Prius Shake when coming off idle, and/or at low RPM
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by joellecool, Sep 4, 2024 at 10:20 PM.
  1. joellecool
    joellecool Junior Member
    22
    Washington, DC
    I have 2012 that recently started shaking at low RPM and threw these codes:
    • P0301 - Cylinder 1 Misfire Detected
    • P0A0F - Engine Failed to Start
    • C1464 - Front Speed Sensor RH Circuit
    • C1465 - Front Speed Sensor LH Circuit
    A bit more about the car:
    • Water pump was recently replaced in August 2024
    • Thermostat was recently replaced in August 2024.
    • Has about 260K Miles
    Before those 2 above were replaced, it would have the following symptons:
    • Orange Triangle
    • Stopped moving. Symbol of wheel with exclamation mark appeared
    • Coolant mostly empty and or dark. <------- I had put K-Seal when I replaced the water pump in October 2023
    These were the codes that showed before I replaced the Water Pump:
    • P261B - Engine Coolant Pump 'B' Control Malfunction
    • C1259 - HV/EV Control System Regenerative Malfunction
    • C1310 - HV/EV System Malfunction
    What do you recommend that I do?
  2. MAX2
    MAX2 Member
    271
    61
    Third Rock from the Sun
    P0301
    Misfiring in a cylinder can be due to a number of reasons.
    Coolant entering the cylinder through a ruptured head gasket.
    Malfunction of spark plugs and ignition coil, incorrectly adjusted fuel and air supply system.
    Have you ever cleaned the EGR system?
    How often do you check the coolant level in the engine?
    C1464
    C1465
    These errors may have subcodes that will indicate problem areas.
    Specify whether the codes are frozen or current?
    Do these error codes appear again when the DTC is reset?
    Are there any signs of rodents under the hood of the engine compartment?
    C1464/C1465 ABS code, ABS, Brake lights on and no speed | PriusChat
    #2 MAX2, Sep 5, 2024 at 4:18 AM
  3. ASRDogman
    ASRDogman Senior Member
    6,229
    3,326
    Head gasket failed, last year. Because you put in the clogger stuff,
    you'll need a new radiator, heater core, water pump and thermostat and will
    still need to flush out the coolant system, including the head, and pre heater
    under the car through the exhaust....
    The "C1464 and 5" codes are for the ABS system I believe.
  4. joellecool
    22
    Washington, DC
    The codes went away by themselves.
    How do I clean the EGR system ?
    I checked the coolant level after I changed the water pump, after having flushed it about 3 times or so to try to remove the K-Seal from the system.
  5. joellecool
    22
    Washington, DC
    I changed the water pump and thermostat.
    However didn't change the heater core and radiator. Those 2 sound like they would be expensive to replace?
    The water gasket may indeed be broken. That was the theory that led the mechanic to recommend the K-Seal.
    Is it time to just sell the car ?
    Is
  6. MAX2
    MAX2 Member
    271
    61
  7. ASRDogman
    6,229
    3,326
    Are you having overheating issues?
    Some use white vinegar to try to clean the clogging crap out.
    And yes they are expensive, but the labor to do it is more expensive.
    Which will make your "mechanic" happy.....that's probably why he said
    to use it. I take it you have a head gasket failure?
    Replacing it is the ONLY way to fix it.
    You have to weigh all your option about keeping or selling the car.
