2012 Prius C AC Drain Tube Location
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by Sosa, Aug 13, 2025.
  1. Sosa
    Sosa Junior Member
    Utah Valley, Utah, USA
    Hello,
    As the title suggests, I cannot, for the life of me, find the location of the ac condenser drain tube under the car. I can't even find it anywhere online either and it's driving me up a wall. I'm wanting to do a flush for it to remove bad odor. Any help here would be fantastic, thank you.
    51,442
    it's not in front of the firewall like other prius?
  3. Sosa
    Sosa Junior Member
    I thought it would've been and maybe I'm just missing it but definitely having a difficult time finding it.
  4. bisco
    51,442
    might be a free service manual here:english-prius-c-manual-available.102440
    Sosa likes this.
  5. Mendel Leisk
    40,875
    Just editorial, and it may help with searches: the AC "radiator" in the dash is called the "evaporator".
    The drain tube should be findable, likely on right underside. Maybe tucked in behind something. Are you able to raise the car safely?
  6. Sosa
    Sosa Junior Member
    I haven't been able to but I will be able to lift it on a ramp either Tuesday or Wednesday. Should give me a better look and I should be able to find it then hopefully. I'll use information provided by both of you and hopefully it gets me there.
  7. Sosa
    Sosa Junior Member
    Okay, so I was able to raise it better and get under it. If anyone can confirm, this is the A/C evaporator drain tube, correct?
  8. bisco
    51,442
    i think so, is there a drain for the front vent intake grids as well?
