Engine shakes after replacing head gasket but no consistent codes
Discussion in 'Gen 3 Prius Technical Discussion' started by oldzebra, Sep 26, 2025.
  1. oldzebra
    oldzebra New Member
    Pacific Northwest
    Hi All,
    Replaced a head gasket on a gen 3 with 240k miles on it. Before reassembly I checked the head and block per the Toyota manual and they've better than required tolerance. Completely cleaned out the EGR system and intake with a combination of purple power and a 0 degree pressure washer. I did release the timing chain tensioner and visually verified that the hook was released and the tensioner arm was engaged.
    Engine shakes on start up but at higher RPM (not driving it, just pressing the gas) shake goes away at about 1500 RPM and above. Shake does not go away if left running at lower RPM.
    Code reader initially reported a misfire on cylinder 1, started testing that by swapping plugs/coils/injectors, code went away but the shake didn't. I think the initial misfire on cylinder 1 was related to the initial start with a drained fuel system, but am not sure. It's hard to troubleshoot without codes.
    I need a sanity check please.
    If the timing was off, there should be misfire codes or at least some code being thrown. Is that correct?
    If it were you, what would your next step be? I was thinking of getting techstream operational and trying to pull codes with that rather than my little handheld reader. Is that a reasonable thing to do or is there something else I should try first?
    Thanks
  2. Mendel Leisk
    41,315
    Maybe a bent piston arm? Did you check piston height with all at TDC? You might be able to check through the spark plug holes, there are depth micrometers for checking hole depths. They're pricey though, a dowel and razor blade might work.
  3. oldzebra
    oldzebra New Member
    Pacific Northwest
    Thank you for the reply.
    Sorry, I left out some information. This engine was running fine prior to being reassembled. Very slight shudder on start up that went away in a few seconds, classic early head gasket failure symptoms. No coolant in oil that I could identify. Unless the piston got bent during the reassembly process, which I don't think it did, I don't think it's a piston or I would think it would have been running poorly before the head job as well. That's what's so puzzling about this to me. I took an engine that was running well, replaced the head gasket, and now it's running horribly. I clearly did something wrong, but without codes it's hard to tell what. I find it especially puzzling that it runs fine at higher rpms but shudders violently at lower rpms.
  4. BiomedO1
    3,488
    1,811
    SacTown, Ca
    Did you find physical signs of leak in the old head gasket when you replaced it?
    Make sure the EGR valve isn't stuck open. That would cause a lean mixture at idle. Also check the fuel pressure; though the engine should exhibit signs of fuel starvation at higher RPMs. If everything was done correctly and put back together correctly; my bet would be stuck EGR valve.
    What was the symptoms before tear down??
  5. oldzebra
    oldzebra New Member
    Pacific Northwest
    I did find physical signs on the old head gasket. Small penetration point. Haven't been on here long enough to post links so can't show the photos.
    Will check the EGR and the fuel pressure. Thanks. It occurred to me that the EGR cooler was completely clogged. Compressed air wouldn't go through it. Neither would water, oven cleaner or anything else, left it soaking for days and nothing passed through. Pressure washed it out and then it took about a minute before any water got through. If nothing could get through the EGR cooler that means this vehicle was running with a blanked off EGR for an unknown amount of time. Since the test to see if the EGR is causing a problem is to blank off the EGR, I have absolutely no idea if the EGR valve is working or even worked when I drove the car home.
    Bit long but here's everything I know: I purchased this car used from a nice fellow who had it as his daily driver for a weekly 300 mile commute. He told me that he changed the coils and plugs and then stopped troubleshooting. He parked the vehicle and purchased another Prius about a week after noticing the problem and being unable to correct it with new coils and plugs. He concluded (correctly based on what I found) that it was the head gasket and didn't feel he had the time to take on that job. Car would shudder intermittently for a few seconds on start and then run normally. He pulled codes and found a misfire on cylinder 2. That was the only symptom. I started the vehicle and drove it a few miles to get it home. My observations matched his report: the car shuddered very slightly on start up and then ran smooth. A code was thrown for a misfire on cylinder 2. On getting home I turned the vehicle off and checked the oil again to see if there was any coolant present in the oil. There was not. I then started the tear down. That was about 2 weeks ago. Other required tools and parts finally arrived and I've been working on it as time allows since. Vehicle has 240k miles on it. Previous owner has records of regular oil changes and other maintenance going back about 7 years, car appears to have been well maintained. He was the second owner.
    I replaced the head gasket with a new felpro one that a lot of folks seem to use (the blue one.) Followed the Toyota service manual for torque specs and head/block tolerances. Also cleaned the EGR system, replaced the PCV valve, replaced various other gaskets that were exposed, triple checked timing and that tensioner was released, and then finished reassembly. Added oil and coolant, let the car sit overnight and checked under it for any leaks. No leaks and everything seemed sealed up well so I started it. It shuddered. Got a cylinder 1 misfire code. Tried to troubleshoot but that code didn't persist past the first start/shut down cycle so I think it was related to the fuel system being partially drained. No other codes are being thrown, but shaking persists.
