Bad 12V?
Discussion in 'Gen 4 Prius Main Forum' started by Sung Woo, Jun 26, 2025.
  1. Mr.Vanvandenburg
    1,353
    572
    2020 Prius Prime
    I sometimes charge the 12 v by putting car in park in ready mode. Usually in winter or rain. But I have a battery monitor so I know whats happening.
  2. Paul Gregory
    Paul Gregory Senior Member
    2,161
    569
    Alberta
    2024 Prius Prime
    XSE
    I don't think CCA (cold cranking amps) is a useful number for this type of vehicle. There is no cranking, as the car doesn't use a conventional starter.
  3. a2058
    a2058 Junior Member
    55
    Westchester, NY
    2019 Prius
    XLE AWD-e
    My 12V battery was registering 10.5V and not charging anymore, and I was still able to start and drive the car no problem with a lithium jump pack. Of course I changed it out after a couple of starts like that.
  4. Mendel Leisk
    41,512
    This is about what I was figuring: everyone’s advising charging, but “is this possible for you” question never asked.
    A decent smart-charger is pretty much mandatory, when your car usage is variable, with regular, multi-day downtimes. Without an AC outlet you have a quandary.
    you’re condo underground parking, or street, something like that?
  5. Mr.Vanvandenburg
    1,353
    572
    2020 Prius Prime
    For the first charge it should be possible to do it since the AGM is delivered to the door. For cost I see very reasonable smart chargers for sale, some by known brands like Schumacher. I have a few around some were really cheap, getting a like new from Amazon at steep discount.
  6. Sung Woo
    Sung Woo Junior Member
    70
    Washington, NJ 07882
    Four Touring
  7. Sung Woo
    70
    Four Touring
    Actually, can I take the battery to my neighborhood AutoZone? Looks like they offer free charging...
  8. Mendel Leisk
    41,512
    The need for initial charge is "debatable". The need for periodic, ongoing charging, especially if you're use of the car is sparodic, is more important. In lieu of charging, one simple tactic is to disconnect the battery whenever the car's going to be idle for a protracted period, say more than a week. Appreciate this is a pain.
    According to @ChapmanF there's a disconnection you do at the under-hood fuse box, more convenient than actually disconnecting the negative cable at the battery: info < Note, this is in a Gen 3 discussion, but Gen 4 may be siimilar.
    For reference, Gen 3 fuse box:
    Having a hard time finding a Gen 4 fusebox image, perhaps OP can post one?
    #28 Mendel Leisk, Jul 5, 2025
  9. Sung Woo
    70
    Four Touring
    Back when I had my Gen2, I replaced the battery twice with the Optimo yellow battery and never even considered charging, figuring the driving would do the job.
    I drive my car like once every three days. Once every two weeks I drive it for about three hours, 1.5 hours each way. I figured this was enough driving to keep the battery in decent shape, but maybe I was wrong...
  10. Mendel Leisk
    41,512
    Your usage is ok, but those regular 2 day hiatus reduce the lifespan.
    I'm the poster-boy for low usage, with both me and my wife retired now we're only accumulating around 3000 kms yearly (2000~ miles, yes...). The car only gets used around once a week. Current battery is an Optima Yellow Top, installed in September of 2015. I've got it near constantly on a CTEK 4.3 charger, using a quick connect. Appreciate that's not happening for your scenario though, with no AC.
  11. Mendel Leisk
    41,512
    We make a point of consolodating trips, say when we've got to drive somewhere, do the heavy shopping on same day, if practical. Then back on the charger the next day. Yesterday I had the dentist, then this morning doing my charger hook-up drill.
  12. Paul Gregory
    2,161
    569
    Alberta
    2024 Prius Prime
    XSE
    I'm no expert on lead-acid battery technology, but I believe the charge level should be increased in lower temperatures, and of course, the reverse.
    This would account for the higher initial voltage shown when I start the car on a cold morning, and see it drop as the battery warms up.
  13. Mr.Vanvandenburg
    1,353
    572
    2020 Prius Prime
    I wouldn’t, get a lower cost charger maintainer and plug in at home. I don’t know what amps autozone charges at, may do more harm than good. A maintainer can be left on for hours if you don’t want to get a battery monitor. At least going in the battery will be fully charged. I almost guarantee it wont stay that way long if its like my gen4. I do have the prime but not sure that the standard hybrid is different.
  14. Paul Gregory
    2,161
    569
    Alberta
    2024 Prius Prime
    XSE
    Why would you take a battery anywhere for charging? If you don't own a battery charger, the car will charge it.
  15. Mendel Leisk
    41,512
    Asked and answered: he doesn't have AC outlets available where he parks, so this would entail pulling the battery.
  16. Paul Gregory
    2,161
    569
    Alberta
    2024 Prius Prime
    XSE
    I'd heard stories about the LVL 1 chargers that come with the car being stolen, so I bought a much cheaper one online. So far, it's been doing a perfect job.
    It's no longer listed on Amazon, but I paid $164. Less than 10% the price I was quoted from the dealer for an OEM cable.
  17. Sung Woo
    70
    Four Touring
    @Mendel, I believe you asked for a pic of the Gen4 fusebox -- see attached.
    I'll let you all know how it goes with the battery charge (I bought a $17 charger) and the install...
  18. Sung Woo
    70
    Four Touring
    Just got the battery and checked its voltage with a multimeter. It reads 12.81V. Do I still need to charge this thing with my charger before installing it into the car?
  19. Brian1954
    Brian1954 Senior Member
    2,229
    877
    South Central PA, USA
    No, you should be good to just install it into the car.
    Sung Woo likes this.
  20. Paul Gregory
    2,161
    569
    Alberta
    2024 Prius Prime
    XSE
    I have a voltmeter plugged into the lighter socket, which shows the system in real time. It ranges from 14.2V when the temperatures are low, and can go as low as 12.2V when the battery is warm. Parking in the sun can drive temperatures quite high in the rear compartment where the battery is situated. I've seem temperatures as high as 50C back there. And that was with all four windows down a few inches.
    I have placed a foil reflector over the cargo cover, which seems to be mitigating the heat buildup a bit.
