2001 Prius A/C / Heat noise in interior
Discussion in 'Generation 1 Prius Discussion' started by statultra, Jul 27, 2017.
  1. statultra
    statultra uber-Senior Member
    798
    31
    Edison,NJ
    2001 Prius
    My 2001 is making noise whenever i have on the air, it sounds like something is flapping, i would then turn up the temperature and the sound would change to a clicking type sound.
    Where is the part for this? Should I spray contact cleaner on the temp sensor located near the key?
  2. Brian in Tucson
    Brian in Tucson Active Member
    981
    453
    Tucson AZ
    2003 Prius
    Are you missing any baseball cards?
    Spraying the temp sensor wouldn' t do anything
    EddieAtl likes this.
  3. ChapmanF
    19,058
  4. Brian in Tucson
    981
    453
    Tucson AZ
    2003 Prius
    SERVO?!!!
