Optimum Highway Speed
Discussion in 'Gen 4 Prius Fuel Economy' started by Zardoz, Sep 22, 2017.
  1. MelonPrius
    MelonPrius Senior Member
    839
    516
    Nevada
    I consider the source. If the charts are from Wayne, then IMO, they are accurate. He lives for this kind of stuff and takes it seriously. He won't be configuring charts while going downhill, with a strong tailwind, tailgating an 18 wheeler, etc...
  2. kevinwhite
    kevinwhite Active Member
    333
    200
    Los Gatos Ca
    Bob Wilson has posted a lot of good information on Priuschat from experiments he has done. You should review those:
    Such as:
    Updated MPG vs MPH chart | PriusChat
    kevin
  3. Munpot42
    Munpot42 Senior Member
    1,391
    544
    Santa Monica, Ca. 90405
    There is a trade off, optimum speed for mpg vs value of your time, to me cruising at 55 on the highway would be a waste of my time.
    RCO likes this.
  4. KV55
    KV55 Member
    126
    43
    Northamptonshire, UK
    Excel
    True and this will be a different value for different people, worth noting it is average speed that counts for journey time.
    RCO and Mendel Leisk like this.
  5. rogerdpack
    rogerdpack Junior Member
    82
    Enoch, UT
  6. Mendel Leisk
    42,355
    The horizontal values are in kilometers per hour, and the vertical values are liters per 100 km's. With the latter lower values are better.
    rogerdpack and Tideland Prius like this.
  7. fuzzy1
    10,713
    I just can't agree to his data collection method. It scrambles and mixes in far too much other activity. The included accelerations and decelerations render it almost meaningless for this purpose.
    The sweet spots you think you see, didn't appear in the the steady speed mpg vs mph tests run by Wayne Gerdes on CleanMPG.com, or on similar tests by a member here (unfortunately, the primary chart image was lost in a website host migration, but copies still appear elsewhere):
    #67 fuzzy1, Sep 25, 2024
  8. Tideland Prius
    16,681
  9. vvillovv
    vvillovv Senior Member
    4,337
    1,519
    NY
    I probably write the same thing over and over again, and boring ..... but what looks like optimal in one direction of a trip can be way off in the other direction of the return trip using the same route in both directions. So much depends on all the conditions of each route driven.
  10. rogerdpack
    82
    Enoch, UT
    I'm also interested in that dip around 100 km/hr...FWIW :)
  11. vvillovv
    4,337
    1,519
    NY
    There are other dips besides the dip at 100 kmh they are just not as noticable. If you get an accurate estimation of that dip at 100 kmh than you track at 60 kmh enough to see that difference, than move onto 130 kmh you'll see just how much of a dip the car will show you per speed and other conditions.
    When it starts getting really cold most of us play a lot less attention to how much gas the Prius uses.
  12. Konrad202
    Konrad202 New Member
    2012 Prius Alpha
    Upgrade
    60mph or lower?
  13. Buggs1a
    Buggs1a Junior Member
    112
    I have a 2020 L Eco. On I5 I go 50. Not on freeway I’ll go 28 - 35 as it’s always 25-40 mostly. I have gotten 77 mpg on a 20 mile trip once the car showed. I5 and then not freeway. But mostly thst trip gives 66-70 mpg according to the car. I know it’s lying tho.
    So on freeway I go 50. Not freeway 28-35. 28 is min for cruise.
