12V Battery
Discussion in 'Prius v Main Forum' started by borna, Jun 26, 2023.
  1. rjparker
    rjparker Tu Humilde Sirviente
    11,101
    6,966
    Texas Hill Country
    In the first post the answer was definitive. Bad battery.
    First post again, the car was driven far enough to ensure a full charge and three days later it could not Ready a Prius.
    The only thing that could have aggravated a weak off brand battery is an excessive parasitic draw. But no effort to get that test run. Good enough for me.
    It needs a battery. That is a given. Do yourself a favor and get a quality unit like the Toyota oem.
    #61 rjparker, Aug 27, 2023
    Brian1954 and jerrymildred like this.
  2. jzchen
    jzchen Newbie!
    3,316
    1,022
    Arcadia, CA
    borna likes this.
  3. borna
    borna Junior Member
    venice
    2014 Prius v wagon
    Thanks for your reply , definitely will not buy from Batteries plus , it's not even a year . It seems the battery does not hold the charge and I wanted to make sure there is nothing wrong with the charging system
    52,855
    i keep mine on a $30. noco maintainer when i'm not going to be driving much. and if there were a parasitic drain and i didn't want to deal with it, it would solve that issue as well.
    Air_Boss and borna like this.
  5. borna
    borna Junior Member
    venice
    2014 Prius v wagon
    Thanks bisco, i just bought one of these maintainer
  6. bisco
    52,855
    well done
  7. Air_Boss
    Air_Boss Senior Member
    4,259
    1,197
    New Yawk
    The ‘fleet’ all have LED charger/battery SOC indicator pigtails. One NOCO covers them all.
    jzchen and borna like this.
  8. jerrymildred
    jerrymildred Senior Member
    11,517
    14,167
    Tampa, FL
    Good choice. I've used them for decades. They are what Tampa Hybrids use for overnight when inventory cars come back from detailing.
    borna likes this.
  9. Mr.Greenjeans
    Mr.Greenjeans Junior Member
    40
    Central Pennsylvania
    2017 Prius v wagon
    yes, THIS
    - rotating through them so they each get a full charge once a month (whether they need it or not ;) is perfect.
    It can take hours to get a battery happy with a full charge. Most driving patterns just don't attain this, even if you believe the DC-DC inverter can get it there.
    Another option is a small (7-10 watt) solar panel. It wouldn't even need a charge controller.
    borna likes this.
  10. borna
    borna Junior Member
    venice
    2014 Prius v wagon
    "Another option is a small (7-10 watt) solar panel" that is perfect , where would you get these type of panels ?
  11. Mr.Greenjeans
    40
    2017 Prius v wagon
    Harbor Freight, off the shelf
    borna likes this.
