How long does it take your gen5 prime to charge from zero range? Something wrong with my battery?
Discussion in 'Gen 5 Prime Charging' started by wstt, Dec 16, 2024.
  1. wstt
    wstt Member
    147
    25
    Online it says leave 1 charge takes 11 hours. When I plug mine in, it says 9:20 to full charge. What is your full charge time?
    I’ve also noticed I’m not getting the range I expected to get (and it’s not because of driving style). Is it possible my battery has some cells that are bad? Is there a way to test battery capacity?
    (I have RAV4 Prime too, and that says online 12:30 to full charge and my display shows approx 12:30 each time).
    Silas Wentworth likes this.
    52,421
    range is not a fixed number, it is changeable. the epa is a specific test, you shouldn't expect any particular range, there are too many factors involved, only some of which are under your control.
    you can get a tool to measure kwh charged, and that will tell us if your battery is healthy.
    some public chargers also report kwh as well.
    in all likelihood, it is your espectations that are the problem.
    there are lots of threads in the gen 4 prime forums that cover this in detail.
    BiomedO1 likes this.
  3. BiomedO1
    4,231
    2,214
    SacTown, Ca
    It's an imperfect world out there, so when you feed a computer more accurate information - it gives you a better approximation. It's as simple as that......
    Are you going to be equally upset, when your DTE (distance to empty) rolls over to zero and the car doesn't stop dead in it's tracks or would you prefer it to continue to run?
    If you think you have a problem, take it in for service - It's under warranty......
    #3 BiomedO1, Dec 16, 2024
  4. wstt
    wstt Member
    147
    25
    Thanks for the response. How long does your Prius Prime charge from empty?
    Like I said, it’s not due to driving style / conditions. I drive in optimal range conditions, all low speed, flat, limited lights and stops. In my RAV4 Prime, I consistently get 60-62 miles of EV range when EPA is 42miles. It even shows in my estimated range after a full charge. I was expecting more range than I’m getting with my Prius Prime XSE Premium. And seeing the battery saying only 9 hours to charge when most say it should take 11 hours, it makes me wonder if the battery has problems. I guess I’ll leave it on a charge point charger one day and see how much of a charge it will take. But what should that number be? 10.5kwh? 10.9kwh?
  5. wstt
    wstt Member
    147
    25
    Again, I know it’s not due to driving style and conditions. I’m calculating how many actual miles I am getting on a full charge, not what the estimated range is. It seems suspicious that I am getting less than I thought I would AND the battery is taking 2 hours less to charge than they say it should. (For reference my RAV4 Prime charges in 12.5+ hours and it is supposed to be 12.5 hours, and I get 60-62 miles of range but it’s all low speed, flat, not a lot of lights or stop signs. )
  6. wstt
    wstt Member
    147
    25
    Again, how long are other people’s Prius Primes charging from empty to full battery? thanks.
  7. bisco
    52,421
  8. mva
    mva Member
    157
    92
    B.C. Canada
    2024 Prius Prime
    SE
    At the 12 amp setting - Charging time from empty is about 10 1/2 to 11 hours at 120 volts and 4 1/2 to 5 hours at 240 volt level 2.
    There’s also an 8 amp setting that extends the 240 volt time to about 7 hours.
    I haven’t used the 8 amp much at 120 volts because I believe it is inefficient and takes about 17 hours.
  9. Trollbait
    12,692
    Li-ion does go through a breaking period where it doesn't reach full capacity. perhaps this the case. If so, it will clear up with use.
    There are some questions to go over though.
    Are you doing trips completely on EV? Maybe the EV mode portion of the battery isn't completely drained.
    Where are you, and do you start the charge as soon as you get home? Climate and the battery's temperature will affect charge times. The link in post #7 was seeing a 9hr charge time during a NJ summer.
  10. Silas Wentworth
    Silas Wentworth New Member
    2011 Aqua
    Charging time can vary based on outlet type, temperature, and battery conditioning. 9:20 sounds normal for a Level 1 if conditions are ideal. For range concerns, you can ask the dealer to run a battery health report or use an OBD2 scanner with the Dr. Prius app to check cell balance.
    PrimeDan likes this.
  11. bisco
    52,421
    sounds like a chatbot :cool:
  12. Quovadis007
    Quovadis007 Junior Member
    COVENTRY
    2024 Prius Prime
    Business Ed. Plus
    In Belgium, with type 2 charging cable and my Prius 5 on 8A, it takes 7 h20 in the winter (+/- 225 V to 230 V mains voltage) with an empty battery and I needed 12.1 KWh of electricity. (measurable socket)
    Now that my PV produces much more electricity, the Prius is at home on Max (= 10 A) and with charging cable type 2, this now takes 5 h20, (230 V / 245 V due to the many PV installations in the street) with a total consumption of 11.4 KWh
    On a public charging station with 16A it takes 3 h20, with a consumption of 10.8 KWh
    I rarely use it, because it is usually more expensive than using petrol.
    My consumption at speeds lower than 45 miles/h is now 10.5 KWh / 100 km
    (no rain, during the day, no air conditioning, 19 inch tires)
    Average with motorway journeys included = 11.5 Kwh, where the Prius also switches to HV mode
    With a full battery I can now also drive 100 km in sunny weather. (in winter only 68 km)
    GilTal and mva like this.
  13. Danno5060
    Danno5060 Active Member
    394
    201
    Wyoming
    Take this with a grain of whatever as my experience is with a 2019 Prime. I believe the Gen 5 is pretty similar, except the controls may be a bit different, and the capacity is greater for the Gen 5.
    The range is dynamically calculated. My wife doesn't get the same EV range as when I drive it as she mainly takes it on the highway and I drive around in town. Those highway speeds (here it's 80 MPH) take more out of the battery per mile. Also, I use studded winter tires and there's sometimes a bit of wind in Wyoming that also take away EV range.
    When I first got the car, I couldn't charge it as I have a freezer on the garage circuit. When charging the car at 12 Amps, the freezer would kick on and it would trip out the garage circuit breaker. I've since installed a dedicated 240V 50A outlet in the garage. That makes it where I can use the full 12A, 240V charging rate without issues. Just for comparison, I get my 25 miles in 3 hours (4 hours if I turn it down to 8A 240V, twice the hours if I use the 120V charger - you'll need to scale that to your Gen 5)
  14. CalvinL
    CalvinL 2025 Prius Plugin XSE Royal Green PPF
    100
    28
    Long Island, New York
    2025 Prius Plug-in
    XSE
    If the following pics help (see below)
    They are my charging history from my Toyota app.
    You can see from the public charger which is a level 2, it was so mich faster and is the recommended. I believe the manual says this. I am deciding now if to upgrade my electric panel. The rest is from home. You can see at the normal 110 it takes like almost 7hours to go 64% to 100% or more importantly, 3.7kwh. Below, it takes almost 4hrs for 1.7kwh. On a level 2, was like 1 hour for almost 3kwh. But bear in mind, most public chargers will not recharge 100%. Many go 80%, some 85 to 90%, and even fewer to 100%.
    Anyways, back to charging at home. Are there other devices like air conditioners on that same circuit? It takes considerably longer to recharge my car when I also run my AC and gaming computer on the same circuit. My breaker panel tripped when a second AC was turned on lol. Which reminded me of that whole electricity and stuff.
    odb2 and dr prius app Can go some way. But likewise, check your household circuit too!!! The Toyota App is nice in many ways, but a turtle moves faster than the way the info refreshes.
    Good luck.
    Calvin
    2025 prius plugin xse
    (Previous Prii 2005,2008,2011,2013,2017)
    Attachments/pictures
