Fuel Economy Drop After Speed Sensor Replacement
Discussion in 'Gen 3 Prius Fuel Economy' started by Purrius, Feb 16, 2025.
  1. MAX2
    MAX2 Senior Member
    1,436
    488
    101
    Third planet from the Sun
    I suggest returning to the information in message #15.
    Purchasing a diagnostic device, adapter or program, a special cable will cost less than $200, and it will pay for itself many times over in the future.
  2. Purrius
    Purrius Member
    166
    49
    Northeastern US
    I'll be honest. I'm scared to buy one. I have a learning disability that gives me a hard time understanding directions and information without being physically helped.
    (Unfortunately, I don't have friends here offline that can help, that's why this forum is my best point of contact for Prius related stuff.)
  3. MAX2
    MAX2 Senior Member
    1,436
    488
    101
    Installing software is no more difficult than installing any application on a computer. The forum has many topics on the features of installation and connection. You can always ask a question to which you will receive a competent answer.
    Best Techstream software | PriusChat
  4. Purrius
    Purrius Member
    166
    49
    Northeastern US
    A long story short, my Prius ended up back at the same dealership. They've had it a few days, but gave me a loaner this time, which was appreciated.
    They emailed me an update tonight, and it's not good at all.
    "The tech has recommended for the abs actuator to be replaced as it incorporates a lot of the systems associated with the codes hes getting. So in order to remove and replace that its 4 hrs labor @ $185 ($740) and the parts are $1013.70 so $1753.70 plus tax."
    There's no way I could possibly afford that, especially because my job security evaporated this week. :(
    I tried looking the parts up on RockAuto, but I don't think I'm looking at the correct ones. I think the only one over $140 is an Ignition Starter Switch.
    The following is more context, but probably superfluous. I try to provide as much info as possible, in case something I don't think is important enough to mention, is actually a necessary part of the puzzle.
    I take everything a dealership says with a heap of salt, but I do have a question. The tech mentioned after reviewing my DTC pdfs from over the course of this situation, some codes showed up only after the replacement repairs. It's possible that when the original shop replaced the hub assembly, and later the speed sensor, they may have caused a short that got us here. Truth be told, my roommate and I had independently shared that concern.
    Without getting too deep in the woods; after the hub was replaced, but the issue persisted, they suggested further work. This wouldn't be covered under their guarantee, since they said it wasn't necessarily related to the original issue. Usually they're okay with me asking questions, so I asked if a speed sensor is something that's normally replaced along with a hub assembly. They said they had no way of knowing the sensor was bad when originally diagnosing the issue, because the sensor is buried in grease. I don't know if that's a common issue, but unfortunately they didn't seem willing to explain it further, so at the time I let it go.
    I think I ended up paying around $250 for the sensor installation, but I don't have that bill on hand to double check. This is the bill for the original hub assembly job, though.
    I suppose it doesn't make a huge amount of difference at this stage, but do you think it's likely, or even possible for the original shop to cause the abs actuator to fail in this scenario? Or is it more likely just hitting the pothole sent this all in motion and the ABS imploding was inevitable?
  5. nicoj36
    nicoj36 Active Member
    518
    162
    Get a bottle of redline fuel treatment.
    Also your issues could simply be from a bad 12v battery, or a lose wheel-hub / speed-sensor connection. Check behind the wheels to make sure the connection is tight and secure, you could also give it a clean using a electrical-contact cleaner.
    Don't replace your ABS yet as a bad 12v or lose/bad wheel-hub could cause those lights to come on. Load test your 12v battery. You can get an obd reader from amazon for $15 and download the dr prius app for free. There are how-to videos on youtube. Stealership is last resort. https://a.co/d/fuNl2dO
  6. Purrius
    Purrius Member
    166
    49
    Northeastern US
    I wanted to try out some of your suggestions, but my car's been at the dealership this entire time.
    They think it's these that need replacement, but they couldn't confirm it. (They never gave me the paperwork I asked for, so I'm not even sure how they came to that conclusion.)
    (It's not this specific dealership, I'm just showing the parts!)
    When they called to ask for me the loaner back, I told them not to do the repairs, and I'd take the back car instead. (I didn't directly say it, but I want to get it done elsewhere.)
