Very faint clicks at stop from brake actuator
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by howardc64, May 6, 2026.
  1. howardc64
    howardc64 Member
    142
    Pacific Northwest
    2011 150k
    Very faint clicks when at a stop from brake actuator. Had wife pull the car into drive way, gear in D, foot on brake, popped the hood and found this faint click (~1x/s) coming from brake actuator area. Quite difficult to pickup even in a quiet cabin.
    Brake works fine. Actuator pump seems to run at same duty cycle as it always has.
    Last brake fluid flush was probably > 10 years ago simply due to the complexity of flushing this system (have techstream and know the process)
    Actuator must have a high pressure accumulator of course. No idea how much pressure is maintained. Need to read up more. Currently spending accumulator diagnosing effort on an Audi DSG transmission which has a 400 PSI campbell soup can sized accumulator to drive its actuators and clutch packs haha.
    Anyone encountered before?
  2. PriusCamper
    PriusCamper Senior Member
    13,467
    5,434
    Pacific Northwest, USA
    If you don't hear clicks when you open the car door to drive it after not driving in a while you can hear accumulator pump powering up. If that's the case, keep searching for another source for the clicks.
    howardc64 likes this.
  3. howardc64
    howardc64 Member
    142
    Pacific Northwest
    Good idea, I'll check this more carefully. Familiar with Prius running accumulator pump when first open the driver door in garage. I don't recall the faint clicks but will check carefully.
    I guess maybe an additional test... Run the car to get engine tranny hot. Park, wait awhile, open the door to trigger accumulator pump, see if click occur in case related to a hotter engine compartment
  4. ChapmanF
    19,033
    The release valve for one of the brake lines could be leaking slightly, so that the apply valve for that same line has to repeatedly, briefly, click open to maintain the pressure in that line while you are holding the brake.
    What leaks through the release valve returns to the reservoir, and if you're there holding the brake long enough, the pump will eventually have to cycle again, but if the leak isn't big you might notice the clicking before noticing any drastic increase in the pump cycling.
  5. howardc64
    howardc64 Member
    142
    Pacific Northwest
    Thanks! Will bring a stethoscope to the test and see if can pin point click to any brake lines can get access to.
  6. ChapmanF
    19,033
    All of the apply and release valves are contained within the actuator. I don't know whether a stethoscope on the lines would allow you to pin down a particular brake line—or what good that would do, as nobody really takes the actuator apart or replaces individual valves in it.
  7. PriusCamper
    13,467
    5,434
    Yes, but it'd be interesting to know...
  8. howardc64
    howardc64 Member
    142
    Pacific Northwest
    Thanks its been awhile but I recall the actuator is kind of a sealed unit. I'll run techstream later and see if any per brake line sensor to look at. Will report back but might be awhile. Still tied up debugging Audi's crazy DSG transmission with electric motor pump+accumulator ATF pressure for shifting haha. Snooping the electric motors + sensor data... Far from the days of running a simple geared ATF pump...
    PriusCamper likes this.
  9. rjparker
    rjparker Tu Humilde Sirviente
    11,116
    6,975
    Texas Hill Country
    The bad news is the brake actuator has no rebuilt or aftermarket options and most used ones are either the wrong part or are likely to be bad after sitting on a junkyard shelf.
    The good news is yours is still good with no codes. It could stay that way for months or years.
    The kind of good news is some shoppers have bought a new one and had it installed for as "little" as $500 parts and $300 labor. Parts from an online Toyota dealer during a holiday sale. Labor from an experienced independent. A few have bought the part for $1,000 and struggled to install and set it up with Techstream or equivalent. Most pay a dealer around $2,400 turnkey.
    $500 part
    Fuel Economy Drop After Speed Sensor Replacement | Page 2 | PriusChat
  10. PriusCamper
    13,467
    5,434
    Speaking of Audi... This new 3rd of 3 Rich Rebuilds video of a $160K Audi he got for less than $10K with a supposed "blown engine" when it turns out engine is fine will inspire you to be optimistic about all Audi problems:
  11. howardc64
    howardc64 Member
    142
    Pacific Northwest
    Cool thx! I see ~$750-$800 at some Toyota dealers selling online parts and of course wait for their frequent 25% off + free ship :) So we'll see how my faint click evolve...
  12. howardc64
    howardc64 Member
    142
    Pacific Northwest
    Decided to record some data today (2011 Prius II, 151k miles). Here is accumulator pressure without touching brakes and pressing brakes 4x.
