Multifunction Display Is Out/Not Working
Discussion in 'Gen 2 Prius Technical Discussion' started by geopupps, May 23, 2022.
  1. geopupps
    geopupps Junior Member
    Phoenix
    Our 2009 Prius' multifunction display is out. It may come on every once and awhile but for the most part it's always out/dark. It's been an issue for the past 6 months. We can't change the air, the radio, or see the backup camera. Does anybody know what the issue is and if there is a fix for it. I tried doing a search on here but couldn't find anything. Any help is greatly appreciated. Thanks.
    #1 geopupps, May 23, 2022
  2. Another
    Another Senior Member
    1,802
    511
    Naples, Florida
    It’s called a Multifunction Display or MFD.
    You can do a PC search on it and will notice that it routinely fails in older Prius cars.
    It’s relatively simple to swap out with a used one that works of that’s all that’s wrong, if it is not repairable.
    Others here will have better suggestions to diagnose what you can try short of replacement but here’s one video that shows how it’s done
  3. geopupps
    Phoenix
    Thanks. Yeah I don't know if it just needs to be replaced or it can be fixed cause there is another issue with it. Thanks for the feedback.
  4. Moving Right Along
    Moving Right Along Senior Member
    690
    541
    If it’s going out and no longer accepts touch inputs, then you probably need to replace it. Unfortunately, it’s not cheap.
  5. geopupps
    Phoenix
    I would assume so cause last time it came on at all has been awhile. Even when it did come on is wasn't for very long. I guess I'll have to look for one.
  6. TMR-JWAP
    TMR-JWAP Senior Member
    6,242
    5,939
    Columbia, SC
    You need to make sure you replace it using an identical part number. Remove your MFD and purchase one that has the same exact part code.
  7. Another
    1,802
    511
    Naples, Florida
  8. geopupps
    Phoenix
    Ok we’ll make sure.
  9. geopupps
    Phoenix
    Ok, thanks for the info.
  10. geopupps
    Phoenix
    Getting in it this time I noticed it was a white screen. I tried pushing buttons but it didn’t do anything and 15 minutes later or so it’s now black/off.
  11. James Analytic
    182
    28
    Michigan
    Is this post by @Cateran relevant in regards to interchange between the MFD's? Granted, there might not be functionality based on vehicle model package system.
    MFD 86110-47230 Compatibility | PriusChat
    This post is for the pinouts of the connectors from @ITBland: Will 86110-47230 work instead of 86110-47081 in 2005 Base Model? | Page 2 | PriusChat
    I've not verified that there are the two same pinouts used for all the models in the pertinent two year ranges noted in the first link I shared, guessing based on the two categories of known US model types they may be.