    I couldn't bring it home the same day I returned the loaner, but they gave me my key so I could, even if they were closed. They had insisted on getting the loaner back that day, but since I was running behind for an appointment, I didn't think to check my car before leaving.
    Yesterday I drove the 40 minutes to get it (Sunday, so unfortunately they were closed). And. Uh. Here is how they left it for me.
    When I dropped it off with them, obviously it had a cowl, wipers, functional glovebox arm, etc. The missing parts are completely MIA. (I always said "stealership" in jest, but oof...) They honestly expected me to take it like this...:confused:
    Now I don't have the loaner, or my own car.
    So... I understand it's okay for some water to get in the engine bay, but it's been raining (often pouring), for days now... I didn't think to cover it somehow before leaving, because I cannot articulate how frustrated I was. Still unsure what do do, I left it there. How possibly screwed am I?
    I'll call Toyota directly tomorrow, although I'm not optimistic they'll give a hoot. (In over a decade of working with them, unfortunately they've not been very accommodating.)
    This sucks.:(
  7. MAX2
    MAX2 Senior Member
    1,436
    488
    101
    You are missing a trough for the wipers and plastic covers. Of course, in the rain this can provoke much more subsequent problems with the failure of various systems due to water getting into the connectors and further corrosion.
    The glove box is held on by a couple of latches and its absence is not as scary now as the lack of protection between the hood and the windshield.
    The car should be parked indoors or under a protective cover.
  8. Purrius
    Purrius Member
    166
    49
    Northeastern US
    The black arm seemed broken on the glove box, but you're 100% correct. I'm really scared about the engine bay.
    The worst part of it is knowing I'll likely just be on my own to pick up the mess (hopefully I actually get my parts back).
  9. Purrius
    Purrius Member
    166
    49
    Northeastern US
    I have a really unfortunate update, and I admit I am close to tears. I'm really confused and upset. :(
    Toyota's Customer Advocate department has been aware of the cowl situation since May 5th, when the dealership blatantly lied to them, saying I had been there that morning to return my car, and left before they could help me.
    I was at work, and never took my car from the parking lot like they claimed. Toyota didn't do anything to help even after I informed them that I could prove they'd been directly lied to. Instead they just kept telling me to sit tight and don't worry, they'd "make me whole". (I don't know what that means.) That's the last I heard from them.
    I saw on Thursday night that my case with Toyota had been closed without any resolution or communication provided to me. On Friday morning (yesterday 5/9), I tried again to call the Toyota agent assigned to my case, but I was told maybe he'd call me Monday.
    I called another dealership and explained the situation. They said to have it towed directly there, and they'd try to help. They said to cover themselves they need the paperwork breaking down what Dealership One claims they did. (I do understand this).
    When I went in, Dealership One only gave me part of the documentation. When I asked for the rest, they insisted that was all of it. When I proved that was untrue, they pivoted to saying I can't have the rest of it because they don't have it. They said I can come back for it on Tuesday. (It should be digital, right? Why wouldn't they have it?)
    Currently I don't think Dealership Two can look my car over, but they said Dealership One legally has to provide the documentation. I don't know how that works, but I also don't feel like policies and laws will help me when no one enforces them.
    Dealership One shrugged off that my situation wasn't an isolated event, and that they commonly leave vehicles with exposed engine bays out in the elements, because they said it won't hurt anything. Sometimes they leave gloveboxes on the floor so they can offer customers a new cabin filter but forget.
    When pressed, they were alarmingly comfortable admitting they don't always remember to do safety checks before returning vehicles to customers.
    I feel sad and like somehow I have woken up in the Twilight Zone. I can't understand why Toyota doesn't care about any of this. I love my car, it's still broken, and I feel really upset and helpless. :(
  10. Purrius
    Purrius Member
    166
    49
    Northeastern US
    (I don't know if I should be editing my previous reply, I apologize if adding new ones isn't the right thing.)
    Toyota says it doesn't make their certified dealerships take accountability for their actions, because they're only the manufacturer.
    It explains a lot though. This arrangement is probably an absolute perfect dream for a bad actor running a stealership.
