Very faint clicks at stop from brake actuator
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by howardc64, May 6, 2026 at 11:02 AM.
  1. howardc64
    howardc64 Member
    118
    48
    Pacific Northwest
    2011 150k
    Very faint clicks when at a stop from brake actuator. Had wife pull the car into drive way, gear in D, foot on brake, popped the hood and found this faint click (~1x/s) coming from brake actuator area. Quite difficult to pickup even in a quiet cabin.
    Brake works fine. Actuator pump seems to run at same duty cycle as it always has.
    Last brake fluid flush was probably > 10 years ago simply due to the complexity of flushing this system (have techstream and know the process)
    Actuator must have a high pressure accumulator of course. No idea how much pressure is maintained. Need to read up more. Currently spending accumulator diagnosing effort on an Audi DSG transmission which has a 400 PSI campbell soup can sized accumulator to drive its actuators and clutch packs haha.
    Anyone encountered before?
  2. PriusCamper
    PriusCamper Senior Member
    13,190
    5,338
    Pacific Northwest, USA
    If you don't hear clicks when you open the car door to drive it after not driving in a while you can hear accumulator pump powering up. If that's the case, keep searching for another source for the clicks.
    howardc64 likes this.
  3. howardc64
    howardc64 Member
    118
    48
    Pacific Northwest
    Good idea, I'll check this more carefully. Familiar with Prius running accumulator pump when first open the driver door in garage. I don't recall the faint clicks but will check carefully.
    I guess maybe an additional test... Run the car to get engine tranny hot. Park, wait awhile, open the door to trigger accumulator pump, see if click occur in case related to a hotter engine compartment
  4. ChapmanF
    18,697
    The release valve for one of the brake lines could be leaking slightly, so that the apply valve for that same line has to repeatedly, briefly, click open to maintain the pressure in that line while you are holding the brake.
    What leaks through the release valve returns to the reservoir, and if you're there holding the brake long enough, the pump will eventually have to cycle again, but if the leak isn't big you might notice the clicking before noticing any drastic increase in the pump cycling.
  5. howardc64
    howardc64 Member
    118
    48
    Pacific Northwest
    Thanks! Will bring a stethoscope to the test and see if can pin point click to any brake lines can get access to.
  6. ChapmanF
    18,697
    All of the apply and release valves are contained within the actuator. I don't know whether a stethoscope on the lines would allow you to pin down a particular brake line—or what good that would do, as nobody really takes the actuator apart or replaces individual valves in it.
  7. PriusCamper
    13,190
    5,338
    Yes, but it'd be interesting to know...
  8. howardc64
    howardc64 Member
    118
    48
    Pacific Northwest
    Thanks its been awhile but I recall the actuator is kind of a sealed unit. I'll run techstream later and see if any per brake line sensor to look at. Will report back but might be awhile. Still tied up debugging Audi's crazy DSG transmission with electric motor pump+accumulator ATF pressure for shifting haha. Snooping the electric motors + sensor data... Far from the days of running a simple geared ATF pump...
    PriusCamper likes this.
  9. rjparker
    10,657
    6,686
    The bad news is the brake actuator has no rebuilt or aftermarket options and most used ones are either the wrong part or are likely to be bad after sitting on a junkyard shelf.
    The good news is yours is still good with no codes. It could stay that way for months or years.
    The kind of good news is some shoppers have bought a new one and had it installed for as "little" as $500 parts and $300 labor. Parts from an online Toyota dealer during a holiday sale. Labor from an experienced independent. A few have bought the part for $1,000 and struggled to install and set it up with Techstream or equivalent. Most pay a dealer around $2,400 turnkey.
    $500 part
    Fuel Economy Drop After Speed Sensor Replacement | Page 2 | PriusChat
  10. PriusCamper
    13,190
    5,338
    Speaking of Audi... This new 3rd of 3 Rich Rebuilds video of a $160K Audi he got for less than $10K with a supposed "blown engine" when it turns out engine is fine will inspire you to be optimistic about all Audi problems:
