Dealership used 0W16 instead of 0W20 for my 2017, is that fine?
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by AustinZ, Oct 27, 2022.
Tags:
  1. AustinZ
    AustinZ New Member
    Michigan
    Four Touring
    I went to a Toyota dealership for an oil change and brake flush. Later I saw on the receipt that they used 0W16 instead of the usual 0W20 which my car manual specifies. Should I ask them to switch or should I be fine for 5k miles?
  2. JC91006
    JC91006 Senior Member
    16,767
    8,564
    That oil is wrong for the car. But I'm hoping the tech that serviced your car would know better and not put that in. I'm not even sure it can be corrected at that dealership. If you bring it back, you will not know if they actually drain the oil or put in the correct oil. They may just keep you car in the back for a couple hours and give it right back to you and say they fixed it.
  3. Doug McC
    Doug McC Senior Member
    1,079
    416
    Midwest
    2022 Prius
    There are several places on the internet (fwtw) where the two oils are compared via oil analysis, and each one I have seen shows they are nearly identical. If it makes you nervous, simply go back to the dealership and talk to the Service Manager (not the Service Advisor) and at least ask them to document it.
  4. prime grip
    prime grip Member
    115
    56
    SO CAL
    I've had a 2017 and now have a 2021 PP, both use 0w-16 as stated in the users manual here in CA. Look in your manual to make yourself at ease .
    TGrracie and Doug McC like this.
  5. Doug McC
    1,079
    416
    Midwest
    2022 Prius
    If that’s the case (not that I doubt it is), then you are much better off with that oil in there.
  6. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,592
    near Brisbane, Australia
    Here in Australia on a 2016 - they have a plethora of approved grades - and depends on the location (but no 0-16) - but then Michigan gets colder than most of Australia:
  7. prius16
    prius16 Active Member
    462
    246
    New England
    2022 Prius Prime
    It seems like in 2019, when Toyota went to the spin-on canister oil filter for the Prius 2ZR-FXE engine, Toyota also changed the recommended oil spec from 0W-20 to 0W-16.
    https://www.amsoil.com/lookup/auto-and-light-truck/2018/toyota/prius/1-8l-4-cyl-engine-code-2zr-fxe-j/?volume=us-volume
    2018 Toyota PRIUS 1.8L 4 -cyl Engine 2ZR-FXE Variable Fuel
    Capacity 4.4 quarts (with filter)
    Viscosity 0W-20 (All TEMPS) - 0W-20 is the best choice for good fuel economy and starting in cold weather. If 0W-20 is not available 5W-20 may be used. However, it must be replaced with 0W-20 at the next oil change.
    Torque 27 ft/lbs (Oil Drain Plug)
    https://www.amsoil.com/lookup/auto-and-light-truck/2019/toyota/prius/1-8l-4-cyl-engine-code-2zr-fxe-j/?volume=us-volume
    2019 Toyota PRIUS 1.8L 4 -cyl Engine 2ZR-FXE Variable Fuel
    Viscosity 0W-16 (All TEMPS) - SAE 0W-16 is the best choice for good fuel economy and good starting in cold weather. If SAE 0W-16 is not available, 0W-20 oil may be used. However, it must be replaced with SAE 0W-16 at the next oil change.
    Capacity: 4.4 quarts (with filter). After refill check oil level.
    Torque: 27 ft/lbs (Oil Drain Plug) Install a new washer on the drain bolt.
    BiomedO1 and Doug McC like this.
  8. Elektroingenieur
    2,515
    3,283
    Three Touring
    As long as the engine oil looks and smells like engine oil, not ATF WS or brake fluid or oleomargarine or whatever, I’m sure it’ll be fine.
    You’re correct that, for model year 2017 Prius cars built for sale in the U.S., the recommended engine oil viscosity is SAE 0W-20, per the Owner’s Manual (PDF), page 726. As previously discussed, however, I think that may have had more to do with the limited availability of 0W-16 oil in the U.S. at the time, than with any problem using it in the engine, for which 0W-16 has been the standard in Japan (Toyota Oil & Fluid Pocket Chart, in Japanese) since the introduction of the fourth-generation Prius model in 2015.
  9. Misterman74
    Misterman74 New Member
    Tuesday
    Fresno
    2018 Prius
    If the spec calls for 0w-20 use 0w-20 unless you live in very cold climate.
    for the 0w-16 Toyota changed a few things.
    Toyota reduced:
    • Main bearing oil clearances
    • Rod bearing oil clearances
    Tighter clearances support lower viscosity oil without metal-to-metal contact.
    Revised piston skirt coating
    The newer Prius engines received:
    • Lower-friction piston skirt coating (updated polymer-moly blend)
    • Improved skirt geometry to reduce boundary friction
    This is an internal change that directly helps with ultra-low-viscosity oils.
    Revised oil pump output / relief pressure
    Toyota tuned the oil pump relief valve to:
    • Run slightly lower peak pressure
    • Allow stable flow with 0W-16 viscosity
    • Reduce parasitic drag from the pump
    Chain-drive friction reduction
    Toyota introduced:
    • A lower-tension timing-chain tensioner
    • Improved chain lubrication passages
    This reduces friction losses that would otherwise require thicker oil.
    Updated valve-train coatings
    Later revisions include:
    • DLC-coated (Diamond-Like Carbon) cam followers / tappets
      This is specifically designed to be compatible with lower-viscosity high-slip oil films.
    • Stick to what the engine calls for.
  10. VelvetFoot
    VelvetFoot Active Member
    589
    202
    New York State
    2026 Prius
    Of course, as a GEN5'er there's this:
  11. Prodigyplace
    12,542
    11,767
    Central Virginia
    Post removed due to resurrection of zombie thread.
  12. VelvetFoot
    589
    202
    New York State
    2026 Prius
    I'm thinking of bringing along a container of Mobil1 0-8w in case the dealer hasn't run out of the 0-16w yet, although at this point in time they should have.
  13. Prodigyplace
    12,542
    11,767
    Central Virginia
    I am sure the dealer uses 0w-16 on many cars they service that require it. I doubt they would be permitted to use anything other than Toyota branded oil.
  14. JC91006
    16,767
    8,564
    The service department does not use Toyota branded oil. There are exceptions (oil for Supra), but they buy bulk stuff, not manufactured by Toyota.
    Prodigyplace likes this.