  11. Purrius
    Purrius Member
    166
    49
    Northeastern US
    Since my last post, my car has started randomly accelerating when it's raining out, and the stereo sound will fluctuate as well. I haven't run an OBD2 on it yet, but I'll have to do that when I have access to my reader again.
    I'm not sure what was reported to Carfax, but my car's value also dropped from $3,000 to around $500 shortly after the dealership fiasco. Could it be related?
    Both Toyota and the dealership refused any accountability, so I'm completely on my own. If I knew a safe way to do it, I would go public. :(
  12. rjparker
    10,437
    6,544
    I suspect the dealership is telling Toyota Corp they previously diagnosed the brake booster and you refused. The reality is a brake booster failure is common on these cars and can cause many of the concerns.
    Unfortunately there are no aftermarket sources for that rather complex brake booster. The dealer does not see many 2010s because of their high labor rates.
    How did you determine the car is now worth $500? Is that what they offered as a trade in?
    I don't know how you would go "public". If you had a lawyer and good evidence, perhaps you could go that route. However most lawyers are expensive and the dealer can afford to counter with high dollar legal help.
    Sometimes it is time to find a newer car. The best value would be a conventional car rather than a hybrid.
  13. Purrius
    Purrius Member
    166
    49
    Northeastern US
    The dealership told Toyota a lot of things that weren't true, including that I came in and yelled at them. This allegedly happened while I was at work, an hour away. I never yelled at anyone, I don't like confrontation. If anything, I get really quiet. :unsure:
    CarFax said my trade-in was $500, just checked again and it says over $1000, and about $3,800 private sale. I think I might be misunderstanding what that means.
    When I say public, I just mean a public review, I only need to make sure I word a review carefully. I've been thinking it over for months, and I think I'll feel a tangible amount of catharsis from sharing my experience.
    I love my car, trading or selling it isn't an option I want to consider. I have more good memories with this car than anything else in my life. (If that sounds sad, it's probably because it is.)
    Maybe I could offer work time in my garage and use the proceeds to buy the parts. I have a variety of parts for different vehicles I'd trade (Miatas, Civics, RX-8s, stereos, random bits and bobs), but I don't think I should get the brake booster and pump used, right?
    Monday I lost my job on the farm, but I really just want my car like she used to be.:(
  14. rjparker
    10,437
    6,544
    As a trade in it's worthless. The dealer gives you a token amount on paper and simply sends it to a wholesale auction where they would be lucky to get $500.
    In reality the car they sell you is several thousand more than what you could buy it for privately.
    Private sale of your car means you put it on Facebook Marketplace or similar and sell it directly. I always private sale my cars and get thousands more than a dealer trade in. However you have to deal with low ball car flippers, people who test it but don't want it and the title transfer paperwork. If it is not in super clean condition and running properly no one will buy it privately.
    For you private sale is probably not a viable option.
    A brake booster job is one of the most complex jobs on the car. In addition to poor access it requires a very high end scanner like Techstream to calibrate and setup. Many here fail when trying to set it up.
    On top of that, there are many versions, at least two per year and model. Buying used means it might not work due to the wrong part (common) or it is broken as well. It can be a tough pill to swallow if it does not work after struggling with it all day or weekend.
    As a result buying the brake booster new matched to your vin is the only safe way and even then the setup can still be a problem.
    Honestly the $1700 price they gave you back when was a deal. Today it is more like $2400 installed by a pro. Four hours is reasonable and is a lot of time for a pro mechanic who has done it many times before. For you it could be much longer and perhaps unsuccessful.
    You say your only help or advice comes from this forum. My advice is immediately take any job you can find or your car will be the least of your problems.
    #34 rjparker, Sep 5, 2025
  15. ASRDogman
    ASRDogman Senior Member
    7,788
    3,975
    You should contact the corporate office yourself.
    Be honest and tell them what happened. It's good you stay calm because they'll be more understanding
    when you are.
    It is something you might be able to do yourself. Reading from those that have done it, it's a "fun" job!
    But doable. You will need a good diagnoses tool like a legit copy of techstream, D8 tools, or others.
