1 million Prius' to be recalled. Fire hazard.
Discussion in 'Prime Main Forum (2017-2022)' started by schja01, Sep 5, 2018.
  1. stevepea
    stevepea Senior Member
    535
    581
    US PRIMES ARE NOT INVOLVED IN THIS RECALL.
    (not clear about Canada)
    The link to the PDF file from Toyota: https://techinfo.toyota.com/techInfoPortal/staticcontent/en/techinfo/html/prelogin/docs/cp/j1ttofaq.pdf
    states this:
    Why are Prius Prime vehicles not involved in this Safety Recall in the U.S ?
    The routing of the engine wire harness in Prius Prime vehicles distributed to the U.S. is different from Prius Prime vehicles in certain other markets. Therefore, Prius Prime vehicles distributed to the U.S. are not affected by the condition.
    So US Prime owners can relax about this :)
    Sorry I haven't been around much lately, some IRL stuff preventing me from getting online as much currently, but hopefully as things get back to normal I'll be more active again.
    ArcPrime likes this.
  2. Roy2001
    Roy2001 Active Member
    371
    158
    Sacramento, CA
  3. Elektroingenieur
    2,515
    3,284
    Three Touring
    Indeed. In the liftback Prius thread about this recall, I linked to (and @360texas kindly posted) Toyota’s announcement about the same recall in Japan, which includes an illustration of the area of the possible failure in the part of the engine wire harness that goes to connector C33 on the top of the inverter with converter assembly.
    The same connector exists on the Prius Prime and Prius PHV, but the wire harness design is different for the left-hand drive Prius Prime. On these extracts from the Location & Routing sections of the Electrical Wiring Diagrams, in which the front of the vehicle is at the bottom, I’ve highlighted connectors C32 and C33:
    On the Prius Prime, notice how the wire bundles for connectors C32 and C33 branch from front to rear, rather than branching from rear to front as on the right-hand drive Prius PHV and all models of the Prius.
  4. huskers
    huskers Senior Member
    2,544
    2,487
    Nebraska
    Is this going to be on the test?
    fneil likes this.
  5. Old Bear
    Old Bear Senior Member
    712
    1,050
    Boston, Massachusetts USA
    It's not just that, but in the diagram which you provided, only the LHD Prime lacks the L-shaped housing/shroud which appears in the other three diagrams.
    This photo was posted elsewhere:
    https://attachments.priuschat.com/attachment-files/2018/09/153029_IMG_0307.jpg
    I am still confused, but I just checked my VIN against the Toyota recall campaign database (updated thru 9/4) and it came back with no current recalls.
  6. EyePrime
    EyePrime Active Member
    268
    115
    Ottawa, Ontario, Canada
    2018 Prius Prime
  7. Trollbait
    12,543
    The announcement was just two days ago. Toyota's online systems may not be up to date for it yet.
  8. DustyPhoenix
    DustyPhoenix New Member
    US
    Moto G (5) Plus ?
