The 5th gen wheel pics thread
Discussion in 'Gen 5 Prius Accessories and Modifications' started by AddMoreGas, May 18, 2025.
  1. AddMoreGas
    AddMoreGas Member
    88
    Dallas
    2024 Prius Prime
    XSE
    Surprised this thread doesn't exist yet. I have been photoshopping a bunch of other OEM wheels on the 5th gen (using an app on phone, so results aren't great, but give a fair representation of what it would look). My goal has been to find a wheel & tire set that is:
    1. Smaller than 19" to get a bit more rubber & ride quality
    2. Wider than 195 to get a bit better grip and handling
    3. Are either 7.5 or at the most 8" wide to keep from going to too much tire and sucking up efficiency
    4. Lighter than 46 lbs all-in per wheel (which is what the OEM XSE pizza cutters and 195x50x19 weigh)
    5. Roughly same rolling diameter as stock (26.9") - 225x5
    6. Not the stock 17s because those look awful
    It is hard to hit all those criteria! Except for a few of the choices below, most are heavier than 46 lbs and wouldn't qualify, but I did the photoshop anyway. Note: Some of these are not 5x114.3 and would need adapters to make fit.
    1. Forged Prodrive GC07C
    2. Forged Lotus Evora S1 wheels
    3. Cast Audi S3 'rotors'
    4. Cast AMG C63 wheels
    5. Cast AMG monoblocks
    6. Cast Kia wheels
    7. Forged BMW 'clownshoes'
    8. Forged BMW E39 M5 wheels
    9. Forged Porsche 'lobster claws'
    10. Cast Porsche Cayman wheels
    11. Cast VW 'salad shooters'
    OEM, for reference:
    daisy555 likes this.
  2. otatrant
    otatrant Active Member
    349
    212
    San Francisco
    2023 Prius Prime
    XSE Premium
    MSW Type 48 17x7.5 +45 - not sure about weight but based on weights of 19" and 20" type 48 google estimates the weight to be 25 to 30 pounds.
    Tires Michelin CrossClimate 2 205/55R17 - Tire diameter is 3% smaller at 25.9"
    I used wheel-size.com back in 2023 to shop wheels. Can't figure out currently how to access the wheel configurator tool which let you upload wheel images and place them on your model of car. It looks like they may give free access if you sign up with email.
    Here is a photo from the tirerack configurator of Enki Vulken wheels which are available in the same size.
    From tirerack.com some BBS SR wheels 17".
    A couple more I saved from the Wheel-size.com configurator I saved.
    ENKEI NTO3RR GRAY 17X7 +48MM
    Enkei EKM3 17x7+45
    Enkei EKM3 17x7+45.gray
    ENKEI EV5 HYPERBLACK 17X7 +45MM
    Sport TuningAT2 17x7.5
    daisy555 and AddMoreGas like this.
  3. Blackat
    Blackat Active Member
    488
    356
    Colorado
    2023 Prius
    Limited AWD-e
    I went with these Enkei wheels 17 x 7.5 Running Conti 225/55/17
    #3 Blackat, May 21, 2025
  4. jtchinoy
    jtchinoy Member
    Hayward, California
    2024 Prius
    Does anyone know the wheel width + offset we need to stay within to avoid rubbing issues? I just ordered some Enkei RP03 in 18x8 +40. I saw someone on Facebook post 19x8.5 +35 and it lines up with the outside of the fender so I'm concerned I may rub during autocross or on speedbumps.
  5. otatrant
    349
    212
    San Francisco
    2023 Prius Prime
    XSE Premium
    I
    Before I bought my tires I watched some videos on backspace and front space and how to measure. Here are my numbers.
    Max Back space - 8"
    Max Front space to flush with top of fender - 2-7/8".
    With that information you can use a tool like Rim & Tire Size Calculator. Custom Offsets - Wheel-Size.com to see how you setup fits.
    I used 30 mm for wheel well clearance, 16mm fender clearance, 50 mm for suspension clearance with stock tires of 195/50R19 with 40 mm offset.
    Here are a couple of threads and posts with bigger wheels and tires that have worked out.
    Where’s the aftermarket wheel/tire thread? | Page 2 | PriusChat
    Modified '23 Prime | PriusChat
    60spedteach21 and AddMoreGas like this.
  6. RollingPanda
    RollingPanda Junior Member
    26
    Fort Worth Texas
    2025 Prius
    Limited AWD-e
    Here is my set up
    otatrant likes this.
  7. broderp
    broderp Junior Member
    OH
    2024 Prius
    Limited AWD-e
    Call me a purist, but none of those wheels look as good as the OEM alloys.
    Eddie F and mingc like this.
  8. kev604
    kev604 Junior Member
    56
    Vancouver, BC Canada
    2026 Prius Plug-in
    I've always had a soft spot for bronze wheels.
    My winter set up 17x7 +45 on 215/55/17 Michelin X-Ice Snows
    dicknose, otatrant and Blackat like this.
  9. Mccoy
    Mccoy Junior Member
    Vancouver
    2024 Prius Prime
    XSE
    I used to Photoshop my dream wheels too, but these days AI makes everything so much easier. The pics below were generated with just a simple prompt in Gemini 3 using the new wheel photo — the results are amazing…
  10. Yaktastic
    Yaktastic Junior Member
    2024 Prius
    2024 Prius XLE with 225/55r17 Verdestien Quatrac Pro+ mounted on 17x7+40 Borbet Type W wheels (anthrasite).
  11. Hammersmith
    Hammersmith Senior Member
    2,495
    2,554
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    Sorry, this has nothing to do with your car, but I found the coincidence funny...
    I was on my way to my local Toyota dealer a couple days ago and this clapped out Corolla sedan pulled up next to me at a light. Probably an 8th gen(1998-02) but I could be wrong. The rocker panels were almost completely gone; just a couple rusty remnants at each end. They had put a full sized heavy duty hitch on the back, and it looked like the car might have been lifted an inch or two(but that might have been from oversized tires or an illusion from the missing rockers).
    Anyway, I don't know why, but I looked at what tires they were running. Vredstien Quatracs. I thought to myself, "dude, those tires are worth more than your car". :D
  12. Brick317
    Brick317 New Member
    Toronto
    2026 Prius Plug-in
    XSE Premium
    225/50/18
    18x8.5 ET35