    Maybe Toyota will at least be willing to give you a discount. Maybe free parts but you pay labor.
    Both are a lot.
    Mine cycles every 20-21 seconds, and still works fine. And the engine is starting to burn more oil.
    No, Valvoline's Restore and Protect isn't working after 8-9 oil changes...
    So I'm planing on getting the remanfuctured engine from the Hybrid pit and then replacing the brake
    parts while the engine is out to give me more room.
    You don't want used brake parts! Several people have gotten those, and they don't match the car
    so they don't work. At least I haven't read when anyone has been successful. There might be,
    but I haven't heard it.
  16. Purrius
    Purrius Member
    166
    49
    Northeastern US
    I must have made a mistake on that quote. I'll need to dig back through all the records, but I know the first place never actually provided me with the written one, but I'm nearly certain it wasn't under $2k. The second dealership said $1,700 just for the parts, plus 6.5 labor for approximately another $1,100. (Attached)
    EDIT: rereading the $1700 quote, it looks like that didn't include the full repair. I think it's only for that one part and labor installing it.
    I've been going through treatment for a brain injury, it's been really tough, but I was still able to work because a specific set of circumstances. Until my healthcare providers and I get something set up, I'm really going to be on my own to make things work.
    The owner of the dealership left me a voicemail, but never returned my calls or answered the phone.
    I had asked the dealership if a discount would be doable, especially for the parts, and I'd be able to cover the labor. They said not a chance.
    After several days of back and forth, Toyota Corporate told me both verbally and in writing that they're "just the manufacturing company", and they don't monitor the dealerships they certify, so if the dealership won't work with me, Toyota can't do anything. Then they entirely closed my case.
    #36 Purrius, Sep 6, 2025
  17. rjparker
    10,437
    6,544
    The part pricing they gave you in the pic above was msrp. However you can get discounted prices through online Toyota dealers. I found $784 for master cylinder part number 04002-33447 as listed on the quote.
    During holiday specials the online dealer discounts are supplemented further by Toyota Corp. Last weekend during Labor Day was one of those extra discount periods where an additional 15% plus free shipping was available from some online Toyota dealers.
    You were quoted the Pump and the Master Cylinder. These days most get away with changing just the Master Cylinder. However the 2010's did have a batch of Pumps that failed, so it is reasonable the dealer quoted both. They have to guarantee the work and don't want to spend another four hours if they have to do the job again.
    It is a difficult time consuming project that is often frustrated when a diy'er can not calibrate it successfully.
    #37 rjparker, Sep 6, 2025
  18. Purrius
    Purrius Member
    166
    49
    Northeastern US
    Finally they're here, Toyota Black Friday discounts!
    :coffee:
    Are these the same thing with different part numbers? The one with pictures seems to look right?
    https://toyotaparts.ourismantoyotaofrichmond.com/oem-parts/toyota-brake-master-cylinder-4705047140
    https://toyotaparts.ourismantoyotaofrichmond.com/oem-parts/toyota-cylinder-assembly-brake-400233447
    I spoke with a local shop another Prius owner suggested. The shop agreed we should focus on the master cylinder first before going after the pump, just like you guys suggested. The install will cost around $300 if I provide the part.
  19. rjparker
    10,437
    6,544
    The smart move is to email them your cars vin and the screenshots of the parts you want and ask them to verify.
    Also ask if there is a tsb "kit" that has the needed part for less money.
  20. Purrius
    Purrius Member
    166
    49
    Northeastern US
    I asked about a kit too, and he's the response
    "47050-47140 is the factory part number for your vehicle. We do not see an applicable TSB for your vehicle."
    I kind of find this odd. From what I understand, this might apply, but is there a way for me to double check myself? http://www.nhtsa.gov doesn't give me results for applicable TSBs or CSPs on my exact VIN.
    EDIT: I can't get the free shipping promotion to work. I'm assuming it must be excluded because the fluid?
    Offer excludes products classified as hazardous materials (e.g., chemicals, compressed gases, etc.) and paints.
    This part is usually discounted around 30%, should the extra 25% apply on top? I couldn't get it to apply that either. :censored:
    #40 Purrius, Nov 26, 2025
