Intake Manifold Wire Harness help
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by RavenPri, Nov 2, 2025.
  1. RavenPri
    RavenPri New Member
    24
    North West California
    So I set out on an adventure to flush the coolant, clean the EGR and intake manifold as its been long overdue. Of course every hose and wire harness were on tighter than heck. The last harness I needed to remove of course broke! And yes I was careful as I could be for 10 minutes trying to get it off. Even after it broke it took a lot of pulling with some needle nose pliers to get it off. Anyway, I was able to get the part in stock and now need to splice it back in.
    Unfortunately I am not sure which side is goes to which now (goes for putting everything back together :(). I checked with a volt meter and the positive number is the purple wire touching the black probe and the negative number displays when the red probe touches purple. Of course pending if the probes are in correctly (n).
    I tried and still trying to find a wire diagram, but probably would have difficulties figuring how to read it. So I am looking for some help on which is the correct way the harness gets wired up. I am lead to believe it is officially called 'Canister Purge Solenoid Connector' and it connects to the intake manifold. The purple wire is on the top during testing in case its hard to distinguish, black on bottom .
    My car is my only source of income so I need to get this back up and running soon.
    Thanks,
    2012 Prius Two
    186k miles
    106k last 3.25yrs
    The back story if interested.
    Besides the overdue EGR & intake manifold cleaning and coolant flush, I recently had picked up some engine trouble. It sounded like the car was choking for air or out of gas when the motor would kick in or start to drive off after parked. Some troubleshooting online led me to the "death rattle". o_O oh no not good news. I read that it could be caused by a dirty intake and/or EGR. Ok great that was long overdue, the videos don't look that hard but not easy by any means. Finally figured out how to connect Torque Pro (just needed it set in the app settings :confused:) and got a P0302 error code. Ok well the EGR still needs to be cleaned and it ends up its pretty clogged. Still have it in the ultrasonic cleaner, it seems to be really gunked up. Hopefully not need a new one after all this.
    Anywho, back to the error code misfire cylinder 2, which I was advised to swap the coil and see if it still is # 2 or if it changes then the coil needs to be replaced. But have yet to diagnose that, but first the cleaning. Then I end up reading a post on Reddit that in scenarios like this what happens is the water pump can fail the coolant can dry up inside the radiator and causes head gasket problems and needs to be replaced or a new motor :eek:. Very bad news. I should replace the water pump while got everything apart but its a bit out of budget, but will if I have to.
    Right when the problem chug first happened I checked the oil and it was fine but the engine coolant reservoir was really low, so I topped it off, and after that remained stable but the rattle chug still happened. Tried a couple bottles of fuel injector cleaner and lessened the chug but didn't remedy it. So when I drained the radiator there seemed to be a bit of oil slick on the top. Maybe it is the residue from the new drain tub and when I flushed with distilled water (let it soak in for a bit, engine cold not running) there still appeared to have a little oily sheen on top. I still want to engine run flush and we'll see if there is still any oil slick. Have been getting oil sampled through Blackstone and the tests (4-5 8.5k~12k intervals after a hand full at 5k) have all been clean and received a big thumbs up from the lab. So I know water isn't getting into the oil.
    After all that is when I read the Reddit post, it felt like I'm in the exact same scenario :cry::cry:. I really hope its not and it will be all sorted once everything is snaped back together. :unsure:
    If you got this far thank you for your time and the main problem right now is getting the wire harness back right.
    20251102_124039.jpg 20251102_124913.jpg 20251102_125000.jpg 20251102_125054.jpg vlcsnap-2025-11-02-15h16m53s189.png vlcsnap-2025-11-02-15h17m15s079.png
  2. Iketorz
    Iketorz Junior Member
    46
    Not sure if you're asking more than this but purple is toward the back and black is toward the front.
  3. RavenPri
    RavenPri New Member
    24
    Thank you that is very helpful! I tried looking at my friends '13 but couldn't see anything without taking the airbox off.
    :barefoot: crossing fingers
  4. Mendel Leisk
    41,516
    The head gasket is likely failing, leaking coolant into cylinder two. Borescope inspection can confirm.
    You’re correct that EGR cleaning is long overdue. It’s my conviction that protracted running of the engine with the EGR system ineffective due to carbon clogging is what’s causing the head gasket failures.
    it’s always good to get on the EGR cleaning, but don’t kid yourself, deal with the head gasket first.
