No Heat - Replaced multiple components
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by Norry, Dec 29, 2025.
  1. Norry
    Norry Junior Member
    United Kingdom
    I have a 3rd Gen Prius which has done 300k+ miles. The car has recently started to give a few issues.
    The main issue is that I currently have very limited/no heat coming through the vents.
    I have checked and replaced the following:
    1. Tried to flush heater core with hose pipe. No change.
    2. Replaced water pump. No change.
    3. Replaced thermostat. No change.
    4. Ended up cleaning intake manifold and throttle (probably has no effect on heat but I had it open so why not!)
    The last thing I can think of is the heater core itself. There used to be a step by step video on YouTube showing how to take off the dashboard etc. Can't seem to find it now. Anyhow this is the last resort.
    Does anyone know what else it could be apart from the heater core?
    Could I use a coolant flush chemical like liquid moly to perhaps agitated any debris within the heater core thereby returning heat?
    At a crossroads and not sure what to do.
    Note:
    If anyone ever cleans their intake manifold and gets either a P0121 or P0443 code, then check all the clips and hoses are connected to the throttle body. Had to remove the air intake assembly twice because I kept on missing things.
  2. rjparker
    10,411
    6,521
    1. "Tried" to flush? Does this mean you could not get flow through it?
    2. The "air mix control damper" blend door in the air handler may not be opening. Some have found the mechanical link disconnected.
    3. There could be air in the heater core typically from a head-gasket leak pushing combustion gas into the coolant. This problem often temporarily goes away with a drain and fill.
    4. The thermostat-housing bypass inlet could be clogged.
    Heater Coolant Flow
    Heater coolant flow is continuous and has no valves in its path. The "air mix" blend door opens to allow interior cabin flow through the heater core.
    The engine's big hose coolant flow is separate from the heater-> egr cooler/exhaust recirc -> thermostat bypass flow.
    The heater coolant flow enters the core through the bottom hose and exits through the top.
    After leaving the heater core it takes two paths, one through the egr cooler and a second parallel path through the exhaust heat recirculation system.
    Those two flows merge at the front of the egr cooler and return to the small thermostat bypass inlet which is designed to be open all the time.
    From the thermostat it goes to the water pump and then through the engine.
    From the engine it returns to the heater core's bottom hose.
    #2 rjparker, Dec 30, 2025
    Joele3, Norry, Air_Boss and 2 others like this.
  3. 2015V-BadHG
    2015V-BadHG New Member
    22
    Portsmouth NH
    2015 Prius v wagon
    RJ, tks for this great explanation of coolant flow.
    Pete
  4. Norry
    Norry Junior Member
    United Kingdom
    1. As in I flushed it with a hose. Water came out the other side and reversed it too. Did not see anything out of the ordinary coming out apart from the clear water once the coolant had been flushed.
    2. To change this it would still mean removal of the whole dashboard. There is a video on YouTube showing how the blend door actuator can be replaced (assuming it's the same part). How would I know this is actually bad?
    3. Recently drained and refilled, problem remains as is. Any way to tell if there is gas in the coolant?
    4. Are these the hoses that connect to the thermostats? If they are, then when replacing the thermostat a lot of the coolant did drain out. I stuck a new thermostat on and squeezed the hoses when trying to get the air out of the coolant. Is there any way to check if this is bad?
    Your explanation of how the coolant works is incredible. Do you think there could be an issue with the cooler? I did replace the egr valve and had the cooler cleaned back in 2022. When removing the intake manifold and egr pipe, it wasn't too clogged.
  5. bisco
    52,286
    idk, but tech stream might be able to identify a bad door
  6. 2015V-BadHG
    22
    Portsmouth NH
    2015 Prius v wagon
    Norry, I bought my 2015 V with 251K miles on it with a failing HG. The heat was OK, but occasionally there was no heat like your car.
    What happens is blow by from a seeping HG pressurizes the coolant system and forces coolant out of the over flow tank. As well as creates air in the system. What I did to limp my V home (Salt Lake City to Portsmouth NH 2500 miles!) was to remove the rubber Oring from the over flow tank to keep system from pressurizing and create a makeshift over flow tank for the overflow low tank so
    I could recover coolant and fill the overflow tank back up. LOL. The key is to get the air to burp out of the system at high RPM while driving.
    Then "hope" you can get enough coolant back into via a overfilled coolant tank while car cools off overnite. I did manage it, got heat to work and ran it on high over maintains to keep car from overheating.
    Bottom Line is you need a new HG!
    Pete
  7. rjparker
    10,411
    6,521
    First, we are assuming you have not lost coolant after your drain and flush. We are also assuming it is not overheating as well.
    Second it would be much better if we knew the two Coolant Temperatures after warmup. A scanner like Techstream or a bluetooth device and app like Car Scanner can capture those two readings. If one is normal while the other is much cooler you have a flow issue.
    2. How would I know [if the air mix damper] is actually bad?
    You can Start the car, put all air flow to the front ducts, fan on max, stereo off and quickly set the temperature to 85f or Hi. This will open the damper to the heater core and decrease the vent airflow and air flow sound. Air flow is now restricted by going through the heater core. Then set the temperature to Low which will close the heater core damper and increase the air flow and sound. Air flow is less restricted since it bypasses the heater core.
    Some have reported removing the dash undercovers and perhaps the radio to directly observe the air mix linkage. Some have found it disconnected and managed to reconnect.
    3. [Coolant] Recently drained and refilled, problem remains as is. Any way to tell if there is gas in the coolant?
    If you had a huge head gasket leak a coolant combustion leak test (sometimes called a Block Test) would be positive. A small hg leak will be negative but still can cause "air pockets". Normally these cars drain and fill coolant easily and don't trap air in the process. It is diagnostic to drain the coolant, put it back in, run the engine until the thermostat opens, fill as needed, put the cap on and drive it to test for heat. If you have heat or some heat but lose it later you may have a hg leak.
    4. Are the [thermostat bypass inlet] hoses that connect to the thermostats? If they are, then when replacing the thermostat a lot of the coolant did drain out. I stuck a new thermostat on and squeezed the hoses when trying to get the air out of the coolant. Is there any way to check if this is bad?
    If the thermostat housing was changed the bypass inlet is not bad.
    No
    Notes:
    A: Two coolant temps discussed in this recent thread. Help Diagnosing Engine Cooling Problem | PriusChat
    B: While not the best test, warm up the engine and feel the hoses going into and out of the egr cooler. There should be flow and they should be hot.
    #7 rjparker, Jan 1, 2026
    2015V-BadHG likes this.
