Most efficient speed for best MPG?
Discussion in 'Gen 2 Prius Fuel Economy' started by Swamibob, Jan 24, 2006.
  1. texnet
    texnet Junior Member
    30
    Houston
    We all want to drive faster. We all want more MPG. Why not have both?
    My solution:
    I find on long highway trips it is good to draft behind a large fast moving vehicle like the following:
    Semi Trucks - plenty to choose from, the square trailer trucks are good except they tend to kick up rocks sometimes.
    Big Travel Buses - best draft wake, does not kick up rocks.
    Large motor homes - good draft wake
    Large 5th wheeler trailers - good draft wake but tend to be slower and tend to waggle in the wind.
    On my last road trip I was doing 41mpg at 65mph in a headwind. I drafted behind a Travel Bus and was doing 50mpg at 75mph.
    You do have to pay close attention but I find the cruise control can do much of the work by just bumping down and up as we traverse hills. I keep my foot over the brake to disengage at any time.
    Any thoughts?
  2. skruse
    skruse Senior Member
    1,454
    97
    Coloma CA - Sierra Nevada
    There have been many discussions and performance graphs on this. I earn optimum fuel economy, dependent on ambient air temperature, at 48 mph in my daily commute (30 mi each way, mostly level). I earn higher with higher temperatures, and don't drop below 48 mpg during winter. I keep detailed track of distance and fuel using a spread sheet.
  3. 08Prius
    08Prius New Member
    26
    Long Beach CA
    The best speed for MPG is 25-37 MPH
  4. acdii
    acdii Active Member
    1,124
    131
    depends on the vehicle
    2001 Crown vic gets 26 MPG @68 MPH, but only 18 MPG @45 MPH
    2007 Prius got 65 MPG@ 65 MPH behind a flatbed semi for 300 miles, best MPG is between 45-50 if you can maintain it on a flat road, but in reality, not so easy.
    2009 Camry Hybrid, 41 MPG @65 MPH, 38 MPG@55MPH.
    Seems like a lot of people are hung up on old 1970's way of thinking 55 is more efficient than 65. That held very true back in the 70's and early 80's when cars were built like bricks, but an amazing thing happened when computers were used to design cars, they became aerodynamic, and are now more fuel efficient at higher speeds. Add into that the advent of 4-5 and 6 speed transmissions with overdrive, fuel management computers, and better designed tires, and cars are nothing like they were when the 55MPH limit was imposed.
    Like I said, it all depends on the car. The Prius would probably get better high speed MPG if the engine were a little bigger, it works too hard at higher speeds. It's perfect for city driving since the electric motor does a lot of the work, but on the highway the electric motor is limited in what it can provide so the gas engine is on its own.
  5. Moadeeb
    Moadeeb Junior Member
    I'm starting to settle on 44 or 49 mph for most terrains. Of course time and traffic can dictate other speeds. I try to set the cruise control to these speeds.
  6. almostrice
    almostrice Atari Rocks
    33
    Houston
    I know I will get better mpg if I slow down, but I have settled to drive around 60mph. That speed gets me around 48mpg. If I slow down to below 50mph, I can get over 50mpg easily. Time is also important to me so 60mph is good enough. I dont need to chase any efficiency crowns.
  7. dolj
    dolj Senior Member
    8,549
    4,341
    Wellington, New Zealand
    I don't know if there is any "efficient" speed. After all the normal efficient driving methods and tires etc are taken care of, I think external wind speed and direction is a big factor in what MPG is achievable.
    For example I can get between 67 - 94 MPG (US) (80-113 MPG (UK) / 3.5-2.5 l/100 km) at 64 mph (104 kph) and other days I can't get better than around 47 mpg (56.5 MPG (UK) / 5 l/100 km) on the same journey.
    Interestingly, on the days I have problems there is wind. Also, going slower does not seem to help much. On calm days, I can go faster without much of a penalty, and even better if there is a large vehicle I can follow behind (at a 2 sec gap or even 3). On a windy day, there is almost no benefit in drafting in this manner.
    YMMV.
    #87 dolj, Oct 30, 2014
    Britprius likes this.
  8. rogerdpack
    rogerdpack Junior Member
    79
    Enoch, UT
  9. Mendel Leisk
    41,861
    rogerdpack likes this.
  10. MAX2
    MAX2 Senior Member
    1,436
    488
    101
    Third planet from the Sun
    In my opinion, the fuel efficiency of the Prius Gen2 and Gen3 is different and depends not only on speed, but also on other factors.
  11. ChaseE
    ChaseE Member
    66
    39
    29
    Oregon
    In my gen 2 I've found my best mileage is anywhere its a 35mph speed limit for extended lengths, because you can climb up to 40mph and then trigger the neutral coast function to 35, electric only back to 40, coast to 35, repeat till it starts recharging at 53% SOC...can get 65-70mpg on some in town trips if I route to roads where I can do that the most.
  12. rogerdpack
    79
    Enoch, UT
    So fun, awesome gliding, thanks!
  13. Konrad202
    Konrad202 New Member
    2012 Prius Alpha
    Upgrade
    The average mpg not the bar graphs!
  14. T1 Terry
    T1 Terry Active Member
    929
    491
    Just did a 1,000km round trip in 10 hrs driving, so an average of 100km/h, and got fuel economy of 5.2lt/100kms ...... gotta be happy with that for an '06 Prius with 344,600kms on the clock ...... It might squeak and rattle and the budgies in the back keep asking for more seed, but it still goes great and doesn't use oil ...... gotta be the best run around vehicle I've ever owned ... besides the '08 ex taxi Prius with 750,000kms on it, that gets the added points for being so cheap :LOL:
    T1 Terry
  15. Mendel Leisk
    41,861
    Calculated?
    Driving up the B.C. interior, not long after getting or ‘10, the posted speed limit was 90 km/hr, so I set the cruise there. There was a slight uphill grade, mile-after-mile, and I watched with dismay as the liter-per-100-kms slowly ticked upward.
    we hadn’t seen another car in sometime so I thought to try dropping the set speed to 80. The up-ticking ceased, and after a while it dropped a tenth, then another IIRC.
    #95 Mendel Leisk, Sep 10, 2025
  16. T1 Terry
    929
    491
    The first 650kms, 33.8 ltr to refill. Arrived home a further 350kms and took 18 ltr to fill the tank.
    We don't have bladders in our fuel tanks, so when it starts to splash out around the filler nozzle, it's full ;):)
    Hopefully my maths is correct, it has been a long day for an old bloke :rolleyes:
    T1 Terry
  17. T1 Terry
    929
    491
    All up, 10 mins short of 12 hrs from fuel pump docket leaving to fuel pump docket on return home. 1 fuel stop, two dog walks, a coffee and bacon and egg roll stop included with the first dog walk and 1 hr exactly at the driver's licence centre getting my licence and photo sorted after I discovered I'd been driving unlicenced for over a mth :whistle: Heavy vehicle and all, the motorhome with the MG4 on the trailer weighs in at just on 12 tonne .... and I did get pulled in for a random breath test for drink driving ..... thankfully they didn't do a licence check at the same time, wife doesn't have a heavy vehicle licence :eek: Drive a heavy vehicle in Aust unlicenced, straight to jail, do not pass go and it will cost you a lot more than $200 :rolleyes:
    T1 Terry
    T1 Terry
