Prius Plug In P1A00, P1A61, P1A64, P1A67, P301A, P314A, P31AB
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by James Analytic, Oct 27, 2025.
  1. James Analytic
    382
    56
    Michigan
    Amazing not much info on the Plug In Lithium packs. I finally ran, and tried to run away from and, across one.
    Throws the Prius Plug In P1A00, P1A61, P1A64, P1A67, P301A, P314A, P31AB and typical three ABS ECU codes I'm used to seeing with the other gens when the HV pack is having issues.
    Appears the recall for the fuse was never performed to begin with. Not sure if related or not as I've not found a reference for what codes get triggered in the event fuse goes bad. Still reading into NHTSA info.
    P314A is hopefully straight forward regarding a connection or the inverter pump needing swapped. Will see when get to if not more as per the Service Manual of which I've not read into in detail yet. Still researching online sources prior.
    However, the rest of the codes found appear to be resolved per replacing the HV pack with a known good one per:
    1. The titled "Hybrid Cell Voltage" thread. Hybrid Cell Voltage | PriusChat
    2. The Youtube video comments by Best Car Fixes titled "Toyota Prius 2012 No Starting Diagnose Codes P1A64-P1A67 P31AB-P1A61 _ Step By step part 1"
    Per the not exact same code Hybrid App video titled "Prius Plug-In battery error code P1A05, P1A0A, P1A63, P1A64, P1A67", appears there are issues with the BSU. Purchase a used or new "battery smart unit" AKA: BSU and "the glass unit" from trusted source, parts number 89892-47011
    I am wondering if the 2016-2022 Gen 4 Lithium option pack that uses the same looking case as the NiMH hv pack case uses the same BSU since looks the same per this Weber Auto video titled "2016 - 2022 Toyota Prius Li-Ion Battery" at this time 31:48.
    I am also wondering as well about cells interchange between 2012-2015, 2016-2022 gen 4 Li-Ion and 2016-2022 Prime HV packs. Anyone familiar with and know about options regarding?
    Removing the 2012-2015 Plug In pack can be found here at the Youtube video by Fully Charged Zone titled "Prius Plug-In Hybrid Battery Removal 2012-2015"
    Two other videos I found on Youtube for the 2012-2015 Plug In are regarding cleaning the fans:
    1. Toyota Maintenance titled "2015 Toyota Prius Plug-in Important Maintenance"
    2. Marshall Goldberg titled "Prius Plug in Cooling Fan Clean"
    #1 James Analytic, Oct 27, 2025
    priumium likes this.
  2. jacktheripper
    jacktheripper Senior Member
    279
    555
    Hi @James Analytic,
    The battery smart unit isn’t interchangeable between the Gen4 and the plug-in models. The Gen4 only has one cooling fan, while the plug-in has four — and I’m pretty sure I saw a heating pad at the bottom when working on the plug-in Prius.
    Also, the lithium packs are different in size and shape for each model. That’s why it’s taken us years of R&D to develop new replacement packs for every version. You can find more details here:
    Gen1 Plug-in Prius:
    2012 - 2015 Toyota Prius plug-in Lithium battery pack– NexPower Energy
    Gen4 Lithium Prius:
    2016 - 2022 Toyota Gen4 Prius higher-trim Lithium battery pack– NexPower Energy
    hope this helps.
    Jack @ Dr. Prius App
  3. James Analytic
    382
    56
    Michigan
    Hi @Jjacktheripper,
    Thank you kindly, definitely helps for certain.
    Confirmed the BSU's are close looking from a distance, so I am only just a little crazy and hopeful overly optimistic. 2012-2015 Plug In Prius followed by Gen 4 Li-Ion HV pack option shown below for the curious.
    I saw two sellers on eBay noting "2012-2022 Toyota Prius Plug-In HV Hybrid Battery Cell Lithium 3.5V OEM" with photos of what looked like 2012-2015 Pip cells and that alone boosted my confidence of dreams of interchange. Especially seeing more cost effective Prime packs online, so ideally newer cells.
    Reminds me I can use a full version or two on my other dedicated Dr. Prius smartphones. Next pension payment.
    #3 James Analytic, Oct 27, 2025
  4. James Analytic
    382
    56
    Michigan
  5. bisco
    52,564
    such a deal!