    BiomedO1 and Mendel Leisk like this.
  6. BiomedO1
    3,488
    1,811
    SacTown, Ca
    That's normal for first fire-up and those codes should be ignored. Look for vacuum leaks. You can fire a little bit of starting fluid down the air filter intake, nonofficial check for lean mixture @ idle.
    Your correct, clogged EGR system would negate the EGR valve operation. Now that it's clean and clear, It won't idle properly because the mixture is too lean. You can block-off the EGR to test this.
    Good Luck.....
    oldzebra likes this.
  7. Mendel Leisk
    41,315
    No kidding. Just delaying the cleaning long enough, you've done a "EGR delete".
  8. oldzebra
    oldzebra New Member
    Pacific Northwest
    Thank you for the replies and sorry for the delay, had to order a prius sized adapter for my compression tester and didn't want to follow up until I knew more.
    It may or may not (also) be the EGR valve, Tested that, couldn't see a difference in run quality, still ran rough. Tested fuel pressure and that's fine. Then dug out my compression tester because that's just good practice after a head gasket changed and I didn't do it, didn't have an adapter that fit so ordered one and waited, finally got here.
    Cylinders 2-4 were normal (120+ psi) but 1 had no compression, as in, zero. So I did a poor man's leak down test and pressurized it, wouldn't hold pressure. No bubble in the coolant tank so the head gasket job seemed okay. Leak coming out of throttle body, pulled intake. Furthest left intake valve on cylinder 1 stuck open. Whacked it a few times and it broke loose, popped back closed, but I also knocked the tippet off that valve. Pressure tested again at tdc, holds pressure and 100psi was enough to turn the engine over. Now my only problem (or my next problem, since the EGR could still be messed up and I wouldn't know yet because I had no compression in cylinder 1 when I was testing it) is that I'd like to get that tippet back on without having to pull the timing cover and cams.
    I was thinking maybe I could realign the timing to the original marks, remove the bolts that hold the cams in place and maybe tilt up the intake cam just enough to slide the tippet back under the cam on that intake valve. Then torque down again. Anyone ever do that or know if it would work? I don't need much clearance, maybe 1/8th inch would do it. I just really don't want to drain down everything and redo the timing cover if I can possibly avoid it.
    BiomedO1 likes this.
  9. BiomedO1
    3,488
    1,811
    SacTown, Ca
    I would go ahead and buzz-off the 3-4 clamps holding down the cam. The tolerances are too tight and you don't want to place too much force on those soft bushings. That'll only lead to future problems.
    Just my 2-cents.....
  10. oldzebra
    oldzebra New Member
    Pacific Northwest
    I'll do that, thank you for your input.
  11. oldzebra
    oldzebra New Member
    Pacific Northwest
    Unfortunately that didn't work. I removed the clamps holding on the cam, got the tappet back in and then tried to retighten the bolts holding down the clamps (the 15 or so bronze ones with 11 stamped on them) got to the #14 in the diagram and heard a crack, thought I had snapped off a bolt or something, but the clamp itself snapped over the exhaust cam. There may be a way to do this that works, but my attempt at it didn't.
  12. rjparker
    10,080
    6,246
  13. oldzebra
    oldzebra New Member
    Pacific Northwest
    Does anyone know what the furthest left cam clamp is called? The one immediately to the right of the timing chain with the oil filter in it that's labeled #1 (of 5) if you take it out and look at it? I can't find it on the Toyota autoparts website and I need a replacement.
  14. Mendel Leisk
    41,315
  15. oldzebra
    oldzebra New Member
    Pacific Northwest
    Thanks for the link. Unfortunately, it looks like it's impossible to just buy this part. Have to buy the whole subassembly, cams and everything. Wish there was a pick and pull scrap yard near me.
  16. ChapmanF
    18,070
    Yeah, I wouldn't have guessed the bearing caps could be bought separately; I would guess they are machined together with the camshaft deck so it all ends up a matched set.
  17. oldzebra
    oldzebra New Member
    Pacific Northwest
    I purchased a new cam subassembly, tore everything apart, changed out that sub-assembly, triple checked the timing, rotating the intake cam with the tensioner engaged 7 times to make sure the timing marks still lined up (they did) and put everything back together.
    Engine now shakes even worse. I have codes for misfires for every cylinder, an error about the cam sensor circuit being open, even though the cam sensor is plugged in and errors for every ignition coil. I just can't seem to catch a break. Any ideas what's causing all of that?
  18. ChapmanF
    18,070
  19. oldzebra
    oldzebra New Member
    Pacific Northwest
    I'll start there, thanks for the suggestion.
  20. rjparker
    10,080
    6,246
