1. MichaelB126
    MichaelB126 Junior Member
    Phoenix
    Hey Folks.
    I've scanned the forum for my code and have gathered it can be a bunch of things.
    Here's what I've done recently changed fuel injector, had one sputtering. Changed plugs and coil packs.
    Had the battery and alternator tested at parts store, both are good.
    No other codes came back using Dr Prius.
    Used multi meter to check the voltage, was low at 5 volts. Charged to 13 and drove next day for 50 miles (one stop with engine off for an hour) and on way home I got the infotainment warning to park on level ground and use parking brake. Charged again then went to parts store to check battery and alternator.
    I saw in a post there are 7 sub codes w 3102.
    Anything else I can check?
    Any guidance on a good scanner thats not $500?
  2. PriusCamper
    PriusCamper Senior Member
    13,387
    5,409
    Pacific Northwest, USA
    Car Scanner (Elm) app
    But until you got a solid 13v (14.1v in ready mode) from a fresh charged battery chasing codes is a waste of time.
  3. pasadena_commut
    pasadena_commut Senior Member
    2,996
    930
    Southern California
    I wouldn't trust a battery that had been discharged to that voltage. It might charge up to something reasonable, but it is probably heavily sulfated.
  4. bisco
    52,760
    get a free 12v load test at most auto parts stores
  5. bisco
    52,760
