Gen 2 does not start after a breathalyzer was removed? No LED lit on Power Button.
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by James Analytic, Jun 7, 2025.
  1. James Analytic
    329
    51
    Michigan
    Like the other half or side does, says she or we are going to do and only I wind up literally doing. Kind of like the rant pre syn I'm getting now.
  2. James Analytic
    329
    51
    Michigan
    Appears I found all the wire and am still wondering what the resistance and capacitance effects are on the digital signals if that's what those are for. Didn't ID the connectors and pins along with wire colors just yet. Only conductivity to see if open circuit or not. No voltage testing as well unfortunately.
    I did come to the conclusion, since troubleshooting would be check not the wiring harness first, the fuse box and all the fuses need replacing. AM2 was not conductive nor were any of the fuses for that matter. AM2 also pulled out as a crumbled mess where I am guessing formic acid from the ants is to play? Whether that was a situation from the ants or issues prior or from the ants after sitting a year.
    48018291-4b3e-41c7-808d-c895fc9cc8a4.jpeg 81a80859-9b1c-4756-9cf9-fd75a853695c.jpeg 984ea976-29e8-432b-9865-c14cacd6a1c5.jpeg 812bfc5b-b25f-4cdb-b740-448c814d5270.jpeg
    Amazingly, performing the conductivity testing only as time was limited, everything appears to be conductive connections albeit solder blobs that are not that pretty.
  3. Tombukt2
    12,901
    2,316
    So I'm to believe those red wires were separated and device inserted in between so to speak.if that's so. Then up by pwr distro box should be another probably white wire it's Fat in same condition as red here?
  4. Tombukt2
    12,901
    2,316
    Boy that's ugly fuse box .
  5. James Analytic
    329
    51
    Michigan
    Appears they spliced into the fat blue wires (11 1H and 1 1C) for switching PWR power and I guess HTR for power? At least I'm thinking if I'm reading correctly. (4 1J) was spliced as well, which appears to be the IGN ignition. Brake pedal was the blue wire and I still need to read what the green wire is going into, a tan-yellow thing. The green had the blue wires added and the blue had the red wires added.
    Appears the additional lengths of Blue wires and Red wires were for dropping down those circuits wires for easier access maybe later to more quickly remove or to run to the IID thingy. Those get me wondering if somehow they are adding additional resistance and or capacitance to cause digital signals to be wonky. Just random guessing, though seems like if worked with then probably logically not. Wondered if any of the mess of em jostled around before insulating if grounding could have blow a fuse or damaged something?
    Yes sir, amen to that. I should of taken a photo of the pulled fuse that crumbled into powder and the plastic piece more opaque than clear blue with no continuity even when pulled. Even in the yards and all the Priuses and vehicles I've pulled fuses out of, never witnessed anything like. Fumeric Acid from the ants is my best guess.
  6. Tombukt2
    12,901
    2,316
    So now you trim back the extension wires clean up connections and resistance change should be minimal.
  7. James Analytic
    329
    51
    Michigan
    I agree and prefer to splice so no so goobery blobs of solder. Ordered more shrink tube, so can seal nicely as well.
    Wound up grabbing the fuse box at the yard and swapping in the C block section for starters since AM2 was toast.
    That and solder temp rigged the thermos engine water pump harness at the connector that might have been shorting out in the harness since as was found missing a few inch section with like 1" pigtail at the connector side. Still won't startup, i.e. go into ON (READY), however does go into the other two ON (ACC) and ON (IG) so was able to read codes. MFD and Dash came on as well.
    The codes are as follows after clearing them all: C0210, C0215, C1295, C1310, P0A9D, P0AFA, P3000, B1785 and B1650
    Technically, there were some more for the Air Conditioning and I forget what else though the above were saved after going through and clearing after trying to startup.
    Need to read into codes next since just got back from working on.
    #27 James Analytic, Jun 9, 2025
  8. James Analytic
    329
    51
    Michigan
    From Monday after getting everything connected and praying I didn't need to splice the bottom fuse box section 14 something wires.
    - YouTube
    I made a video prior to this one with the one Power button press and only the MFD came on with the door open symbol. Seems more boring and I narrated noting I needed to maybe wire some more together being I hadn't spliced the one engine coolant pump pigtail to the harness. Still waiting to coordinate with the girl and the baby to get back up with a known working HV battery to swap in and hopefully drive away if the drivetrain seems good enough.
    Two hour road trip and thinking I can go and maybe do, though seems however the HV battery swap will get the car going. Any thoughts? I've never had those SKS codes before.
    #28 James Analytic, Jun 11, 2025
  9. James Analytic
    329
    51
    Michigan
    Going into READY mode and moving, with some other issues I need to address, after HV battery swapped to replace this never in my life before seen mess:
    #29 James Analytic, Jun 12, 2025
  10. ChapmanF
    18,072
    On top of whatever other effects that might have, I don't suppose it's great for cooling airflow.
