2002 Prius catalytic converter was stolen.
Discussion in 'Generation 1 Prius Discussion' started by Thomas Pradetto, Sep 27, 2021.
  1. Thomas Pradetto
    Thomas Pradetto New Member
    Seattle
    2002 Prius
    Am I able to replace the catalytic converter with a straight pipe on a 2002 Prius? If so, what are the negative effects?
  2. dabard051
    dabard051 Tinkerer-in-Charge
    262
    98
    Rochester, NY USA
    2002 Prius
    Mechanically, yes. Electrically and pollution control wise, no. The emissions control system consists of 2 parts: the actual catalytic converter, and a hydrocarbon removal system (known as HCAC) which consists of a valve and capture container subsequent to the second O2 sensor in the exhaust system. A cat converter (exact fit) from Eastern Catalytic will solve a missing cat converter (Eastern Catalytic #40544, about $250 from RockAuto) but the HCAC valve and capture tube must be recovered from a scrapyard.
    The OEM cat converter is about $1200 from Toyota (part #17410-21261), has the capture tube but does NOT contain the pneumatic actuator assembly (Toyots Part # 17230-21010) which actuates the HCAC capture valve.
    See these link for diagram sof the system and a possible source:
    https://partsbarn.sunnysidetoyota.com/oem-parts/toyota-catalytic-converter-front-1741021261
    2003 Toyota Prius Actuator assembly, with bracket. Exhaust, engine - 1723021010 - Genuine Toyota Part
  3. babbles
    babbles Junior Member
    38
    seattle
    2001 Prius
    just had mine stolen 10/15 put parts on order through Toyota and it is $1860 in this Seattle area, had just got it OEM on 9/17 and waiting to see if progressive will help out, (full coverage) also ordered a anti theft plate through them as well for $240,
    my choice was to buy another car (started to get a leaf) or another cat and the cat was the better option
  4. jamesprius
    jamesprius Member
    142
    17
    San Jose, California
    2001 Prius
    I
    hey babbles,
    Do you have the part numbers in your order? I'm trying to put together a list of all the part numbers, there seems to be a lot.
    Also what did they give as an ETA for the parts to arrive?
  5. babbles
    38
    seattle
    2001 Prius
    Add $650 for labor plus tax and this price includes an anti theft shield,
  6. babbles
    38
    seattle
    2001 Prius
    pic
    jamesprius and WHCSC like this.
  7. jamesprius
    jamesprius Member
    142
    17
    2001 Prius
    I
    Thanks babbles. Only 3 days wait for the cat? That is pretty quick.
    In addition to your quote. I think there might be a few more.
    Actuator Assembly 1723021010 (this is attached to the cat, surprised this was not on your quote)
    Actuator Assembly Hose 1734821010
    o2 sensor 89465-47060 (mine was cut but you might not need this if they just detached it)
    This seems to be next to the actuator
    Protector, Exhaust P. 1752321010
    spring air control 1733821010
    3 nut spoiler (rear, upper, lower) 9017906007
    2 hangers 1756521010 (mine was cut, but yours might be still intact)
  8. jzolot
    jzolot Junior Member
    Chicago, IL
    2001 Prius
    Mine was cut off my 2001 last Thursday morning. It was a very smart scumbag and he knew that an early model Prius has possibly the best emissions control system consisting of two precious metal-filled parts that he could cut off my jacked up car in about 3 minutes. It’s all on my neighbors security video.
    I took it to a neighborhood muffler shop, big mistake. He put in two new replacement Magnaflows instead of an HCAC unit about which he seems clueless. Now, I’ve got P1427 code and the guy says he doesn’t know where one of the sensors plugs in. And I paid him $900.
    I saw on here a part called “Stainless Steel Weld On Bung” on eBay for around $10. Do I need to have this installed and will that solve the CEL problem?
    I’m not in California, but I will need to pass an emissions test next year and that CEL won’t do. Any suggestions are more than welcome!
  9. nimblemotors
    nimblemotors Re Member
    117
    37
    Sacramento
    2002 Prius
    You can NOT buy just a HCAC unit without buying the whole cat from toyota. At $900, you pretty much are close to the $1200 to get the right OEM setup.
    Sorry you didn't check in here first !!
    See my post on how to "trick" the computer to think it has a HCAC unit and get rid of the 1427 code.
    I real visual inspection will recognize its missing in the exhaust and fail visual inspection.
  10. Burdy
    Burdy New Member
    Seattle
    2003 Prius
    My catalytic converter was stolen off of my 2003 Prius in Seattle area last week. Current quote is $1,650 for converter, plus another grand for O2 sensor, some other thing I’m forgetting (vacuum something?), a protective shield, labor and taxes. $2,800 feels absolutely ridiculous to spend on a 2003 vehicle with 170k miles on it, but the market right now doesn’t seem friendly to buying other reasonably priced upgrades. Am I missing anything? Is this just the normal cost of repairing post catalytic converter theft right now?
  11. nimblemotors
    117
    37
    Sacramento
    2002 Prius
    You really just need to buy the replacement cat from Toyota, which is currently priced at about $1200,
    17410-21260 Genuine Toyota Front Exhaust Pipe Assembly
    Shipping costs involved here, check with your local toyota dealer.
    This is what gets stolen and needs replaced. Everthing after this is just pipe and might be still on the car.
    Now even $1200 is a lot for a car that sells for $2500 right now (just sold one of mine),
    If you can be 'illegal', you can get it fixed for much less.
    You can get a fake gen2 cat off ebay for $100 which bolts on, and then run some pipe back to the muffler connection. and the car will run just fine. but you will get a p1437 code from the missing vacuum controlled HCAC unit, and so you get a check engine light. I have a hack to fix that on this forum.
    But it will still not pass a real smog check.
    #11 nimblemotors, Nov 21, 2021
    Burdy likes this.
  12. fuzzy1
    10,691
    No smog checks here anymore, so that might open up some cheaper aftermarket solutions.
  13. Soren Lorensen
    Soren Lorensen New Member
    Seattle, WA
    2001 Prius
  14. sandy11246
    sandy11246 Member
    71
    39
    kansas
    2003 Prius
    Once after market cats are installed, purchase a cruise control from a Honda Goldwing ($7.25 on ebay). Connect vacuum pod to pressure sensor line going to HCAC (in engine bay near throttle body), Check post related to this on Prius Chat. Vacuum pod will operate and turn CEL off. Had to solve this issue after Cats stolen. Works Great.
    ammdb likes this.
