2003 Gen 1 Dies While Driving
Discussion in 'Generation 1 Prius Discussion' started by evilroot, Jun 27, 2025.
  1. evilroot
    evilroot Junior Member
    Durham, NC
    2003 Prius
    This is an odd one that is driving me a bit crazy trying to figure out . . .
    My 2003 will be happily driving along and suddenly the engine will die (accompanied by the red exclamation, CEL, etc). This has happened while the car was stopped for a light, in a drive-through, cruising slowly, and even on the highway at 70mph. Does not seem to be tied to speed or conditions, whether I am accelerating or not, etc. It HAS been like 100 outside, but I park in the shade and the problem seems too random and intermittent for that to be the explanation.
    When it does happen I just coast down the road and can still steer/etc. All the accessories keep working, but the gas pedal does not respond and the engine stays off. I have to pull over and come to a complete stop, shift into park, and then I can restart the engine (it starts back up just fine). Sometimes it will happen again almost immediately (3x in a drive-through line once), sometimes it runs for a mile or two, or it might be fine for another week.
    The only thing Techstream sees is a p3100 code in the hybrid control ECU, but apparently that could be a LOT of different things.
    Anybody have ideas on a next step to narrow it down? I can't exactly just start swapping things, spares don't really exist!
  2. evilroot
    Durham, NC
    2003 Prius
    I drove a bit to get the issue to repeat while I had the Techstream laptop connected, and this time got the sub codes: 392 and 159.
    392 HV ECU internal error. Motor CPU malfunction
    159 Motor ECU Communication Circuit Malfunction
  3. ChapmanF
    18,263
    P3100 is one of those DTCs with a lot of different INF codes defined. You mention having Techstream, which is good; you should click the snowflake on the P3100 and look in the freeze frame for the INF code(s).
    For several of the INF codes, the repair manual has relatively simple troubleshooting steps (like, for example, checking the single-wire "GO" circuit between the HV ECU and the ECM, if that's the INF code you've got). Several other INF codes also have troubleshooting steps that are comparably simple. (Then there are a pile of INF codes at the end that all just mean "HV ECU internal error", so if you have one of those codes, that's simple too, in a different way.)
    Toyota Service Information and Where To Find It | PriusChat
    Edit: I see you did post INF codes while I was posting this.
    In the 2001 manual I'm looking at, 159 and 392 are both in the long list at the end that all mean "HV ECU internal error".
  4. evilroot
    Durham, NC
    2003 Prius
    Is that the module attached to the battery or the one on the dashboard behind the glove compartment? Or could it be either/both?
    If I can definitively trace it to one or the other I can look into getting a replacement.
  5. ChapmanF
    18,263
    It's under the carpet beneath the passenger's feet.
  6. evilroot
    Durham, NC
    2003 Prius
    If I do get my hands on a replacement, can I program it for the car using Techstream? I'm assuming it isn't even worth trying to troubleshoot the current one?
  7. evilroot
    Durham, NC
    2003 Prius
    So it looks like this is the unit in question. I see multiple replacements by the year and part number, ranging from around $40 on eBay (https://www.ebay.com/itm/151041560601) to $6-900 from Toyota.
    The service manual has a lengthy section about connecting an external battery system during programming, which I take to mean I need to hook the 12v battery to a maintainer and make sure it doesn't drop too low. I have some chunky 13.8v supplies from ham radio that should do nicely.
    What I am wondering is CAN I even program this using Techstream or do I need a valid Toyota TIS account to pull the required calibration information?
  8. ChapmanF
    18,263
    I think you should be able to. The section in the repair manual about replacing it doesn't have a lot of special instructions. You should probably also review the section on the chip key/immobilizer, because I seem to remember a special procedure for a transponder key ECU and HV ECU to introduce themselves to one another when either one is replaced. I didn't see those instructions yesterday in the "replace HV ECU" section, so probably they're in the other section. But probably they apply when either ECU is replaced.
    The HV ECU might want the VIN to be programmed. I've never tried doing that but I might have seen something in Techstream for it. Of course a new ECU probably comes out of the box wanting its VIN programmed and a used one may already think it knows its VIN. I don't know if that complicates the programming any, but I'm sure people have reported putting in used HV ECUs here.
  9. evilroot
    Durham, NC
    2003 Prius
    Nevermind wrong one, heh.
  10. Paul Gregory
    Paul Gregory Senior Member
    2,174
    576
    Alberta
    2024 Prius Prime
    XSE
    I'm OK with swapping parts to diagnose, but once eliminated, put them back; don't replace good parts until it works.
  11. ChapmanF
    18,263
    Wrong one what?
  12. evilroot
    Durham, NC
    2003 Prius
    ChapmanF: wrong part number on a site for the HV ECU.
    I went ahead and ordered the correct module, I will try putting it in and programming with Techstream when it arrives later this week. It is a scrap pull, but that is better than $900 from Toyota and for $40 I figure might as well. There is a worst case scenario: I could desolder the EEPROM from the old one and move it to the new one. It helps that I'm an electronics repair technician.
    In the meantime I might try replacing all the electrolytic capacitors. Certainly can't hurt.
  13. evilroot
    Durham, NC
    2003 Prius
    I recapped the HV ECU (because why not) and it seems to be driving fine but with a different error code thrown now. p3000-123 from the HV ECU and p3009 from the battery. The p3100 no longer comes up.
    I'm taking this to mean that the problem is probably capacitor related and in the HV ECU. The replacement one I ordered should get here Monday, and then I will see if just swapping that in clears everything.
  14. evilroot
    Durham, NC
    2003 Prius
    Driving for 15 minutes today the errors cleared themselves, and it has not died once yet. If this continues I might just keep driving it and not bother swapping in the replacement HV ECU when it arrives.
  15. Q*bertZ
    Q*bertZ Member
    156
    39
    greenville south Carolina
    2002 Prius
    I have the exact same problem. I just replaced the invertor pump because it wasn't pumping. Had errors P3000 and P3001. Now like before the car just turns off. I still have brakes and steering but no gas peddle. I clear the codes and everything is fine again. Now it gives p3100 and C1259. I'm going to try changing the ECU located under the passengers side feet. Did your resolution need any programming?
  16. ChapmanF
    18,263
    P3100 is a code with many different subcodes ("INF codes") that don't all indicate the same problem. And by "many" I mean near 80 of them. Posting the INF codes for your P3100 would really be needed before saying if it's "the exact same problem" or not.
    ronlewis likes this.
