2005 Prius Making Noise
Discussion in 'Gen 2 Prius Main Forum' started by sthomasaz, Jun 27, 2016.
  1. sthomasaz
    sthomasaz Junior Member
    Scottsdale Az
    It sounds like it is coming from the Hybrid Drive. It is really loud. I can hear it as I drive down the road. The best I can figure out from reading forums is it might be some time of coollant pump the drive uses. It starts as soon as I open the door before I start it and it will keep doing it after the car is turned off.
    I've posted a video with audio on youtube
    : Any suggestions and what a repair might cost would be greatly appreciated.
    52,635
    sounds like your brake accumulator is leaking.
  3. ILuvMyPriusToo
    ILuvMyPriusToo Senior Member
    780
    518
    Outside Philly, PA
    2024 Prius Prime
    No warning lights on the dash?
  4. sthomasaz
    Scottsdale Az
    Nope. No codes at all.
  5. bisco
    52,635
    i would ignore it, if it's working okay.
    Data Daedalus likes this.
  6. Data Daedalus
    Data Daedalus Senior Member
    1,025
    1,185
    Wembley, London
    My Prius makes that noise as soon as I open the driver's door, first thing in the morning.
    After that, only sometimes, when braking. Once the vehicle has been running for a while, I no longer hear it. However, after I've parked, I'll hear the same noise after I've locked it and I'm walking away. Lots of noises in fact. Usually short ones, but not for very long.
    If it's going on continuously non stop then it might be a problem, otherwise, my Prius has been doing this for three years - and no problems.
    iPhone 6s +
    #6 Data Daedalus, Jun 28, 2016
  7. sthomasaz
    Scottsdale Az
    It seems abnormally loud and it's pretty constant. I've had it for a year and it is a relatively new thing so I am assuming it is something failing.
  8. bisco
    52,635
    probably the brake accumulator, needs recharging more often when leaking.
  9. JC91006
    16,896
    8,628
    You need to get that checked, it should have dtc, you just need a code reader that can read prius codes
  10. edthefox5
    edthefox5 Senior Member
    10,096
    4,836
    Clearwater, Florida
    Thats the brake vacuum motor. if it comes on briefly and then shuts off that's normal. Since the Prius engine shuts off at every stop there's no way to get brake assist vacuum from a engine thats not running so there's a assist motor that produces it. You can force it on by just pushing on the brake pedal a few times.
    You must have just bought the car as you will hear that sound alot. Almost every time you step on the brake. If vacuum is leaking from the ABS unit it will run that motor continuously and throw a Master Caution Red Triangle on the dash. Hope you never see that light as the ABS unit is very expensive. You'll know it too as the brakes will be bad too.
    By the way what are you calling the "Hybrid Drive"?
    #10 edthefox5, Jul 2, 2016
    Data Daedalus and aaroncv3 like this.
  11. Data Daedalus
    1,025
    1,185
    Wembley, London
    The Prius is an otherwise very quiet car, especially when stopped in traffic. So quiet, every sound you hear will sound quite amplified several fold. Particularly if you have good hearing! The brake vacuum pump noise will sound even louder if you're standing parallel with other traffic at the lights, in congestion or in your garage with the front windows down.
    Regarding how quiet this vehicle can be in stealth mode when stationary, I've lost count of the number of times I suddenly believed I had a major mechanical malfunction - only to realise it was the unfamiliar sound of the engine if some badly maintained engine of a car or truck to the side or the rear of me. Or even further behind. You brake and hear a horrible squealing noise......repeatedly, in congested traffic. It takes a while to realise it's someone else close by, and not you. Even a badly surfaced road can generate scary loud noises from your drivetrain.
    So, unless you get a red triangle warning, you're more than likely perfectly okay. The noisy brake vacuum pump is one of the Prius II's idiosyncrasies. Reminds me of the landing gear being deployed on an aircraft. I wonder if the development engineers also did THAT on purpose?
    iPhone 6s +
    edthefox5 likes this.
  12. wirelessjava
    wirelessjava Member
    105
    23
    Union City, CA
    I have a 2005 prius, and I know exactly what the problem is. The problem is to do with the circulation of the coolant. The part that is not properly circulating the coolant to both the car and the hybrid battery.
    If you do not fix this soon it will cause your hybrid battery to fail because it does not cool down the hybrid battery properly and the engine. You might be out of warranty on this part but you should replace it. I forgot the code that it shows up as
  13. wirelessjava
    wirelessjava Member
    105
    23
    Union City, CA
  14. JC91006
    16,896
    8,628
    P1121 is not related to the battery at all. It's like you saying you didn't eat dinner and your car ran out of gas.....absolutely no relation
  15. Eastside
    Eastside Member
    129
    82
    NorthVirginia
    "P1121 is not related to the battery at all. . . . "
    . . . . I'll second that comment.
    My 2005 makes the same noise now and then.
  16. sthomasaz
    Scottsdale Az
    I took it to a Prius mechanic and he said that it was Brake Hydraulic Actuator Assembly. To replace it, it would be $2019 for parts and $440 for labor.
    I don't mind the labor portion, but is there a cheaper way to get the part or parts?
    Again, I'm not getting any error codes or red triangles yet. I've had the car for a year. This sound is definitely different than normal.
  17. Patrick Wong
    18,210
    6,515
  18. JC91006
    16,896
    8,628
    The extended warranty probably needs specific codes to prove failure. Just like a weak battery wouldn't qualify for warranty until p0a80 is present
    Patrick Wong likes this.
  19. Patrick Wong
    18,210
    6,515
    Yes.
  20. ILuvMyPriusToo
    780
    518
    Outside Philly, PA
    2024 Prius Prime
    Maybe some documentation of the issue from a dealer will help if codes show later . . . Good luck!
