12V Switched and constant power?
Discussion in 'Prime Accessories and Modifications' started by jessetoedtman, Nov 5, 2018.
  1. jessetoedtman
    jessetoedtman Junior Member
    25
    San Diego
    Has anyone found switched and constant power in their 2017 Prius Prime? I ask because I cant seem to find within the fuse box. I am installing a dash cam and would like to set it up with a parking mode which requires switched power.
  2. Elektroingenieur
    2,515
    3,264
    Three Touring
    The Electrical Wiring Diagram (more info) is the best source for this information. You might find some of these previous threads helpful, too:
    Installing dash cam behind rear view mirror? | PriusChat
    Best way to hide dashcam cable? | PriusChat
    The A Pillar | PriusChat
    Fuse Size for Fuse Tap for Dash Camera | PriusChat
    Has Anyone Installed a Dash Cam? | Page 3 | PriusChat
    Some relate to the fourth-generation Prius, which is similar but not identical to the Prius Prime.
    evpv and kaynin like this.
  3. illumiN8i
    illumiN8i Active Member
    178
    139
    Grand Rapids, MI
    2018 Prius Prime
    If you have prime advanced with the garage door opener auto dimming mirror, constant and switched power is available there. I found an adapter that allows you to tap in.
    Not sure if that same power jack exists on non-Advanced. You can easily pop off the cover and check.