    • Car in Park, Parking brake on
    • Power button in ACC mode
    • Without touching brakes It takes 1.5min for accumulator pressure to reach the trigger point for pump to recharge (~3.7+V to 3.23V)
    • When pressing brakes, Accumulator needs charge up btw 1-2 brake press
    Incidentally, diagnosing an 17 Audi A4 dual clutch transmission (DSG) also using a pump accumulator (also nitrogen filled for counter pressure) for clutch and gear shifting pressure (no mechanical hydraulic fluid pump in this tranny). Accumulator similar size as Prius brake accumulator (campbell soup can size) and a fully charged accumulator last about 1.5 shifts before trigging the pump to charge up again. So it seems quite similar. Audi DSG has study guide outlining accumulator pressure window : 28 bar (400 PSI) is full, pump is triggered at 24 bar (350 PSI) Have some nice graphs if curious ( link )
    • My brake fluid reservoir level seems to not have moved
    • No codes
    • When pressing brakes, was able to get the faint clicks to occur a couple of times but not so repeatable
    • Stroke simulator seems to also make some noise (louder than the faint clicks) but noise stops if applying a little more firm foot pressure. I think there must be seals etc. My 2013 Tesla brake pedal also made noise since 10k miles old, some kind of seal on its stroke simulator. Been that way for > 10 years and 80k miles.
    Anyhow, seem my particular car might be still quite early in accumulator/actuator failure. Maybe occurring in many cars without people noticing. It is quite faint clicks.
    This post ( link ) has brake hydraulics diagram with sensors location etc. One of the 2 stroke sensors is the one on the brake pedal. Not sure where the other one is (simulator?) Anyway, they are inverted signals which I suppose is probably good (match haha).
    Here is a video ( link ) of teardown of Gen1 or Gen2 Prius brake pump/accumulator, actuator/ABS etc. Looks like a sensor is on the simulator (3m17s mark)
    #12 howardc64, May 10, 2026
  13. rjparker
    11,116
    6,975
    Texas Hill Country
    A key metric is how long it takes for the pump to raise pressure and then shutoff.
    The second is how long between pump runs when no brake action is needed.
    Brian1954 and howardc64 like this.
  14. howardc64
    howardc64 Member
    142
    Pacific Northwest
    Looking at the accumulator pressure recharge on the 2nd graph, looks to be ~3s. BTW, the Audi tranny pump (similar motor size as Prius accumulator pump) went from 600 RPM (this pump has dual pressure output including a low output to cool the dual clutch) to 3k RPM for 2s to bump the accumulator pressure from low trigger point 24 bar to full 28 bar.
    It does run quite a bit longer when first open the driver's door but I assume accumulator pressure is probably quite low in this scenario.
    At least while parked in ACC mode, 1-1/2min from 1st graph. This is with accumulator already charged up after opening driver's door. Then gradually fade in 1-1/2min to the pump trigger point.
    It seems nothing out of the ordinary so far. I don't notice the brake pump come on more than the past... but its one of those gradual things... probably forgot what a new car was like... much like VW turbo-charger waste gate shaft sleeve wear haha (sorry just been emersed in Audi's 1/2 time haha) when VW/Audi guys get new turbo... its like a whole new car with the old turbo losing boost with waste gate shaft sleeve wear.
    #14 howardc64, May 10, 2026
  15. rjparker
    11,116
    6,975
    Texas Hill Country
    The raising pressure time is fast and good, a sign the pump is good.
    Time between pump operations is acceptable given most people get worried when that number is 15-30 seconds. However a very good brake booster assembly (eg master cylinder) can hold pressure much longer.
    CR94 and howardc64 like this.
  16. howardc64
    howardc64 Member
    142
    Pacific Northwest
    Update
    Its 1.5 month since first post, clicking sound more frequent now braking at a stop. And pump is cycling more frequently now (every 30-40s?). No code yet although if I step on the brake really hard, the dash's slipping light comes on (I think goes away after pushing park and put in R/D again)
    Question I have is replacing both accumulator and actuator is surely the best but of course cost more. Replacing only one might find the problem is the other one. Anyway to isolate which one failed?
  17. howardc64
    howardc64 Member
    142
    Pacific Northwest
    Additional Clicking Sound (2 different ones)
    Both clicks are reproducible by ACC mode (just push power button once without stepping on brake) Prevent engine starts/noise and easier to isolate.
