Very faint clicks at stop from brake actuator
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by howardc64, May 6, 2026.
  1. howardc64
    howardc64 Member
    150
    58
    Pacific Northwest
    Yes, probably means Apply, I just automatically thought it was Accumulator since its pressure source :)
    Definitely make sense :)
    Thanks
  2. howardc64
    howardc64 Member
    150
    58
    Pacific Northwest
    Update:
    Actuator + Accumulator/Pump came in, installed and bled. Car brakes perfect.
    • Pump comes on a lot less frequent and much shorter duration.
    • No more clicks : faint one and the louder one felt on entire length of all 4 brake lines.
    Will separately post all the challenges on install and cheap MVCI techstream setup.
  3. howardc64
    howardc64 Member
    150
    58
    Pacific Northwest
    Follow up with a graph of working actuator behavior after replacement.
    Car in IG-ON mode (press power button 2x without foot on brake) Followed by foot on brake. Compare with failed actuator/accumulator in post #18
    Note the following
    • SLR is 0A entire time. Seem to make sense, no need to release any pressure feeding the downstream ABS.
    • SLA does pulse every 3-4s gradually extending this time. Probably just feedback loop to converge on target pressure.
    • All other solenoids are steady.
    Compared with failed part, very different picture (SLR going crazy)
    Accumulator + pump
    • Runs much shorter period in all scenarios. Opening door (after a couple of hours) only produce 1-2s of pump run time. With the internally leaking actuator/accumulator combo, it would run 5-10s after opening the door.
    • The pump also seems to run less frequent. Accumulator sensor (pressure sensor voltage) shows a much slower drop (seems both using and not pressing brakes, didn't study carefully) indicating no more internal pressure leak somewhere in the circuit.
    #23 howardc64, Jul 5, 2026
    CR94 and Brian1954 like this.
  4. howardc64
    howardc64 Member
    150
    58
    Pacific Northwest
    Actuator Repair
    Was curious why no one repairs these failed units (Simpler ABS units usually have mail in order repair services and issue seems to be always on the electromagnetic side of the solenoids). Searched and found secondary used Prius markets where labor is cheap (Pakistan, India, I also heard Mongolia is a huge 2nd hand Prius market imported from Japan) and they do have repair services for these.
    Here is a video (several exist) that shows how to remove the electronics and coil side of the actuator (on 1 board) and presumably send it in for repair.
    Removed mine and looks like this
    "If" this is the common failure, then its not the mechanical hydraulic channels and actuator valves that fail. Rather, its the electromagnetic side of the actuator and/or likely the electronics power stages. On/off solenoids probably have relays and linear solenoids probably have power transistor/switches and PWM pulsed for desired current (and resulting position) level. All are possible failure points handling higher voltage, current, and heat.
    To remove the board from that assembly require desoldering a lot of header/connector solder junctions. Will post back after getting that done with a friend's Hakko desoldering tool :)
    Accumulator Pump Repair
    Also saw a few videos on these and also from secondary used Prius markets. Failure point is the motor bearing. Coincidentally my new accumulator motor is quieter than the one removed. Presumably original 150k mile one with lots of brake use (short trips, hilly region) has some rotor shaft bearing wear.
    #24 howardc64, Jul 7, 2026
  5. ASRDogman
    ASRDogman Senior Member
    8,070
    4,092
    Looks like you just came up with a new business!
    When you gonna start your business?
  6. howardc64
    howardc64 Member
    150
    58
    Pacific Northwest
    No business for me. Just curiosity :) Others are welcomed to pursue. I guess tons of these getting thrown away.
  7. rjparker
    11,152
    6,989
    Hybridpit tried it for a while but quit.
    One issue is the variety of different firmware in brake boosters which required Hybridpit to rebuild your personal brake booster. That required the problem brake booster to be removed, shipped to hybridpit, repaired and shipped back. Add the difficulty to fully test without the corresponding car network and hardware. Finally, multiple problems are possible in a complex assembly like this and it is a life safety brake by wire device, opening liability concerns.
    Especially when new brake boosters from Toyota have been purchased as low as $500 shipped. Typical pricing is $700-$1200 using online Toyota dealers.
    These factors might be reduced in a third world country where the entire job might be done locally in realtime with no liability concerns.
    #27 rjparker, Jul 7, 2026
    howardc64 likes this.
  8. howardc64
    howardc64 Member
    150
    58
    Pacific Northwest
    Thanks for the repair attempt history. Indeed 3rd world parts from Japan in local currency aren't going to be much lower than US and probably outweigh monthly salary along with low liability.
    Shipping entire brake actuator both way would also add quite a bit of cost and eat into just new from Toyota on sale. Mine was $900 total shipped ($457.47 actuator, $446.32 pump+accumulator) Would be been another few % cheaper if had 25% rather than 20% Toyota online parts sale.
    And as you noted, great deal more complexity than typical ABS, ECU, TCM modules that have many online repair options. Most are often electronic in nature and frequently failed solder joints (especially early 2000 era beginning of lead free solder formulation)
  9. ASRDogman
    8,070
    4,092
    The hybrid pit had attempted repairing the motor/pump. But it faded away. They only gave a 30 day
    warranty. It's not worth the risk.
    You had to ship your unit to them, then they repair it and ship it back. So you have to wait.
    You can't just grab one "off the shelf" and put it in your car. It has to pair with your car's vin.
    If you want it to work.
    So it's a tricky thing to do. Someone would have to get the numbers off the parts, and match the vin's
    to that part, or that part to the vin.
    It would be nice if they could actually repair them quickly and safely though. For a lot less than a new one.
    At least it's one of those parts you're likely only have to change once in the life of the car.
  10. DIYer26
    DIYer26 New Member
    Leicester
    Hi
    I need techstream for my abs booster replacement calibration etc. Where can I get one for my Japanese import prius 2014?
  11. howardc64
    howardc64 Member
    150
    58
    Pacific Northwest
    Don't know what the etiquette on providing link to unauthorized copies of software. But you'd want to search mhhauto.com for techstream V18.00.008
    If you use mini VCI dongle, it will keep erroring out when bleeding the actuator. Read here I think much easier if investing in better tools. OTOFIX D1 Lite for $300 has been getting tons of awesome reviews by auto shop youtubers.
  12. howardc64
    howardc64 Member
    150
    58
    Pacific Northwest
    Some update and references for future DIYers
    Working system accumulator pressure loss rate without stepping on brakes
    Note the scale is 0,0x Volts so it barely dropped 0.04V in 4+ minutes. Compared to a internally leaky system on post #12 that drops 0.5V in 1.5min.
    Other Improvement Observations
    Engine shuts down much faster at bottom of hills when battery is nearly fully charged by regen. Previously, engine would keep running. I had attributed it to bleeding off a full battery but it seems replacing the actuator/accumulator has changed the behavior back to what I remember the car did when it was newer.
    Gas mileage might have improved but didn't do any kind of precise measurements. So maybe its placebo.
  13. howardc64
    howardc64 Member
    150
    58
    Pacific Northwest
    Pulled the actuator control board out (need vacuum desoldering gun) and removed the 5 capacitors. Unfortunately failure (at least noisy SLR in post #18) is not due to failing capacitors. 3x 220uF, 100uF, 47uF reads 218uF, 220uF, 222uF, 108.5uF, 48uF. Just leaving info here for future tinkerers.
    Pics
    IMG_1330.jpeg IMG_1322.jpeg IMG_1329.jpeg IMG_1328.jpeg IMG_1327.jpeg IMG_1326.jpeg
    #33 howardc64, Aug 13, 2026
