12V battery empty
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Peeto, Nov 25, 2016.
  1. Peeto
    Peeto Member
    123
    55
    Slovakia
    Hi guys,
    my wife just forget to turn off light inside the car for 2 days and car is dead, I can not start. This 1 min video helped me to turn it on again. Hoping it can help others like myself.
    52,849
    well done, thanks!(y)
  3. Peeto
    Peeto Member
    123
    55
    Slovakia
    30min before I was like I will ask here as I am total anti-tech guy regarding cars. Only "problem" with this solution, you have to bother somebody with car and cables to jump you in /if you do not have 2 cars at home/ and than you can recharge by driving for a while. But I was quite scary after reading some negative topics, dead batteries and so on, but nothing bad happend.
  4. Peeto
    Peeto Member
    123
    55
    Slovakia
    btw, Hi Bisco, how is your plug-in now? I have my first winter with prius and when I changed my tyres to winter ones + temperature around 0C my increased consumption is about 0.5-1l/100km ...not so bad
  5. bisco
    52,849
    i lose about 25% of battery capacity, so i'm down from 16 miles of ev to 12. mpg's also drop about 20%. reformulated gas, bad weather and etc.
    Peeto likes this.
  6. Neohippy
    Neohippy Active Member
    220
    201
    Clearwater,Fl
    2013 Prius Plug-in
    I thought the car was only rated for 11 EV miles?
  7. bisco
    52,849
    rating is by a standardized epa test. ymmv. most of my driving is local, 30-40 mph. some get more, some get less. precipitation and a/c use also reduce distance.
  8. Peeto
    Peeto Member
    123
    55
    Slovakia
    that is still impressive, I would be satisfy if I have PIP. The local car service guys from my small village never saw hybrid, they come with their car, I told them, guys, just connect your car to my battery here and here /from video/ and they told me ok, now try turn engine on. I told them, thanks guys you can disconnect, car in on now. they answer me, no something goes wrong, your car is still off/does not hear engine/ :) so we had a fun a bit :) ..its nice to live on small village :)
    Tideland Prius and bisco like this.
  9. Mendel Leisk
    42,343
    Your battery was near-dead, but with a jumpstart and a bit of driving around everything is fine now?
    I would get it checked with a digital load tester. I'd suspect it's Cranking Amps are compromised, that the battery is marginal at best, and should be replaced soon.
  10. Peeto
    Peeto Member
    123
    55
    Slovakia
    not really. no sign of anything. I drive 30min to recharge it. And since than I drive once per 2 days and everything is OK. Battery is 5 year old. It would be really bad if u need change batteries so soon or if they die after recharge.
  11. fuzzy1
    10,706
    For the 12V battery, 5 years old is at or near end of life in most U.S. climate zones.
    And because the Prius 12V system charges very slowly, 30 minutes is much too short, it takes many hours. See Patrik Wong's post at #10 of this thread: Dead battery. Again. | PriusChat
  12. Mendel Leisk
    42,343
    And, it's not 30 minutes on a dedicated charger, it's 30 minutes "driving around".
  13. fuzzy1
    10,706
    I'd describe the Prius internal 12V inverter as a 'dedicated charger'. But a very slow one, meant to be good for full time use. The faster home or bench chargers are meant for temporary use, so can charge faster without cooking the battery.
  14. Peeto
    Peeto Member
    123
    55
    Slovakia
    thanks guys, I read all your posts. Nothing happend from this incident. It is freezing now in my country. Even car looks perfectly fine, I will better change the battery after winter, or let it check by toyota service guys. I have much less experience, and if u say, battery is near dead, i have no reason to not believe you. If anything will happend, i will report here to share experience...
  15. Mendel Leisk
    42,343
    Yeah, we're all counting on your battery dying. Don't let us down.... No no no: kidding, hope you make it through winter. :)
  16. Peeto
    Peeto Member
    123
    55
    Slovakia
    :) i think of your posts, every morning, especialy when it is minus degrees celsius :) .. I perhaps have some chances, that previous owner change battery already once as I bought car as 5yrs old :)
  17. fuzzy1
    10,706
    There is usually very little reason to change the battery just after winter. The warming weather will extend its life. It is just before and during winter that most replacements are needed.
    But if the charge is simply low, an ordinary 12V battery charger should take care of it, at much lower cost than replacing it. An ordinary battery check by the Toyota service guys will not charge it, they will merely tell you if it needs replacement. While they could also charge it for you, that is a separate step from testing it, and you would have to ask (and maybe pay for) that step.
    Peeto likes this.
  18. Peeto
    Peeto Member
    123
    55
    Slovakia
    Survived days after jumpstart: 10 no external charging, only regular drive... not dead, yet. :) -8 Celsius here..
  19. Mendel Leisk
    42,343
    Finally below freezing here, this morning, and light snow (first of the year). But we are on the edge of that great temperature regulator: the Pacific Ocean. :)
  20. Peeto
    Peeto Member
    123
    55
    Slovakia
    -32 celsius today morning :D , battery still working (y)
    Mendel Leisk and bisco like this.
