2006 Hybrid won't start :(
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Megan Sostre, Jun 26, 2015.
  1. Megan Sostre
    Megan Sostre New Member
    Cleveland OHIO
    hi guys,
    I have a 2006 Prius hybrid that will not start. A few days ago I was driving in a storm, parked my car for an hour and when it was time to leave the car wouldn't start. The interior light, power locks, brake lights Ann hazard lights all work. No dash lights or radio come on. I had two friends with two different cars try to jump the front and back battery and still nothing. Somebody PLEASE HELP ME!!!
    52,662
    blown fuse?
    do you have sks? when you touch the door handle, does it unlock?
    what happens when you push the power button? maybe the fob died altogether.
    how many miles on her? i'm surprised you're not getting any warning lights. may have to check for trouble codes. could be hybrid battery.
  3. Megan Sostre
    Cleveland OHIO
    My dad checked and said all the fuses looked good
    My fob broke awhile back so now I stick the fob in the slot to start the car
    When I stick the fob in, the car beeps like the key is in, but when I hit the brake and then the power button, the car sounds like its going to start but it doesnt
    Had my dad bring over his diagnostic test machine to see if he could get a code and because no power it wont even giv a code, and not sure exactly how many miles but I know shes got alot :(
  4. xliderider
    xliderider Senior Member
    8,140
    3,277
    Honolulu, HI
    Have someone check the rear brake lights when you step on the brake pedal, do they illuminate? Could be a bad brake switch sensor. The car won't start if the ECU doesn't sense that the brake pedal is being pressed down.
  5. Megan Sostre
    Cleveland OHIO
    When I press the brakes, they do come on
  6. bisco
    52,662
    perhaps your dads scanner does not work like toyota tech stream.
  7. JC91006
    16,905
    8,631
  8. Megan Sostre
    Cleveland OHIO
    Replaced the 12v battery and car still wont start!
  9. JC91006
    16,905
    8,631
    omg, did you follow some of the steps on the link in post 7?
  10. bisco
    52,662
    are you anywhere in the vicinity of steve at autobeyours? scottsburg, indiana.