    More info on EGR cleaning and head gasket linked in my signature. Last link is full engine section from repair manual.
    (on a phone turn it landscape to see signatures)
  5. RavenPri
    RavenPri New Member
    24
    Thank you! The egr cooler was completely clogged. It was in the ultra sonic cleaner for 2 days! Two gallons of degreaser and 3 brake cleaner cans. It was horrible and I knew to do this a while ago, now I'm paying :( The throttle body was cleaned up real nice, and the EGR valve was real dirty too, especially inside.
    I was able to get everything back together but now I am getting a few more codes but the misfire code went away. Just to be sure I used spade clips on the broken wire, I did solder the wire to the clip so I think the connection is ok. The new codes are p3190, p0102, p0108, p0113, p2135.
    Water got into the plastic air intake because it rained so I ran a blow dryer through it for a while. Will get a can of maf cleaner and see how that goes. Maybe just order a new one while doing all this. Got a new air filter on the way. But I am wondering if the codes are from the rewire, either incorrect positioning or the connection should be redone. I plan on getting a more professional for the solder once it get sorted, though I may be able to do it more permanent if for sure the wires are the correct position into the connector.
    As far as the head gasket, that would be bad bad news but that's the way the cookie crumbles.Wouldn't that show up in the oil testing?
  6. Mendel Leisk
    41,516
    Instead of endless cleaning with hydrocarbon solvents:
    P0401 code after cleaning | Page 2 | PriusChat
  7. RavenPri
    RavenPri New Member
    24
    Replaced MAF sensor and was able to take it to mechanic. He was able to confirm moisture was in cylinder. :cry:
    It does feel and sound better after the cleaning.
  8. RavenPri
    RavenPri New Member
    24
    I did a little bit of interneting and people say and show that the head gasket sealer is a short term fix that works. So after recovering from the mechanics head gasket replace estimate, I went with the cheap temporary fix. There is a 2010 with similar mileage for sale nearby for just a bit more than the estimate. Have a mechanic friend that can help with the DIY but is a bit of distance away, was planning to travel through late January/ early February and hoping the seal will hold for that long. I am a delivery driver (probably the cause of the leak from so many hot cold cycles) and really need my car and can't miss a week of work. Will I get a couple more months on the sealer?
    Though I am still getting a couple fault codes that will pop up and stay cleared for a little while then return. P0401 and P0102. I am wondering if it is partially from my harness splice repair (the low voltage read), a faulty sensor or the egr valve is not working properly? It's clean at least. I did put a dab of lithium grease on the spring inside of the valve motor for smooth operation, maybe too much or none at all?? Or maybe just the magnet inside needs replacement. I don't mind getting a new valve pump assembly just trying to keep the load off the wallet. I see an oem new one on Ebay for a decent price, should just snag it.
    Have been pretty gentle on it since getting back but I am getting ~10 mpg less. A Dr. Prius test put me at 60% battery with a score of fair but the other test said good. So I dont think the -10mpg drop has much to do with the battery although its getting there.
    Did a couple screen recordings of torque pro on a short drive. One is with the error codes (will see some of the gauges not working) and the other with fault codes cleared.
    Also, though may not be related, I cycle through the different octanes every so many months.
  9. priumium
    priumium Member
    258
    66
    Sweden
    2013 Prius Plug-in
    For any reference, I bought a salvage complete EGR with cooler from a Yaris (identical)(from Lithuania) for 20 euro. It was dirty but dry and I could easily blow out any carbon buildup with very high pressure air flows.
    This is dry ash and will not dissolve easily in liquids.
    Keep it dry and blow away at highest straight pressure possible- if you have the entire cooler free - before using any solvents. Also please consider the environmental effects on any fix or maintenance.
  10. Mendel Leisk
    41,516
    Ah well. :(
  11. RavenPri
    RavenPri New Member
    24
    It was completely jammed clogged.
    The environment is my first priority. Even driving the Prius as a delivery driver it really bothers me the emmisions I'm producing for one burrito or a large fry from McDumbs. It really goes against my principals but its the only thing that works for me in my area. If you know of any remote work, let me know. I would get an EV if I could afford it.
    priumium likes this.
