2005. Problem. All warning lights are on. Wont start.
Discussion in 'Gen 2 Prius Technical Discussion' started by Tomish Talbish, Apr 23, 2017.
  1. Tomish Talbish
    Tomish Talbish New Member
    Charlotte
    IMG_1862.JPG IMG_1863.JPG I stick the key in. Then on the main display screen it says problem. Then a red light appears with a car and ! Over it. Then the check engine light is on. Abs. Vsc. Maint reqd. Red triangle with !. Circle with (!). Traction control. Looks to me all the lights are on. Check the battery in the back seems to be fine. Any suggestions? Or is there a way to start the Prius manually?
  2. Sandollars
    Sandollars Prius Maven
    134
    157
    SoCal
    The Red triangle with the ! indicates a general fault in the Hybrid system. Sounds like a tow to the dealer... Sucks.....
  3. Tomish Talbish
    Charlotte
    Thank you for the quick response. That's what I was afraid of.
  4. ericbecky
    ericbecky Hybrid Battery Hero
    4,452
    3,359
    Madison, Wisconsin
    What makes you think the 12v is fine?
    Testing with a voltmeter under load, or with a battery analyzer might be a good idea.
    Get the codes read and report back here.
    Then we can better help point you in the right direction.
    Tomish Talbish and Raytheeagle like this.
  5. Tomish Talbish
    Charlotte
    I used this bad boy. I don't have a code reader. I'm trying to avoid towing it to a dealer or mechanic. Maybe there is a restart switch? But ultimately you're telling me the best option is towing and getting the codes read. Could it be an oil problem?
  6. ericbecky
    4,452
    3,359
    Madison, Wisconsin
    That looks like a nice charger.
    Does it actually test battery health as well?
    If not then you may want to check voltage while the car is under load. (Using a voltmeter or other test).
    If you have a few days to wait, you could order a Bluetooth OBDII reader, and download the Torque app to an Android device. Cost you less than $25 via Amazon and you'd have it quickly.
    Then you could scan the car yourself. Cheaper than towing it. Or having mechanic or dealer scan it.
    Low oil can make the car throw codes. But you can check the oil level yourself. Do some Google searches if you are not sure how to do it. Refill with the oil marked in your oil filler cap.
    Feel free to call me if you have any questions in the meantime.
  7. Tomish Talbish
    Charlotte
    Yeh it tests battery health too. The battery is fine. I'm taking the day off today to get this resolved. Unfortunately I don't have a few days. Or the Amazon idea would be perfect. I'm ordering one any ways to have on hand. I really appreciate your time and your responses. God Bless you. I will keep you informed on the progress. Or what they say.
  8. wjtracy
    wjtracy Senior Member
    11,374
    3,609
    Northern VA (NoVA)
    Tomish Talbish likes this.
  9. ericbecky
    4,452
    3,359
    Madison, Wisconsin
    Guessing what's wrong from far away is a hard task.
    If I were stuck in an isolated location with no access to a scanner, could eventually figure it out.
    But getting a quick scan saves hours of time and keeps you headed in the right direction when trying to diagnose.
  10. Tomish Talbish
    Charlotte
    Codes P0AA7, C2300, C2318
  11. Sam Spade
    Sam Spade Senior Member
    2,036
    1,024
    2017 Prius c
    No it does NOT "test" anything......beyond making sure the battery is not a dead short before trying to charge it.
    You NEED the services of a shop.
  12. Tomish Talbish
    Charlotte
  13. Tomish Talbish
    Charlotte
    Isolation vault? 1800$? They're trying to get me I feel like. He's 90% sure that's what it is...
  14. Sam Spade
    2,036
    1,024
    2017 Prius c
    You also need to know that a failing 12 V battery can throw all the internal computers off.......so that they spit out "trouble codes" that may have nothing to do with the actual problem.
    The 12 V battery is a critical component and needs a proper test (or replacement if it is old) before you waste your money chasing ghosts.
    But you don't have to take my word for it. Just do a search on here for "battery". About a million matches will come up.
    Split about half and half between the 12 V one and the HV hybrid one.
  15. Tomish Talbish
    Charlotte
    Thank you, this diagnostics just set me back 100 dollars. You think I should just head over to auto zone to check the battery?
  16. biglew8
    biglew8 Active Member
    170
    114
    Seattle
    I found this from searching on PriusChat:
    "DTC C2318 does imply that 12V bus voltage is low, which may be due to a failing 12V battery. Since that is the cheapest and easiest item to replace, I'd suggest starting with that." - @Patrick Wong
  17. WilDavis
    WilDavis Senior Member
    2,493
    2,155
    49
    In your first pic, the display seemed to show nothing in the state-of-charge (SoC)...???
  18. Mendel Leisk
    42,343
    Assuming you mean the 12 volt battery: I would suspect the dealership already checked it, but who knows. If you want to be sure, yeah try auto zone, assuming they have digital load testers.
    The charger you're using: how old is it, and is it capable of charging at lower amperage rate?? If you look in owners manual I think you'll see max charge rate recommendation around 3~4 amps. Also, I would highly recommend to get an up-to-date smart charger, in the 3~4 amp range. I use a couple of CTEK's, a 3300 and a 4.3, fwiw.
    Also, you can do a rudimentary check of the 12 volt by checking the voltage with a digital volt meter. For more in-depth test, something like Solar BA5 will do digital load test; it's prosumer level version of what Auto Zone might have.
  19. WilDavis
    2,493
    2,155
    49
    Simplest way to test 12V AuxBattery is to switch on all lights and see if they dim significantly as the load is increased.
    Next simplest way:
    - Without brake pedal, press the Power button once and release to enter ACC mode
    - Press and hold the MFD Info button, then turn the headlights on and off three (3) times to enter Maintenance mode; release Info button
    - Press “Menu” (on screen)
    - Press “Display Check”
    - Press “Vehicle Signal Check” - the battery voltage is shown and should be about 12.4 to 12.8 Volts (normal for an unloaded battery)
    - Again without brake pedal, press Power button and release to put a current load on the battery - the voltage should stay above 12.0V (if less than 12.0V the battery is not well, or there is a fault or unusual load somewhere)
    - Press brake pedal and press Power button once to enter "Ready" mode - the battery is now charging at about 14V (if less than 13.6V or more than 14.4 there may be a problem with the charging circuit)
    - Turn car OFF to leave Maintenance mode
    #19 WilDavis, Apr 25, 2017
  20. Tomish Talbish
    Charlotte
    Off to auto zone now, maybe a new battery?
