    Those are 'permanent' codes—the car's memory of an issue it had but no longer has.
    It appears that at one time you had a dodgy inverter water pump (P0C73, P314A), and that led to the inverter overheating (P0A93).
    But those codes no longer show as current, which either means (a, great) that you have changed out that pump and resolved the problem, or (b, less great) that you cleared the codes or something and they just haven't come back yet.
    Assuming you did the great thing and changed out the pump, the 'permanent' codes will just go away by themselves after a while, when the car convinces itself on a few consecutive drives that the problem is fixed.
    #12 ChapmanF, Jul 14, 2024
  13. Tombukt2
    12,698
    2,269
    What brand of scanner is that like a top dog or something?
  14. Tideland Prius
    16,505
    *Threads merged*
    Mr. F and Brian1954 like this.
