12V battery maintenance for dummies when gone for weeks
Discussion in 'Prime Care, Maintenance and Troubleshooting' started by Girl__wonder, Jan 4, 2026.
  1. Girl__wonder
    Girl__wonder Junior Member
    @Mendel Leisk and @Pdog808 thank you!
    @bisco thanks. You're right. When I pulled into Auto Zone today, an employee had just finished checking someone's battery. He then helped me. Walking in, I saw a different employee checking someone else's car. lol. It's battery day at Auto Zone.
    I had intended to buy the Noco Genius 1 there, but the website was wrong (they didn't have one in stock) so I've ordered that and the Solar BA9 charger from Amazon and will get them tomorrow. I'm curious now. The Auto Zone battery tester didn't show CCA but said my charge is now 32%. I didn't drive at all last week. My normal driving is not helping (mostly short trips around town) but I'm surprised this is even lower than the 61% charge and 73 CCA when the car sat for 6 weeks. (the AAA display, photo above. BTW, the AAA guy did not connect to the battery directly but under the hood. And his display shows the battery specs at 350 CCA, not 285 CCA).
    I had a 2006 Prius (and other cars) and never had this problem, so this is frustrating. Is there a definitive list of things to be mindful of related to the parasitic drain? I read some of long chat thread, which is a discussion (key fob bad or not?), but I'm wondering if someone compiled a definite list. thanks
  2. BiomedO1
    3,937
    2,068
    SacTown, Ca
    This is why I don't like these newer algorithmic battery scanners. I consider them random number generators, made for gen-z that can't use their brain.
    The AAA test was OFF because it had the wrong CCA, so it showed only 73 CCA available. Don't know why a battery with only 73 CCA would be considered a passing grade. That would barely start a small engine on a 30F day. If it was a 6 or 8 cylinder, you would be walking.
    That Autozone tester seems to be a bit better, but not knowing it's internal algorithm - I can't really say how accurate it really is.
    I'm a bit old fashion and prefer the brute force approach of a carbon pile resistance battery tester. The battery must be fully charged (SOC) in order to pass that test and since it's an analog display needle, you can make your own judgement - If it's good enough.
    The 2025 Prime has more electronics and does more readiness testing. If your fob is on the edge range of the car; it's going to perform more testing & preparedness thinking your getting ready to use the car. You'll need to drop your fob into a tin box or Faraday bag to cut-off the fob signal. Short hops in ready mode, probably isn't putting enough power into the battery vs power expended in between trips. That why we are recommending a trickle charger during downtime.
    #22 BiomedO1, Feb 5, 2026 at 11:57 PM
    Girl__wonder likes this.
  3. Mendel Leisk
    41,745
    typo? The Solar BA9 is a tester, not a charger.
    Our automotive usage has wound down to near-nil, literally once a week, albeit decent-length drives. Sometimes we’ve got obligations, and if not, and it’s sunny, there’s a lovely shoreline park about 12 kms distant for a picnic lunch*. All in, lucky to do 3k kms yearly.
    last battery I put in was September 2015. In between drives it’s constantly on a CTEK 4.3 amp smart charger (installed the CTEK quick-connect cable for convenience). With the Solar BA5 it tests like new. Which is a little crazy, a battery longevity record in my experience, and maybe testament to the downside of modern vehicle “phantom draw”.
    * did that drive yesterday:
    #23 Mendel Leisk, Feb 6, 2026 at 8:15 AM
  4. bisco
    52,187
    Idk what 32% charge means. It seems awfully low. I thought they would do a voltage reading as well.
    I think you might need a charger as well, but I’m no expert
  5. Girl__wonder
    @Mendel Leisk you're right. Typo. BA9 tester. Gorgeous photo! BC is so beautiful!
