2006 Prius Power Window help
Discussion in 'Prime Care, Maintenance and Troubleshooting' started by b.oss, Jan 11, 2022.
  1. b.oss
    b.oss Junior Member
    Louisville
    I have my drivers side window stuck in the closed position.
    Pressing down on the switch has no effect.
    Pressing up on the switch makes the window go up a tad and I hear an “oomph” like the window just closed.
    The other 3 windows open and close using their dedicated switch or the master switch on the drivers side control panel.
    The 30 A dedicated power window fuse doesn’t loose broken.
    what’s the next thing to check or replace? The drivers side switch? The motor? Something else?
    52,396
    i would start by pulling the switch panel and checking the connection, cleaning the contacts, then testing it.
    if all is okay, remove the inner door panel to see if anything looks jammed
  3. ChapmanF
    18,558
    If you hear really absolutely nothing happen when you push down, I would kind of suspect the switch. If you can hear anything at all then, I might be looking more for a mechanical jam. A more sensitive test would be to pull the window fuse and plug something like a Fuse Buddy in its place, then watch to see if there is any increased current draw when you press the switch.
    There are about 66 pages of troubleshooting info in the "windshield / windowglass" section of the repair manual (more info) about how to troubleshoot the window controls and master switch. You could use that to do a confident diagnosis where you know what the problem is before hunting for parts.
    My 2010 has developed a couple of issues at different times that responded well to simple contact cleaning.
  4. b.oss
    b.oss Junior Member
    Louisville
    Thanks for the advice. Would this fuse buddy do the trick for me?
  5. Aegean
    Aegean Active Member
    464
    208
    Alexandria VA
    It appears that the master power window switch is broken. The motor is fine since works in one direction.
  6. ChapmanF
    18,558
    There are situations where a motor that works in one direction would not fully meet my expectations of 'fine'.
  7. Aegean
    464
    208
    Alexandria VA
    If the motor works in one direction I am pretty sure it would probably work on the other when power is reversed. I would focus on the switch with these symptoms.
  8. ChapmanF
    18,558
    The switch is a likely suspect, I agree. But because the motor isn't living in isolation, but is part of a geared, jointed regulator assembly moving a glass pane in a track, there are various ways I've seen those get kind of unidirectional with age.
    If the OP comes back with a repeated statement that there is no-sound-no-nuthin'-at-all when pushing the switch down, or that a current draw test shows no blip in current at all, then that would make me even more confident in going with the switch, and that should be pretty easy for the OP.
  9. b.oss
    b.oss Junior Member
    Louisville
    Just to close the loop on this.
    replacing the master switch resolved the issue.
    thanks everyone for the advice!
  10. bisco
    52,396
    congrats!(y)