  11. James Analytic
    329
    51
    Michigan
    That mod was removed and not well documented as of yet. Whomever engineered that knew to chew the sense wires of some sort, current I'm guessing as well as one of the temp. Thinking didn't want a mobile home. Stay tuned for further updates as I wonder if will be a unique HV battery wiring repair video, optimistically thinking ahead as the charge level on the MFD showed enough bars to start the car. Maybe current reading and not only temp reading was unsuitable?
    I did notice some lamp black above and wires chewed on. Didn't inspect enough to repair there since wanted to swap in a known working HV battery since in a rush to get it out from under the walnut trees and to someone who can use.
  12. James Analytic
    329
    51
    Michigan
    Bummer, HV battery somehow discharged to ~114V. Thinking I might be motivated for the grid charger assembly as I have the parts required. Told the other half, assembling that might be a neat thing to do for a birthday task.
    Documented what I observed and will try to upload more when I can.
    Here's a teaser.
    3db371b2-20b4-4b92-8732-d3b958f6e5be.jpeg be58dc69-c433-4a8d-a7ab-c7b07089e8ec.jpeg dd807bf7-ece7-4a2b-bae6-549d7d6eacfa.jpeg
  13. James Analytic
    329
    51
    Michigan
    Wound up assembling the grid charger and charging the original mouse nest HV pack after ghetto taping over the mouse chewed wires that seemed to still be conductive when inspected. I admit, I didn't conductivity check at the plugs after doing now that I am typing this and thinking about regarding.
    So, I'll copy and paste what I noted elsewhere:
    "From 114VDC as-found after cleaning and some small repairs. She decided to see how performs once recharged only (no reconditioning cycles like per the Prolong instructions and other NiMH pack methods). Took approx 12hrs to stabilize at ~235V and then let balance at that for ~10hrs. Block 12 was the only block that was consistently higher temp by no more than 10 degrees at any time (that was when fan battery died before plugging in the Bauer fan to 120V mains) and no specific modules cells stood out overheating which is a good thing. Block 12 temp never went above ~98, where the outside temp was maybe mid to high 80's. So seems like a good pack so far and the last owners did a good job replacing modules. She'll let Toyota and Dr. Prius / Dr. Hybrid app tell us what the performance is in more detail and if needed can disassemble and test more thoroughly. Otherwise will pack up and secure to spec for her."
    In regards to driving back to her place with a known good HV pack, I did find with no related codes other than the prior noted SKS and brake sensors seems. Wondering if the later might be a fuse in the ant's nest potential mess for the ABS. Will have to look for chews and opens.
    P0A9D, P0AFA, P3000 and P0AC0 came up after swapping back in the mouse nest HV pack that came with, since wanted to see what the ghetto inspection and taping to prevent shorts between wires might have done. Still the urinated mess of a system section where I am thinking I'll see what Live data looks like for the battery to get some more clues before removing the HV Battery Computer ECU and opening that up to check for corrosion since appears outside without a doubt next to the connector. I didn't inspect the Orange sense wires connections anywhere, so after Autel Live Data review I anticipate doing that and more swapping HV pack parts.
  14. James Analytic
    329
    51
    Michigan
    Here is the post rainy day guessing humidity swelled something up just right in regards to electrolyte that was built up on the inside of the HV Battery Computer ECU sense wire harness connector. The days prior I had started the car up to open and close windows and one of the last things I did was read what the HV Battery ECU codes and situation from that end were prior to planning to pull since car was still performing and reading same as prior with the original battery. ***PSA - When An HV Battery Is That Nasty, Inspect Everything Thoroughly***
    Definitely correlates with the chewed wire Temp #3 Sensor that for some reason after borescope reviewing prior to disassembly, tests lowest resistant at ~9.45Kohms at the connector. The Temp #2 was ~9.90Kohms and Temp #1 was ~9.56Kohms. Intake Temp Sensor was ~9.35Kohms. Maybe I jostled #3 with the borescope into a more favorable position or the readings were amazingly correct and the HV Battery Computer ECU was already having issues from the prior observed whatever caused the lampblack on the cover situation.
    As we can see in the image above and below, prior to my 4th of July at the Orange Sense Wire Connection to the HV Battery ECU very brief Fireworks show, the sense wires were definitely not sensing correctly (confirmed prior to Grid Charging prior assembly was correct). Where again, from my observations with other corroded HV Battery Computer ECU modules, maybe there can be buildup of oxidation-corrosion on the inside part of the connector where I am guessing debris along with urine possibly can build up and on the humid day decide to spectacularly short? Strange since happened as I was unplugging the HV Battery ECU outside connection to the vehicle harness. FYI... every block past block 3 read wrong and no mouse chew marks were on the sense wire harness.
    b88f5a48-e999-433b-b848-1d08d907b20e.jpeg 3531a042-ed61-48ed-aeb5-3b83951f2872.jpeg
  15. Tombukt2
    12,901
    2,316
    Ow we going places that's the plug and receptacle im talking about . Ponscmust be gone in computer . Should be plentiful the whole box
  16. James Analytic
    329
    51
    Michigan
    Yes sir. Better close up photos of the temp #3 wire. Tests good actually, oddly enough.
