1. MichaelB126
    MichaelB126 Junior Member
    Phoenix
    Hey Folks.
    I've scanned the forum for my code and have gathered it can be a bunch of things.
    Here's what I've done recently changed fuel injector, had one sputtering. Changed plugs and coil packs.
    Had the battery and alternator tested at parts store, both are good.
    No other codes came back using Dr Prius.
    Used multi meter to check the voltage, was low at 5 volts. Charged to 13 and drove next day for 50 miles (one stop with engine off for an hour) and on way home I got the infotainment warning to park on level ground and use parking brake. Charged again then went to parts store to check battery and alternator.
    I saw in a post there are 7 sub codes w 3102.
    Anything else I can check?
    Any guidance on a good scanner thats not $500?
  2. PriusCamper
    PriusCamper Senior Member
    13,455
    5,430
    Pacific Northwest, USA
    Car Scanner (Elm) app
    But until you got a solid 13v (14.1v in ready mode) from a fresh charged battery chasing codes is a waste of time.
  3. pasadena_commut
    pasadena_commut Senior Member
    3,062
    951
    Southern California
    I wouldn't trust a battery that had been discharged to that voltage. It might charge up to something reasonable, but it is probably heavily sulfated.
    Brian1954 likes this.
    52,847
    get a free 12v load test at most auto parts stores
  5. bisco
    52,847
  6. MichaelB126
    Phoenix
    Borrowing a topdon AD500 scanner and battery charger with desulfating mode.
  7. pasadena_commut
    3,062
    951
    Southern California
    I'm highly dubious about desulfating modes for AGM batteries. Most of those charger modes are for conventional flooded lead acid batteries. Some of the chargers with pulsed desulfating modes claim to work on AGM, but you would have to wait weeks or even months to find out if it made a difference. Since the same manufacturers almost never provide any evidence to support those claims take them with a spoonful of salt. There are of course many anecdotal claims of success - just as there are with every brand of liquid snake oil.
    Edit. I wasn't sufficiently clear. DO NOT use a desulfating mode intended for a flooded battery on an AGM battery. Any of the high voltage or high current methods is going to damage the AGM battery as there isn't enough fluid on the plates to support those extreme conditions.
    #7 pasadena_commut, Jul 8, 2026
