2005, 161,000 miles, red triangle and problem notice
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by spagirl76, Aug 16, 2013.
  1. spagirl76
    spagirl76 Junior Member
    Ft. Myers, FL
    I'm an original owner of the car above and haven't had any issues (except the paint peeling).
    After leaving the car sitting for 12 days while I was away, I returned and the car was fine the first night.
    Second day the triangle came on, which I've never seen. After taking it my personal mechanic (who I trust), he recommended Toyota and then call him with the diagnosis. Our Toyota was recently taken over by Autonation and twice they've lied and tried to oversell to me. My mechanic has seen a lot of this lately so he and his wife look out for their customers.
    So, Toyota says it is the main battery and will run me approximately 3500.00. I was not prepared to spend this, but wanted to keep the car for my now just turned 16 year old.
    After learning about this forum, I've done some research and think I found a place that will replace the battery, test it, warranty it for 1-3 years and would be under 1500.00 (likely I need the drive belt and water pump changed, too).
    Seems worth it to me. Any suggestions?
  2. Eclipse1701d
    Eclipse1701d Prius Enthusiast
    645
    224
    Nature coast, Florida
    Three Touring
    $1,500.00 for the battery and a few hundred for the water pump and belt and you're good to go! I would do it, as opposed to being saddled with a new monthly payment....
  3. nh7o
    nh7o Off grid since 1980
    1,686
    340
    Hawaii
    Please have Toyota tell you the codes that they read from your car, and list them here for better advice. How many miles on the car, and what is your location?
  4. wjtracy
    wjtracy Senior Member
    11,374
    3,609
    Northern VA (NoVA)
    ..the thing is if you left your car sitting 12 days the smaller 12-v battery could take a hit due to SKS system draining it.
    kinglew likes this.
  5. Joe 26
    Joe 26 Member
    242
    42
    Columbus, Ohio
    I agree with wjtracy. Check the smaller 12v battery before spending on a new traction battery. If you search this site there are DIY instructions on how to do so.
  6. spagirl76
    Ft. Myers, FL
    So now I'm at 207,000 miles, with the teen daughter driving it around town to work and college. I did end up replacing the HV battery a couple years ago for 1200.00 (refurbished w/ 3 year guarantee). Car has been great. For 6 months we've had the ABS and brake light on which multiple mechanics told me is fine to drive with while Toyota said it would be 3000.00 to fix 8 months ago.
    Today we took it to the mechanic as the red triangle came on with the engine light. The fuel tank has gas but is not registering it and the last cube keeps blinking.
    Mechanic advised leave it and monitor gas usage or replace for 500.00, but it's ok to drive.
    Opinions? We are trying to hold off buying another car for a bit longer.
  7. JC91006
    16,896
    8,629
    Try disconnecting your 12v battery for a minute and see if it resets
  8. spagirl76
    Ft. Myers, FL
    It's at the dealer today getting the actuator replaced (yes, warranty item!!:) and they said the main battery (3100.00)is missing some cells and my water pump needs to be replaced (530.00).
    I found a business that will come to you and replace the battery for 1000-1700, depending on which warranty you go with and since I did that once already and got 4 years out of it, I'll try it again.
    My regular mechanic will recheck the water pump (dealer has told me this needed replacing urgently every time it's had a check in the past 3 years, then my mechanic says no, it's fine).
  9. JC91006
    16,896
    8,629
    regarding the rebuilt batteries....these are most likely rebuilt with 2004-2009 failed batteries. So at 2016, your 4 year old rebuilt was done in 2012 right? The oldest that battery could have been in 2012 was from a 2004 pack that was 8 years old. So if you were to get a rebuilt now at 20016, you could end up with a 12 year old battery pack from 2004 modules. It's highly likely you won't get 4 years of reliable service from that battery.
    There have been many posts on here regarding rebuilt batteries with different option packages and warranties. It seems no matter which package you choose.....you will most likely get the same battery, you'll just pay more for the more expensive package. You don't have the expertise to know what the difference is from battery A, B, or C. Most battery rebuilders are counting on your lack of battery knowledge and providing you with different options to separate you from you money.
  10. spagirl76
    Ft. Myers, FL
    I had the battery replaced on Saturday (unlimited mileage replacement) and the water pump repaired.
    Now the car turns on but stays in neutral. The mechanic is trying to recharge the 12V and see if that is the issue.
    Another Prius person recommended the power button could be worn or a sensor on the brake.
    Anyone have something similar?
  11. JC91006
    16,896
    8,629
    If it only goes into neutral, then the car is probably not in ready mode.
    Hopefully the 12v is your problem
  12. spagirl76
    Ft. Myers, FL
    The mechanic disconnected and retried the 12V and charged it. Speedometer doesn't come on and car won't shift to anything except neutral. He's tried multiple times and can't get the car going.
    A couple times in the past year the display went out but Toyota said it wouldn't effect operation of the car.
  13. JC91006
    16,896
    8,629
    If the speedometer is out and you made a complaint that's documented by Toyota, then you may be able to get it covered under a special extended warranty
    jeff652 likes this.
  14. spagirl76
    Ft. Myers, FL
    I think it was the middle panel I told them about but I'll circle back with Toyota. Our local dealer has lied so many times I'm not keen on going to them for anything.
    I'd really like to get the car running again this week. I've been pretty happy with Pep Boys lately, but need the car to turn on and drive (it did once this morning for about 2 minutes before the red triangle appeared).
  15. kinglew
    kinglew Member
    318
    49
    ny
    2020 Prius Prime
    Time for hybrid battery
  16. spagirl76
    Ft. Myers, FL
    The main battery was replaced Saturday and car ran for about two minutes. Stayed at the mechanics so the water pump could be replaced Monday. Since then the car will turn on but won't drive. Speedometer doesn't come on and stays in neutral. Codes are C1259 and C1310.
  17. spagirl76
    Ft. Myers, FL
    Any other ideas for getting the car at least driving? Codes are C1259 and C1310.
  18. JC91006
    16,896
    8,629
    C1259= HV System Regenerative Malfunction - code can be triggered by a "no start" situation.
    C1310= HV System Malfunction - code can be triggered by a "no start" situation.
    Do you have fuel in the car? How did this battery swap happen with the car only running 2 minutes?
  19. fotomoto
    fotomoto Senior Member
    5,639
    3,815
    So. Texas
  20. spagirl76
    Ft. Myers, FL
    Just saw my mechanic and we are wondering if the ABS/Actuator work done at Toyota missed a brake sensor as the lights are all on for ABS. The car was driven from Toyota to the mechanic (3 miles) where it had the main battery replaced, after a week (delay with original company I had planned to use) and then driven for 2 minutes to make sure the battery was good. The car stayed at the mechanics since the water pump also needed to be replaced, which he did on Monday. Car continues to turn on w/ radio etc. but same lights as when I dropped it at Toyota 2 weeks ago. I called Toyota and they said have it towed back. We'll see what they say.
