Will 86110-47230 work instead of 86110-47081 in 2005 Base Model?
Discussion in 'Gen 2 Prius Audio and Electronics' started by babubhai, Aug 20, 2017.
  1. ITBland
    ITBland Active Member
    433
    277
    New Orleans, La area, US
    The original table above was missing the two illumination wires that must also be moved. Here is the corrected table:
  2. ITBland
    433
    277
    Here's a better version of that chart:
    SkyWolf and Thomez like this.
  3. Thomez
    Thomez New Member
    Waterville, Minnesota
    Is there a way that I can disable the CD port by snipping certain wires on the M13 pin connector? I am trying to get an aux input I installed to work. It works when the M13 is unplugged, but once I plug it in to the screen the aux stops working. This is on my 2005 Prius
  4. Thomez
    Thomez New Member
  5. ITBland
    433
    277
    The M13 connector does not have any audio wires, only the data wires that allow the MFD to communicate with the radio (so you can control the fader and EQ, and see the radio and CD info).
    What wires (pin numbers) did you use for the Aux input you added? (Or, what cable did you buy?)
    Do you have navigation?
    Do you have JBL (does the radio have a cassette player)?
  6. Thomez
    Thomez New Member
    I plugged an aftermarket aux cable into an empty CD changer port on the back of the radio. I do not have navigation or a cassette player.
  7. ITBland
    433
    277
    Gonna have to help me a little here...what aftermarket cable? Is it just a cable, or does it have a little box on it? (with some electronics?) You may not be able to post a link--just type the URL to where you bought it and I'll take a look at it.
    Also, If you start your own thread, others may see it and help.
  8. ITBland
    433
    277
    Here is a picture of the Aux In/Bluetooth Interface that I was using with my 2004.
    next to it is a 12-pin "Y" cable that connects to the same plug on the back of the radio. The wire colors are wildly different.
    I would contact the seller and be sure it will work with a 2005 Prius.
    Since there are no audio cables in the MFD M13 plug, my best guess is that the Aux-In must be getting turned off after the MFD "talks" to the radio. When you plug the MFD in, does the radio still work?
  9. Thomez
    Thomez New Member
    Yes the aux I bought has a box with electronics (“
    Car MP3 Player Radio Interface Aux In Input Adapter For Toyota Corolla 2005-2011
    ”) the eBay description says that it works with a 2005 Prius.
    UPDATE: We just figured it out! On pin 9 and 10 of the R5 connector we added a 68ohm resistor. This was soldered to a double pull double through switch with the 9 & 10 radio wires in the middle with resistor on one side and the other end of the 9 & 10 from the MFD on the other side of the switch. It’s very crude but it works with some strings attached. In order to use the aux the car has to start with the switch on the resistors side. With the aux activated there is practically no useful function in the MFD. You can switch to the regular state of the MFD but then the aux doesn’t work. Once switched to regular you can’t go back to aux.
    ITBland likes this.
  10. ITBland
    433
    277
    Glad you got it working, sorry you had to hack the Prius up to do it. Looks like you are disabling the communication channel until the Aux In reports to the radio.
    Thomez likes this.
  11. OBJUAN
    OBJUAN Member
    165
    76
    canada
    I'm adding a OEM camera into my 05. I have from a salvage yard, the camera and 47210 MFD.
    The MFD appears to have a similar pinout as the 47230. Thank you guys for posting that!
    Has someone posted a photo of the factory knockout in the aluminum sheet metal of the back hatch to make a template?
    I will have to run a shielded cable from the hatch to the MFD, the rest should be easy.
    Picked up the parts cheap on a whim, $150CDN.
    The donor car is 500km from me now.
    Had I known the 05 has no knockout, I would have take a pic.Doh!
  12. OBJUAN
    OBJUAN Member
    165
    76
    canada
    The release is the small holes near the edge of the connector. Check that locking bar is out (pain in the b design). I used a very small jewellers screw driver and push firmly until you feel the pop. Then it comes out easy. Similiar for the orange battery ECU connector.
    May even be the same pin part number available from digikey/mouser.
    ITBland likes this.
  13. OBJUAN
    OBJUAN Member
    165
    76
    canada
    There is a physical difference in the 2005 M13 and 2009 M13 connectors, photo attached.
    The M14 connector pins works the same on the on the 2009. Trying to identify the tyco pin...
      File size:
      90.1 KB
      File size:
      46.8 KB
    SFO and ITBland like this.
  14. ITBland
    433
    277
    Tyco pin? :confused: (Is that the release tool?)
    AustrianPrius likes this.
  15. ITBland
    433
    277
    I did in the other thread, here: 2008 OEM backup camera add-on. hope this helps!
  16. ITBland
    433
    277
    I ran my cable (base 2004 I had at the time) under the passenger door sills so that I could pick up the Rev wire in the footwell, and wire-tied that one wire to the shielded cable.
  17. ITBland
    433
    277
    Is the 47210 the later (2009 in this case) MFD with navigation? Are you going to take a stab at the Bluetooth? I added a Bluetooth interface using the external CD connection in the back of the radio instead of trying to use the MFD Bluetooth, which would only have given me phone and not the audio I wanted.
  18. OBJUAN
    OBJUAN Member
    165
    76
    canada
    No Nav, it the same screen as the 4 button type you posted.
    Bluetooth seems to work, does pair with the phone, but needs a mic.
    Should be easy enough unless it needs preamp.
    Not enough detail in the EM01ROU diagrams :eek:P
    Its on the M14 connector so I can rig up an electret element and try it.
    I assume the audio patches into the stereo...
    The REV B+ (21) is being a pain, nothing at J36(3 black & 3 Blue)or at 5N14-5E2 at least the colours aren't there.
    May have to go right to the relay box...
    You still have 06-09 model?
    Perhaps get a picture of the camera hole in the aluminum hatch?
    Doesn't take long if you can spare 1/2hr...
  19. OBJUAN
    OBJUAN Member
    165
    76
    canada
    I'll have a look, thanks
  20. OBJUAN
    OBJUAN Member
    165
    76
    canada
    Tyco is the maker, these are AMP connectors. They are TE Connectivity now, same disease as HP management.
    Don't know who they are so may as well change the badge and confuse customers....
    ITBland likes this.