  12. RavenPri
    RavenPri New Member
    24
    Not the greatest choices for sure. Realized after the fact I should have used only a small amount, 30 mL or so. The leak can't really be that big.
    Just disappointing because here I thought I was keeping up with maintenance minus knowing the egr needed to be cleaned and had the opportunity the last spark plug change out. :(
  13. RavenPri
    RavenPri New Member
    24
    Still have a p0401 code which is EGR flow insufficient. Wondering if its the valve, maybe the diaphragm and unfortunately sub-assembly parts aren't sold individually. Or it could be the sensor? The $200 something sensor . Probably both are the issue given my luck.
    What would you replace first the valve assembly or the sensor? Both are similar $$ so they easy choice of going with the cheaper first doesn't really pertain.
    Pretty sure now its not the wire repair. Getting all the head gasket replace parts and tools. To top it all off rear driver caliper seized and was screaming through town ‍, hashtag facepalm. . Half a can of liquid wrench took care of that. New rotors, pads and calipers are already here and will get done with the head gasket.
  14. ChapmanF
    18,249
    Loosen 2 screws and you can take the stator off that EGR valve, unscrew the rotor and look inside to see if the ski-jump inside has a rut through it. That can give you a P0401.
    RavenPri and Mendel Leisk like this.
  15. Mendel Leisk
    41,516
    Maybe dissimilar metals, for some reason, those screws can be a bear.
    For me setting the valve on a stump section, with blocking under to protect the studs, then tapping the screws with an impact driver and hefty hammer did the trick. Something like this:
    I replaced them with M4x16 socket head cap screws, hopefully make it easier if there’s a next time.
  16. ChapmanF
    18,249
    I have the same kind of hand impact tool, and a hammer about like what's shown in that picture (which I don't know that I'd call 'hefty').
    In my experience, what those screws need is a couple casual bops on the impact tool to surprise them loose, and after that, you can spin them the whole rest of the way out with fingers. Certainly not the kind of stubborn that would make me bother replacing them with anything else.
    But it is good to mention the impact tool, Those initial casual bops make a real difference, and people who try to just muscle those screws loose with a plain screwdriver do often post here about having stripped the heads.
  17. RavenPri
    RavenPri New Member
    24
    Definitely stripped one screw but found a replacement in the 'i might need this one day' pile. Did take it apart and cleaned everything but did not check the ski jump thingy. I did have the magnet cylinder thingy in the cleaner until I noticed it collecting metal dust and was like that might not be supposed to go in there. Maybe that messed with the ski jump.
    The valve assembly before cleaning was nearly stuck closed. When taken apart the spring assembly was also pretty stiff and not fluid movement more little jumpy but once cleaned it seemed to operate normally. The spring was a bit sticky though so that's why I put the lithium grease on.
    All assembled back together it did open and close much better but now that I think of it the open close didn't feel exactly as it should. Not consistent with the feel of open/close.
  18. ChapmanF
    18,249
    I'm not sure the effort of taking the valve apart is worthwhile if not checking the ski-jump while it's apart. A rut there isn't an uncommon issue.
    It doesn't get a rut because of anything you do while cleaning. If the rut forms, it forms over many cycles of normal operation.
  19. Mendel Leisk
    41,516
    I've been thinking, perhaps just wishfully, that the rut is more prone to form with abnormal operation. Maybe misguided, but would the ski jump see more/greater passes if the system is moderately to heavily carbon-clogged?
    If not, then they're all "perishable goods".
  20. ChapmanF
    18,249
    The ski jump is a simple stop at the 'valve closed' end of the range of motion. It doesn't see 'passes', it sees one 'bonk' on its tall end each time the valve closes. I don't think clogging would increase how often the valve closes.
    I would love to see if there's a difference in the way it's constructed in Toyota's revised version of the valve. Seems crazy that's been out so many years now and still, that I know of, no one has posted any pics from its insides. Every time someone installs a new one, I ask, and they say "heck no, not taking off two screws and a cover from this new valve I just bought." C'mon people!
    I noticed that in some later generations (gen 4? maybe Prius c also?) the valve itself seems to have coolant nipples on it and is hooked up for coolant to pass through it.
    #20 ChapmanF, Nov 22, 2025
    CR94 and Mendel Leisk like this.