    @BiomedO1 when the AAA display showed 73 CCA it also said that battery needed to be replaced. But it claimed 61% SoC. Thanks for mentioning the faraday boxes. I dug out my old Mission Darkness bag (which apparently no longer works) and ordered a new box. (the fobs are now sitting in a ziplock bag inside an olde school coffee percolator. works! lol)
    I made an appointment at the Toyota dealer tomorrow and briefly spoke to a service agent. He said that cars that are rarely driven, especially PIP, have problems holding a charge. But they'll check it out. I'm going to ask them to do a full charge and see if it will hold. I'll also ask about parasitic draws, maybe they can check for that. Anything else that you think I might want to ask? Below is my news/actions from Friday.
    On Friday my package from Amazon arrived, the NOCO Genius 1 and a TopDon tester (the Solar BA9 won't come until Sunday so I thought I'd start with this and return the one I don't want). Findings:
    1) 2pm first check, the 12V charge is 0, CCA 229 (Thurs @ 4pm AutoZone tester show SoC 32% and CCA "passed", whatever that means)
    2) 3pm driving for 35 minutes, the charge is 20%, CCA 176
    3) 7 pm a few hours later, charge is 0, CCA 182
    4) 9 pm charge is 0 and CCA is 260. After 7, I drove 10 minutes. Parked for an hour while I did something. Then I drove 45 minutes on a freeway and checked it again. I can't believe that the charge would be 0 after driving so long.
    Possible problem: Between 3 and 6ish I connected the NOCO Genius 1. I made a mistake. I couldn't figure out which type of battery it is (not in the manual) so I googled and a chatbot said it is a flooded lead-acid type. (it referenced priuschat and larryhmillertoyota.com). Since then, I looked at the label on the battery itself and saw "345LN1-MF" which I think means it's an AGM battery. So I charged the battery using flooded 12V mode instead of 12V AGM mode, 1 amp for about three hours. oops. Not sure if I wrecked the battery completely. (?) It wasn't holding a charge though on Thursday night before I intervened. Thanks for your help!
    #25 Girl__wonder, Feb 7, 2026 at 3:37 PM
  6. Mendel Leisk
    41,745
    According to my CTEK charger, choosing regular vs AGM mode simply bumps the charging voltage, with the AGM. Also, it recommends to only that only with "spiral wound" style AGM (the ones that look like canned beer 6-packs). So, I'd say no harm, just using regular mode, at most it might not charge quite as fully.
    Googling, AI says the gen 2 OEM battery is rated 325 CCA. That sounds right, and it is the case for gen 3 as well. The "RATED: 285 CCA" on your TopDon's display, did you enter it (say based on a label on the battery), or did the scanner come up with that. At any rate: the as-tested CCA it's display don't look good. A typical battery in good health will in my experience display higher than spec'd CCA, which I'd suspect is aforementioned 325. In your shoes, I'd be replacing it.
    "CHARGE= 0% 11.94V" I would gather is the voltage it measured is 11.94, and it's really in need of charging. When the Solar BA9 arrives I think you'll find it simpler but more to the point: it'll display as-tested CCA and VOLTS, toggling between the two, and give a verdict: pass, pass-but-charge, and fail (words to that effect).
  7. Brian1954
    Brian1954 Senior Member
    2,340
    933
    South Central PA, USA
    Depending on the SOC of the battery, it could take as many as 40 hours of charging with the NOCO 1 amp charger to full charge the battery. Try charging for 12 hours and do another test.
    BiomedO1 likes this.
  8. BiomedO1
    3,937
    2,068
    SacTown, Ca
    Yes, anytime it does self-diagnostic; your losing ground on the battery charge. Out of the 1A charger, your battery is only going to see 0.95A max; because the car electronics draws around 0.05A nominal - while in deep sleep.
    My gen4 battery hovers around 12V and if I catch it below 11.5V it gets a few hours on a 6A charger. I'm usually good for another 6-12 months after that. I'm usually checking the battery during the winter months; but my winters are pretty moderate. Old habits from living in the deep freeze zones. Still on my original OEM battery and has never needed a jump. I never had this issue, before I retired, when it was a daily driver on a 40 mile round trip commute.
    Hope this helps.....
