12v fan
Discussion in 'Prius v Accessories and Modifications' started by workingdogs, Jun 25, 2014.
  1. workingdogs
    workingdogs New Member
    corvallis,or
    2014 Prius v wagon
    I have a 12v plug in fan that uses up to 3 amps power. I want to run the fan for extended periods ( up to 8 hours a day) plugged in to the cargo area. I admit to not knowing much about the Prius electrical system. My question is, is it OK to have the car on ready and run the fan all day? I attend dog trials where I need to crate my dogs in the car. I keep the hatch and windows open, but want the increased air flow. Also, how long can you run the A/C while the car is parked?
  2. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    So long as your car is Ready, you can run a fan or A/C all day. As the batteries discharge, the engine will start and recharge them.
  3. ETC(SS)
    7,425
    Concur.
    Just make sure that you have a few gallons of fuel in the tank.
    Actually?
    Toyota has done most of that for you already, since your car effectively has about a 2-gallon reserve.
    Your car will be fine.
    Just remember that the ICE (gas motor) will be cycling on and off, so you'll want to avoid parking in grass or over other combustible material.
    Enjoy the show!
    Thanks for not leaving the pooches in a hot, parked car all day. ;)
    tanasit likes this.
  4. rdgrimes
    rdgrimes Senior Member
    1,740
    448
    New Mexico, USA
    2018 Prius Prime
    If you use the mechanical key, you can even lock the car in ready mode with the A/C running. I've done that for my pups before. Just be aware that on a really hot day, the traction battery with discharge in a few minutes, and the ICE will run frequently to re-charge and to keep itself warm.
  5. JC91006
    16,905
    8,631
    Just make sure you leave a sign on your Window that says "ac is on". When people can't hear your engine on and see dogs inside, they'll rescue them by breaking your Window
    SM-N900P ?
    Onlooker and tanasit like this.
  6. budrow56
    budrow56 Junior Member
    45
    I would like to change my own oil on my 2012 toyota prius v but the dealer said there is a tool that I need that costs about 80 dollars . Can anyone please tell me that this tool is.
    Thanks
    iPhone ?
  7. Mike500
    Mike500 Senior Member
    2,593
    767
    This is the official and the best one.
    Toyota - OIL FILTER WRENCH Part Number: 09228-06500-02
  8. ETC(SS)
    7,425
    Reason # 497 for me being a Toyota driver but not a Toyota owner. ;)
    Don't ever take your car back to that dealer.
    There is a substitute for the above listed wrench floating around somewhere on the forum. Watch some YouTube Videos or read some "how-to" posts in this forum.
    Whether or not you're going to do your own maintenance or have it done for you it is very important that you check your oil regularly.
    I'd be lying if I said that I do this every fill-up, but I guarantee you I'll do so at least semi-regularly (like: every other fill-up.)
    Also.....
    Check with Amazon or Ebay and start shopping for air filters. You can get the OEM brand cheaper there and there are videos on this forum for replacing both the cabin and the engine air filters.
    I don't remember what the periodicity is for these with Toyota, but I change mine with every other oil chance - which for me is about 10,000 miles.
    I'm thinking that about $100 worth of tools and a good set of ramps (I use the $40 Rhino ramps) will allow for you to do all of the preventative maintenance on this car out to about 120,000 miles.
    Good Luck!
  9. Mike500
    2,593
    767
  10. tanasit
    tanasit Member
    399
    60
    Philadelphia
    I do produce shopping and always leave the AC on when I stop. The very first stop, the traction battery keeps the AC on for over 15 minutes (battery gauge is almost full). When the battery gauge goes down to 2, the engine will kick in and once it goes up to 3 bars, the engine stops again and cycle through like this. BTW, I only use ECO mode, so the fan speed is not as high as in POWER mode and I set AC at 72 degree on AUTO.
    Mike500 likes this.
