2013 Prius Two Head Gasket Set Part Number?
Discussion in 'Gen 3 Prius Main Forum' started by pingd, Oct 22, 2022.
  1. ASRDogman
    ASRDogman Senior Member
    7,747
    3,964
    whattteeverrrr
  2. Bill Norton
    Bill Norton Senior Member
    2,208
    744
    MONW, Ks.
    2019 Prius
    L Eco
    Not as well stated.:unsure:
  3. ASRDogman
    7,747
    3,964
    whattteevverrrrrrr :cautious::sleep:
  4. Mendel Leisk
    41,808
    I don’t hear a thing… :)
  5. Elektroingenieur
    2,515
    3,287
    Three Touring
    I don’t have reliability data for Toyota’s head gaskets, but the part has changed several times since the launch of the third-generation Prius model. The original service part number was 11115-37051. This was superseded by 11115-37060 in December 2011; by 11115-37061 in October 2014; and by 11115-37062 in November 2021. The last is the current service part number, for the head gasket only (not the kits), for all third-generation Prius, Prius v, and Prius Plug-in (2010–2015) cars.
    I don’t know the reasons for these changes, which don’t imply that the earlier parts were defective. Parts can be changed for many other reasons, such as cost reduction, manufacturing efficiency, or commonization.
  6. Bill Norton
    2,208
    744
    MONW, Ks.
    2019 Prius
    L Eco
    OK, getting progressively more childish.
    But I'm all for that! So, whatever, right backatcha!;)
    What does imply the part was definitely defective (or the head/block design) is the chronic failures of this part.
    What more evidence do we need?
    At this point even toyota does not have 'reliability data' on all the head gasket repairs out there in the world.
    This is a 13 year old engine at this point. There are Mobile Pit-Stop-Like Head Gasket repair services.
    Do you think toyota gathers data on outside-the-dealership repairs? I don't think that's possible.
    5 strikes and you're out.
    I'm going with the FelPro, when my time comes.:mad:
    (Or Blue Devil and sell it quick,,, like I did with my second Gen3.:unsure::whistle:)
    (And get an affordable used BEV,,, ya, right.. I'm selling an EV and bought this current Gen3, bc I need more range.:rolleyes:)
    Even if I change engine coolant and clean the complete EGR circuit every 100k miles, what are my chances of this part of the engine lasting a long time? Is there data on this forum about that?
  7. ASRDogman
    7,747
    3,964
    Bill Norton likes this.
  8. Bill Norton
    2,208
    744
    MONW, Ks.
    2019 Prius
    L Eco
    Oh, here's an idea!
    Start with the biggest font for the w and the smallest font for your last r!
    COOL :)
    The kids like this stuff!
  9. ASRDogman
    7,747
    3,964
    :sleep::sleep::sleep:whattteevverrrrrrr , kid:cautious::sleep::sleep::sleep::sleep::sleep:
  10. Carall
    Carall Active Member
    316
    104
    Harrisonburg, VA
    I tried to find on this website what this set looks like and couldn't find it.
    Engine Cylinder Head Gasket Set - Toyota (04112-37254)
    There are also questions about some of the o-rings from this kit. It is not clear where they are placed.
    Strangely, this kit doesn't come with 2 o-rings for the oil filter housing.
    They could have packed it better. The the exhaust manifold gasket lies on the head gasket.
    #30 Carall, Jul 20, 2025
  11. Carall
    316
    104
    Harrisonburg, VA
  12. Mendel Leisk
    41,808
    You're in luck, @NutzAboutBolts has just posted a head gasket video, starts off part 2 with a thorough explanation of the Toyota gasket kit parts: here:
    Nutz About Bolts Prius Maintenance Videos | Page 28 | PriusChat
    Also mentions several that were not included, which he purchased separately.
    I've always gone back to the kit part no in the attached, when the question comes up, not sure if it's still the latest.
    Carall and NutzAboutBolts like this.
  13. ASRDogman
    7,747
    3,964
    The "?" on the right of the part number sticker, I believe one goes in the front of timing cover,
    and the other goes on the head under the cam shafts, or on the valve cover. You have to look
    closely, because it's small, easily missed. I forget where the left "?" ones goes, sorry. It's bee a year...
  14. Carall
    316
    104
    Harrisonburg, VA
    Some updates.
    The part number for the O-Rings, Oil Filter Bracket 96723-24020
    adrtho4 and Mendel Leisk like this.
  15. Mendel Leisk
    41,808
    There seem to be at least two gasket kits, the first is from the oil consumption mitigation TSP I posted earlier, and the second what you’ve posted on table top, plus title/description from Toyota USA parts site, more head-centric:
    Engine Overhaul Gasket Kit:
    04111-37325
    Engine Valve Grind Gasket Kit
    04112-37254
    #35 Mendel Leisk, Jul 21, 2025
  16. Carall
    316
    104
    Harrisonburg, VA
    I couldn't find this part number on Google 04111-37325.
  17. Mendel Leisk
    41,808
    Apologies, should be 04111-37315. Screen grab from the TSB I posted:
    that’s one fantastic picture you’ve posted btw, I think there’s an info resource page on priuschat, maybe @Tideland Prius can add it? @ChapmanF is up on this too.
  18. Carall
    316
    104
    Harrisonburg, VA
    No problem.
    I'll take a closer look at 04111-37315 kit later.
  19. Carall
    316
    104
    Harrisonburg, VA
    It turns out that the Engine Overhaul Gasket Kit: 04111-37315, which differs in that it has 2 rings for the oil filter adapter. There is also a crankshaft seal and a gasket for water pump and thermostat. The rear main seal is useless when replacing the head gasket. The price of this kit is a little higher, but one ring for the oil filter adapter costs about $4 (need 2 of them) and the crankshaft seal costs about $15. If you buy these parts separately, the price will be about the same as Engine Valve Grind Gasket Kit: 04112-37254.
    Next time I need a set, I'll try this one.
    ASRDogman and Mendel Leisk like this.
  20. Carall
    316
    104
    Harrisonburg, VA
    I was going to buy the 04111-37315 kit, but instead i was suggested the 04111-37316 kit.
    I checked the Toyota website and that's what it says.