    Both clicks only occurs at stop with foot on brake.
    1. Original faint click still present
    2. A louder click as developed and difficult to determine the source. Click can be felt on all 4 brake lines near all 4 corner caliper AND at the exit of brake actuator. Can be felt along entire length of all 4 brake lines (at least where easily accessible such as passenger front line along the firewall) Probably the reason source is difficult to determine is due to the clicking sound traveling along all 4 brake lines with lines clipped to the chassis.
    No brake fluid external leak is seen anywhere including at all 4 calipers.
    Observation
    First faint click is something internal to the brake actuator
    2nd louder click is clearly affecting the hydraulic output to the calipers thus can be felt on the brake lines
    Next step
    Will proceed to replace actuator and accumulator and report back when done.
    #17 howardc64, Jun 26, 2026
  18. howardc64
    howardc64 Member
    142
    Pacific Northwest
    Techstream recording on clicking noise that can be felt on all 4 brake lines at a stop with foot on brake.
    • Accumulator is getting recharged ~45-50s intervals with/without foot on brake)
    • SLR (a linear solenoid) is going crazy. When it goes to 0A, click stops. SRC also goes to 0A. SLR signal seems fine during drive but goes crazy when applying brake (but only audible when stopped with ICE off - clicking sound not drowned out)
    • SLR doesn't go crazy in reverse with foot on brake
    • Saw no other data in techstream ABS/VSC/TRAC module that shows SLR crazy patterns (see signal list below)
    Brake actuator/accumulator hydraulic circuit diagram and operation explanation
    3rd Gen Prius/1st Gen Camry Hybrid Brake diagram | PriusChat
    https://attachments.priuschat.com/attachment-files/2017/01/119102_2010-Prius-NCF-BrakeControl-Details.pdf ( starts on page 22)
    Don’t know the brake hydraulic circuit in detail. According to p37 of the detailed document, SLR and SLA are primarily responsible to modulate the hydraulic pressure during braking. Either SLR has failed (under full stop foot on brake situation) or brake ECU is commanding it to behave erratically based on some other signal (but I saw no other signal changing erratically)
    Short Drive
    Start from stop. Stop 2x.
    Reverse with foot on brake
    Don't know why mph isn't 0
    Stopped with foot on brake
    ABS/VSC/TRAC Signal Lists
    #18 howardc64, Jun 27, 2026
  19. howardc64
    howardc64 Member
    142
    Pacific Northwest
    Here are basic understanding of the brake hydraulic circuits for gen3 Prius for future reference. Fed Toyota's operation theory/diagnostic document to AI and queried it to understand how it works. Transcript attached.
    Fly by wire brake hydraulic pressure
    • SLA (Solenoid Linear Accumulator)
    • SLR (Solenoid Linear Release)
    These are the 2 linear solenoids (adjustable, not just on/off) responsible to generate the proper pressure (depending on brake force demand from the foot pedal) to the brake pistons. SLA adds pressure from accumulator circuit. SLR releases pressure.
    Blending mechanical and regen braking
    Brake ECU adjust SLA/SLR and blend with the MG2 regen to provide the necessary braking force.
    SCC
    SCC opens to provide pressure to the front brakes. I guess a way to distribute more work to rear pads avoid wearing mostly front pads.
    SMC SRC
    These are fail safe valves. If fly by wire (power brake circuit with accumulator SLA SLR) circuit fails, these valves open so the brake pressure from the master cylinder is supplied to the brake lines. This basically means losing "power" brakes but not losing all mechanical braking capability. Just less power. I guess MG2 regen braking is likely still available.
    FL/FR/RL/RR H and R valves
    These 8 valves are just normal ABS system. A pair of Hold (H) and Release (R) valve per brake circuit to handle slipping wheels.
    Will do the same tests on post #18 after actuator and pump/accumulator replacement to compare the results.
  20. ChapmanF
    19,033
    I have always guessed, like the AI did in your attached PDF, the A and R were apply and release.
    I noticed in the PDF from the AI that it was 'concerned' that SMC and SRC do not remain always in the fly-by-wire position, but are seen switching between that and the fail-safe position.
    That's not a concern, that's what they normally do. They actually live in the fail-safe position all the time, only switching to fly-by-wire when you go on the pedal, if everything checks out, as described → in this post←.
    If you think of it, that's kind of how you'd want it to be. If anything doesn't check out at the time you go on the brakes, they just stay fail-safe; nothing has to switch to make that happen.