  6. James Analytic
    382
    56
    Michigan
    Hi again Jack, what are the physical dimensions of the 2012-2015 PIP cell and the 2016-2022 Prime cell?
  7. James Analytic
    382
    56
    Michigan
    Latest observations of friends 2014: Codes P1A64, P1A67, P1A61, P31AB "Check Hybrid System" | Page 2 | PriusChat
    Appears after charging for about 3hrs with the Nissan Leaf charger and going back in with the Autel MaxiAP200, that clearing the 10 Hybrid System and 1 ABS/VSC codes cleared all the codes so the dash if trouble light free.
    Now wondering if all related to the 12V battery and maybe for the Hybrid System, the HV battery sitting for so long.
    #7 James Analytic, May 10, 2026
  8. James Analytic
    382
    56
    Michigan
    Well, she got roadside and lined up another pack or two with hopes one is still in good enough condition and me hoping I don't have to learn how to rebuild the packs. They don't look fun to disassemble. Reassembly doesn't seem enjoyable either, albeit foolish seeming. Mainly, I hope she gets a balanced pack with all the cells having similar voltage differences with similar enough charge and discharge rates. Wishful thinking.
    However, I am very much inclined to see if feasible to hack the newer 2017-2022 and 2023-2026 PRIME cells somehow into a pack that fits safely using all the other 2012-2015 better parts. I don't comprehend yet why, other than safe fitment. Yeah, I'm being wishful, though I do enjoy learning something new and potential hacks.
    From what I read, the 2010 Prototype PiP using 96 cells report a cell size as: 4.42 x 4.35 x 0.56 in.
    The 2012 PiP using 56 cells report a cell size as: 4.13 x 5.83 x 1.04 in.
    This is per https://techinfo.toyota.com/techInfoPortal/staticcontent/en/techinfo/html/prelogin/docs/priusphvdisman.pdf
    Going by Weber Auto YT Weber State University bank specs appear to have 19 cells at 6 x 4 x 23 in, therefore I can safely assume the max cell size is definitely no more than 6 x 4 x 1.23 in. Bummer no detailed dimensions from there, though will update as I find. https://youtu.be/yGMcQ6JWlBs?t=1596 Appears sounds like the 1st and 2nd Gen PRIME cells are the exact same size dimensions, though 72 total in the pack with three stacks of 24 cell banks for the 2nd Gen PRIME.
    The 2nd Gen PRIME is noted here as having 148mm (5.83in) x 91mm (3.58in) x 26.5mm (1.04in).
    This leads me to believe the PRIME cells may be interchangeable in a PiP bank stack as no seller will reply with dimensions, i.e. Jack and eBay sellers. Depth being 1.04in and width being 5.83in equivalent and the height being the only difference where the newer PRIME are shorter I guess for better heating and cooling control fitment? Not sure just yet. Guessing from what I see as well is that the PRIME cells are being sold to fit the PiP and not the other way around, based on listing observations of PRIME pack sources and images in the listings even though claiming 2012-2022 cells.
    Anyhow, enough background and research regarding potential capabilities. Next, on to the as-found latest situation.
    OK, this time I read the codes using the Dr. Prius app and found some interesting info regarding the situation. I'll attach the screenshot here as well down below and I do agree lines up with what I remember the Autel app showing and similar codes although no engine codes were read when I used the Autel app last as-left. Maybe in the morning I'll try reading again with the Autel reader to see what is there. I don't comprehend why Dr. Prius is showing me more codes than the Autel and Techstream readings? Maybe something changed? I didn't read Engine ECU codes with Techstream however, so can't confirm that situation as-left.
    What I find as strange is the Battery Monitor showing 0.77-0.74 (0.76 in the screenshot), though the block 5 vs block 7 calculates to 27.52 - 26.05 = 1.47. Definitely over the >1.2V or whatever lesser like >0.3V reported throws codes in the NiMH packs. Bank A, B, C and D I assume are blocks 1 & 2 per Dr. Prius being bank A per Techstream and so on and so forth. Bank C and Bank D along blocks do seem to be over that >0.3 limit. Wondering if Block 7 in Bank D has a smoker and that is what we were smelling or possibly reading some more the fan can cause a similar odor? Delta SOC definitely looks like in the red at 10.00% and there it is.
