12V Battery Charging/Maintaining, Apt. Dweller Solutions
Discussion in 'Gen 5 Prius Care, Maintenance and Troubleshooting' started by Probity, Nov 4, 2025.
  1. Probity
    Probity New Member
    25
    Covington LA
    2026 Prius
    My daughter in CA will be the end-user (in a couple months?) of my new ’26 LE FWD, and I’m in the process of prepping it with a few add-ons for her. One small add-on from the maintenance side I want to do is enabling ease of 12v battery charging/maintaining. A Noco Genius2 or 5 is in her future.
    Like many, she’s an apartment dweller in SoCal. So periodic overnight (or longer) charging of the small 12v Yusa 345LN1 is pretty much out of the question (too far from apt. 120v/15 amp outlets to parking area). At her workplace, no outside outlets. Although she does normally drive daily it’s usually short 10-25 mi.) trips, and she has the occasional 1-2 week trip somewhere w/o using her car. So need other solutions.
    I read pretty much all this thread AGM battery for Gen 4/Gen 5 Prius/Prius Prime and observations on the 12-V charging system | PriusChat. Very helpful/interesting. I have been a believer in 12v maintenance chargers for many years, then and now use them on my non-hybrid gassers with 12v battery management systems that are more convoluted that apparently what the Prius LE HEV has.
    My 1st thought – I put an eyelet terminal connector under the hood at the jump start terminal locations and (somehow) bring quick-connect to outside the grill area. Every couple of weeks or so, she goes to a friend’s place, uses their (garage, other) outlet, quick-connect the Noco and overnight (~12+ hrs) or longer charge it. Likely won’t hit full charge in that limited time but seems it could help and wouldn’t hurt.
    So I popped the hood, removed the “exclusive” jump start terminals cover (aka Fuse & Relay cover). My hopes were dashed when I saw the + terminal under the red plastic cover wasn’t a nut or bolt but that flat plate thing. Fine for alligator jaw terminal clamp, not so much for trying to permanently mount an eyelet connector. So she’d have to pop the hood and use the clamps for charging. So be it.
    2nd thought – do the same thing as (1) at the 12v battery (hatch) end. For anyone who’s actually done this, how’d you exit the eyelet connector from the trunk to the outside?
    3rd thought – permanently mount the eyelet connector to the trunk 12v battery, and use a portable power station left in the closed & locked trunk area overnight to charge the 12v. Nothing exiting the vehicle. Just remember to unplug the Noco before driving off. She has a Jackery Explorer 500. Anybody try something similar to this?
    Any and all comments/ideas welcome...….
  2. BiomedO1
    3,581
    1,856
    SacTown, Ca
    IMHO; a jump box would be more prudent and she could start the car right away; instead of sitting there waiting for it to charge. As long as she keeps the car in 'Ready' mode while parked - listening to the radio, she should be fine.
    Most of the issues was a bad batch of batteries and people x-mas tree a bunch of electronics into the lighter socket. Someone even admitted to putting in an oversized fuse into the circuit because they kept blowing the OEM sized one. Strange how bad news spreads like wildfire and good news gets ignored.....
    Good Luck...
    soft_r likes this.
  3. bisco
    51,899
    and tell her to never use any accessories unless the car is 'ready'.
    Danno5060 likes this.
  4. Fenichel
    Fenichel Junior Member
    30
    West Vancouver, BC
    2023 Prius Prime
    XSE Premium
    @Probity said
    VelvetFoot likes this.
  5. Probity
    Probity New Member
    25
    Covington LA
    2026 Prius
    Thanks, a valid suggestion. I did get her a small portable power jumper for Xmas last year for her Fit, verbally walked her through operating it, not long ago she of course had a ‘no start’ incident away from home, had to have a service call jump start. When she told me later about it I asked ‘why didn’t you try the jump pack?’ – answer was ‘because it was back in the apt. at the time’ (and uncharged to boot). So much for being proactive. I sadly got on her s*** list for a week or so when I mentioned, well I explained it to you but I can’t understand it for you – I won’t make that mistake again. But maybe she’ll remember to carry it again.
    Yep bad batteries happen – had a 2017 Honda CRV OEM battery fail after less than a year from purchase, got a new one free, no questions asked.
    BiomedO1 and bisco like this.
  6. Probity
    Probity New Member
    25
    Covington LA
    2026 Prius
    Thanks. I did find that thread Battery maintainer install directly to 12V battery | PriusChat , very helpful. Good to know no hatch seal issues doing that. I think my little YUSA 12v battery is different than your Prime battery, I’ll find out soon enough, I do want to attach the eyelet connector to hopefully bypass the neg. side shunt resistor (assuming there is one on by Yusa cabling?) that measures battery current. Ran into this with my previous F-150 12v. battery maintainer install.
  7. Probity
    Probity New Member
    25
    Covington LA
    2026 Prius
    I’m still thinking about a potential under-the-hood solution. Bear with me and be kind (I’m new to both Toyotas and hybrids, the lingo/jargon is giving me some issues, and not strong on electrics):
    My LE (HEV) has the ‘exclusive’ + terminal jump start copper plate under the Relay and Fuse cover. The plate threw me off, was expecting a stud/nut type arrangement.
    There is a stud/nut in the box that comes from what the owner’s manual calls the Power Control Unit.
    Can I use that stud for mounting an eyelet connection to enable use of a Noco Genius2 or 5 (or, with the proper adapter, the Noco Boost GB20 powerpack)? The copper jump start plate looks to originate at that stud.