    5996b2ed-22d0-4e42-a8fe-29ed435a7bbd.jpeg 662df982-819a-4466-99ca-e60293fe9fda.jpeg
  17. James Analytic
    329
    51
    Michigan
    I'm starting to realize this is turning into a sick porn thread. However, here is the last of the "I'm guessing why won't start" situation potential causes.
    I do see some green blue corrosion on the orange HV Battery ECU on the inside as I was suspecting. Starting to wonder is some sort of nitrate may have formed from the combination of urine and fecal matter over the year or who knows for how long. Wondering if the mouse can hear a high frequency arc as well from the beginnings of a bad connection or maybe smell and maybe they'd mark that?
    49de295e-420f-453d-bf22-f42dac776bed.jpeg 71189f12-3181-49fd-b4f2-288648eb866b.jpeg
    Kind of got me thinking about doing like Radio Direction Finding for arc faults in the Prius. Would have to characterize everything good first for subtracting out.
    Neat thing is I wound up today getting the HV Battery that came with back in service. Looks like I'm going to have one block low compared to the others that all seem considerable better for now. Does throw a P0A80 due to the voltage difference. However, neat IMO experience diving into and correcting most cost effectively and safely. Now to work on investigating the remaining codes causing incidents and correcting those situations.
  18. ChapmanF
    18,072
  19. James Analytic
    329
    51
    Michigan
    I need to read through the above thread fresh in the morning after some coffee or a workout. Thank you sir, excellent info!
    After just waking back up and not recalling much other than the smell of this latest Prius rescue that isn't the burnt smell; having three not burnt No 2 Frame Wires from Gen 2 Priuses that I am unsure the years or mileage, what all specifically would you like measured?
    I do have a Megger and Milliohm meter and can update the battery fires at ECU sense connector thread accordingly for more data.
    I also have my latest titled Gen 2, an 08 base model, that appears to have the original HV pack that I removed as when the previous owner drove it started smelling like something was burning along with having an overcharge situation where I had to shift to Neutral to get back home where I observed in Hybrid Assistant what appeared as a bad Block 14 later found module 28 most discharged after resting for a few months situation. That overcharge situation was causing the smell from what I observed in that situation, whatever that source was that hasn't been confirmed as of yet. Haven't noticed after swapping both batteries. Makes me want to look at that ones as-found HV Battery ECU connectors as a PM now. Though I don't recall any hokey codes other than P3000, P0A80 and P0606 P0138 P0420 where the later was like the P0A08 and P0A09 randomness where I need to trace down that may be more potentially fried from the reverse polarity jump that fried DC/DC 100A in the fusible link. That car appears to not want to charge the known good enough HV battery correctly, whether the inverter is actually bad still or not. I assumed the codes other than P0A80, P0420 P0606 and P0138 were due to the 12V battery being weak and later where I saw briefly due to me replacing the 12V positive terminal as found 10A Mini Fuse with a 5A low profile Mini Fuse. Where I then replace the 5A low profile with a regular 5A Mini Fuse and haven't seen the P0A08 and P0A09 since.
    I also ran B12 Chemtool Fuel Injector Cleaner and a bottle of Techron in the latest tank, as that car sounded like had been sitting a year as well prior and I haven't driven much around due to the ticking engine situation that I guess might have been aided by the bad HV Battery over revving the eCVT and engine to discharge the overvoltage situation that has been driven like who knows for how long prior to the sitting in storage for a year situation. Guessing might need an inverter converter assembly and engine. Wondering if needs an inverter, if I can replace the DC-DC Converter as my guess is that has degraded potentially after the reverse jumping assumed situation that fried DC/DC 100A and maybe funked the almost new 12V battery that was found in so much as Walmart honored the warranty.
  20. James Analytic
    329
    51
    Michigan
    Yes, swapped in a good condition HV Battery ECU and No2 Frame Wire sense wire harness and now looks like after testing in the og car and the 08 I'm seeing I'm going to have to replace some modules since throwing a Block 7 code along with the P0A80. No biggy. ECU and sense wire harness cleared C1295, C1310, P0A9D, P0AFA and P3000 I think or the better 12V battery replaced did. On that topic, this Prius came with the second Prius AGM battery I've not been able to restore. I might zap with the FCAW welder and see if brings back to life, otherwise $10 core charge.
    The og immobilizer breathalyzer car also needed both rear wheel speed sensor harnesses replaced to clear those C0210 and C0215 codes. Thankfully that was all. Found the passenger side one completely cut through in two places, though didn't notice anything yet visible on the drivers side one.
    The B1785 and B1650 needed the Zero Point Calibration done with the Techstream Utility on the Passenger side and that seemed to clear the B1650 along with.
    Now the need to decon deodorize from all the standing water in the rear end stink and mouse livery all throughout. :sick::D
    Will need to see how feels personally as well, as reported felt OK by the other half who drove the hour so road trip to her place. Oil and Oil filter change in line next up ASAP. AC is blowing cold enough seems, that was a pleasant surprise after dropping the fan and cleaning that wow way wow mess I totally was overwhelmed and forgot to photo.