    Maybe the 12V battery being low reading now, I don't recall what was prior as-found as-left, is causing the additional codes. Seems potentially likely I guess.
    6fa5cb34-18d4-49b3-809e-ac4c5b03d739.jpeg 298e68c7-a3b4-46c9-abc8-1eba2dac175d.jpeg f3d0182c-c7b1-4a07-84cd-286422a281c7.jpeg
    #8 James Analytic, May 15, 2026
  9. James Analytic
    382
    56
    Michigan
    I made a video to begin documenting the High Voltage (HV) Battery Sense ECU for the 2012–2015 Toyota Prius Plug-in (ZVW35), a.k.a. the "glass unit," officially called the Battery Voltage Sensor or "Battery Smart Unit".
    Would be nice to get this out to the electronic groups to get their thoughts regarding repair or even to begin with troubleshooting the easiest, as I am guessing many others will see parts or circuit sections that are more likely the cause of failure.
    2012-2015 Plug In Prius PiP (Gen 3 Lithium Plug In Hybrid) Hybrid Errors: - YouTube
    #9 James Analytic, May 20, 2026 at 2:53 PM
  10. ericbecky
    ericbecky Hybrid Battery Hero
    4,449
    3,353
    Madison, Wisconsin
    So I had/have a PIP that has a connection issue at the charge control computer attached to the battery .
    If the connector is wiggled it can occasionally make the car throw a slew of codes.
    P1A61, P1A64, P1A67, P31AB, U00129, U0164 etc. Not all codes every time.
    It is possible to reseat the connector and get 100's of worry free miles until it vibrates slightly out of position again.
    Not sure if directly relates to your situation, but thought I'd mention it.
    You can test this on yours by powering the car on and somewhat aggressively wiggling the right hand connector on the charge control computer. (Picture attached)
    SIDENOTE: I just made a separate post because looking for this section of harness. If you have that section I may want to buy it from you.
    Sometimes it's still attached to the battery. Sometimes it is left in the shell of the parts car. 20260519_105649~2.jpg
    James Analytic likes this.
  11. James Analytic
    382
    56
    Michigan
    Any and all info on these PIP's is excellent IMO.
    She was offered the charge controller and declined. Not sure if the pigtail was there with and I don't recall seeing attached to the cases. I'll see if I they still have the part and can ship. Since I have the contact info, I am thinking I might get and pay for shipping so I have in my parts stash for a PIP or maybe useful for some other custom project.
    The boys and I all noticed a burning electrical like smell that we narrowed down to what seemed like the Brick C & D area. I didn't pull the trunk plastic insert out, though was wondering about the wire bundle going around the outside and the 12V positive connection. Wondering now if might have been coming from below and will visually inspect more thoroughly.
    The smell came back the two times she wanted me to clear the codes and see if she could still drive.
    Time for thermal camera time anyway, as I was planning on clearing the codes and attempting to recreate to see if I can pinpoint the source.
    Next up is determining the better way to discharge the Brick A & B so to be closer to the value of the what appears better from old DrPrius data and test measurements Brick C & D replacements.
  12. James Analytic
    382
    56
    Michigan
    @ericbecky Are you able to confirm the PIP cells are as I found reported cell size as: 4.13 x 5.83 x 1.04 in. Mainly the 4.13" height. Appears is from what I can tell, though I've not compressed and drill out rivets on a Brick just yet. Will plan on doing in time.
    Have you had or know anyone who has replace Brick cells with Prime newer shorter height ones? I still need to confirm the terminal spacing as well.
    Wondering about making some sort of insert to space and not obstruct air flow since doubt will try to hack a heater and cooler to fit beneath. Would be interesting making something to space that would exchange heat as well.
  13. ericbecky
    4,449
    3,353
    Madison, Wisconsin
    I hadn't planned on taking the cover off again. But if I have time I'll see what I can do for measuring. Pretty sure I wouldn't be as accurate as your readings.
    I saw what Jack had done, which you linked. As well as The Black Jimmy Neutron.
    Not sure what people are using or swapping.
    The current state of things in my car at the moment..