  8. Mendel Leisk
    41,413
    Underground parking in an apartment complex is a very difficult scenario. Maybe just a battery disconnect for the times she's leaving the car idle for "1-2 weeks"? It seems to me it'd be near futile, managing "overnight parking at friends", often enough to effective.
    With a house, we've got it easy. We drive about 3k kms a year (yup), and the car regularly sits a week, or more. I've got a CTEK charger hooked up during the idle times, near constantly. I've got a CTEK quick-connect permanently wired at the under-hood fuse box.
    There's a brass bar for clamping jump starter, but there's also the main 12 volt cable feeding in with a pig-tail connector. It's under a fussy cover: remove that, and you've got relatively secure spot to connect the positive. Neg you connect to at grounded bolt.
    I leave the quick connect socket under the hood, so hood has to be ajar to access. FWIW, anything hanging out the grill could be shorted out, by rain, or some joker with a paper clip.
    #8 Mendel Leisk, Nov 5, 2025
    Probity likes this.
  9. Probity
    Probity New Member
    25
    Covington LA
    2026 Prius
    Thanks Mendel. I did look at that video from NutzToBolts on that 3rd Gen(?), that bolt under the 'fussy cover' is what I'm talking about. What I'm thinking is that for my '26 LE, the stud/nut location in attached thumbnail is the same - where the DC-DC converter comes into the relay/fuse box. As I'm poor on electrics, didn't know if attaching the positive eyelet on the Noco to that stud/nut would cause issues (the 130A fuse block location appears to be downstream of the stud/nut, the 'exclusive' Toyota jump start plate is downstream of the 130A fuse block).
    #9 Probity, Nov 5, 2025
  10. BiomedO1
    3,581
    1,856
    SacTown, Ca
    Sorry; I've found that tongue-lashing really doesn't work. Explaining something is quite different from doing. You need to show and make them do it. Unfortunately, as a young adult - you'll need her buy-in. I've done that with my kids and my best friend's kids; when they wanted their drivers license. They had to demonstrate basic self rescue skills. That included jump-start, spare tire change, and basic fluid checks under the hood.
    While you know how to use that jump-pack; it was simply a paperweight to her. They'll be OK; as long as they don't stray out of cell phone range. That skill set came in handy when we did a multi-family camp-out. One of them got a flat, so we were just drinking beers, while she was begging us to help her change the tire. "Sorry - we're too drunk to handle heavy equipment":LOL: but we'll hold the tools for you...:whistle: She actually did pretty good, considering it's been a decade since those lessons. We did have to remind her how to break the lug nuts loose by jumping up and down on the tire-iron.
  11. VelvetFoot
    VelvetFoot Active Member
    635
    224
    New York State
    2026 Prius
    Did you see this thread?
    Probity likes this.
  12. Mendel Leisk
    41,413
    Worked ok for me. The CTEK quick connect cable I'm using has an inline fuse too, fwiw. It's not a bad idea to disconnect the 12 volt battery ground connection when adding a ringlet to that positive stud.
  13. VelvetFoot
    635
    224
    New York State
    2026 Prius
    I'm in the process of personalizing my LE, lol.
    Velcro sticks to the trunk lining material. It's not as fuzzy as some other linings I have experience with, but it still sticks.
    I put a big strip of velcro on the back of the Harbor Freight Viking jump pack and put it on top of the battery lid, up against the liner.
    It's out of the way, easily removed for battery access or actual use. If too easily removed, lol, I might stick velcro to the top of the battery case, but it's brand new...
  14. BiomedO1
    3,581
    1,856
    SacTown, Ca
    You many want to move that up front; perhaps under the seat. If your battery is really dead; you may not be able to pop the trunk and have to crawl back there to retrieve it.
    As long as the car is parked in your garage, the cold may not effect it's use. Just remember that those lithium batteries likes to be warm too.
  15. VelvetFoot
    635
    224
    New York State
    2026 Prius
    Not much room under the seat. Plus doesn't Toyota frown on putting stuff under the seats?
    If I managed to unlock the driver door with the mechanical key, would I be able to open the side passenger rear door with the mechanical button? I'm thinking not.
    edit: Still, I could open the passenger door from the inside, then open the rear passenger side door with the inside handle while standing outside, then make the reach. No crawling.
  16. Mendel Leisk
    41,413
    Was thinking similarly. Still, in a bad front end collision, it might become airborne. Under the seat would be better in that regard. And less prone to thieves' interest.
  17. bisco
    51,899
    i put stuff under the seats all the time, why does toyota recommend against it?
  18. VelvetFoot
    635
    224
    New York State
    2026 Prius
    That was from memory. Something to do with airbags?
    For sure there's no woofer under there, lol.
    Anyway, I tried to squeeze it under the seat and it wouldn't fit. I do have it all the way down though.
    At least I'll see it in the trunk. I had a can of the inflate a tire under the seat in my old car that I only remembered when I cleaned it out. :)
  19. BiomedO1
    3,581
    1,856
    SacTown, Ca
    The seat sensor for airbag activation. Too much junk under there can snag and disable it. "lawyer speak".
    I've got my emergency 4-D cell flashlight/club under there along with road flares (chemical type). Got a couple of large old-time jump packs in the garage, that gets tossed in on road trips.
  20. bisco
    51,899
    i put everything in from behind the seat, it's roomier, though i can't speak to gen 5 prius
