Hood insulator replacement
Discussion in 'Prime Care, Maintenance and Troubleshooting' started by Aundrie, Aug 7, 2026 at 6:40 PM.
  1. Aundrie
    Aundrie New Member
    Midland NC
    Four Touring
    An animal chewed a hole in the insulating pad under the hood of my 2017 Prius Prime. I've been having trouble finding a replacement, even at the Toyota site. Am I using the wrong terminology? I know I could call a Toyota dealer, but I was hoping to get it a little cheaper.
  2. Mendel Leisk
    42,349
    You should do what you can to discourage rodents as well.
    Is the car garage stored, or is there a garage that could be cleared up enough to fit the car, that'd be worthwhile. Ensure it's secure too, all the doors tight sealing, and check for any other ways they could get in, doesn't take much.
    Top prevent them getting into cabin, remove the wipers, windshield trim and metal cowl, and cover the cabin air intake with galvanized steel anti-rodent mesh, with 1/4" spacing. Secure tightly with sheet metal screws (good to pre-drill pilot holes). Also good to mesh the engine air intake, to avoid them using it as a home. And the 2 exit vents below the hatch floor, in the rear corners. Removal of back bumper and installing mesh on the outside worked for me, with our 3rd gen.
    Also set up traps, acquire a cat, whatever works.
    A web cam that can detect motion is handy too, can give you feedback about their activity, means of egress.
  3. Aundrie
    Aundrie New Member
    Midland NC
    Four Touring
    I was mainly asking where I might find the replacement shield without going to the dealer.
    But thanks for the suggestions to prevent rodent damage. This is the first time I have had this problem in the almost 10 years I have owned the car. It has never been kept in a garage and there is no good option for that. I think the reason this rodent decided to occupy my car's heat shield this year is I had foot surgery a couple of months ago and the car was not driven for many weeks.
