2006 Prius suddenly developed really bad problems today, VSC, check engine, etc.
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Cgreer00, Mar 2, 2014.
  1. ericbecky
    ericbecky Hybrid Battery Hero
    4,381
    3,242
    Madison, Wisconsin
    I tend to shy away from low mileage hybrids. If nothing else I would like to see them have at least some kind of maintenance grid charging done to keep the batteries a bit healthy from the lack of use.
  2. FreydNot
    FreydNot Member
    216
    37
    Seattle, WA USA
    This can be normal behavior when the HV battery is very full. If the car is forced to charge the battery beyond it's preferred maximum (by doing down a hill or doing regenerative breaking when the battery is already at full green bars) it will use the HV battery to run the electric motors and spin the ICE. This does not propel the car nor does it use gas, but it does consume energy from the HV battery. The car will do this until the excess HV battery energy is used up and the voltage is back in spec. Often this will happen as pulses. To the driver it seems like the engine is revving up and down several times.
  3. Cgreer00
    Cgreer00 New Member
    Thanks Freyd, appreciate the knowledge. I have read a few threads where people had some REALLY strange issues that happened when the inverter pump completely failed. I am still hoping that is the problem here, but I guess I'll wait and see what the dealer says.
    Ericbecky, the car is low mileage but it was driven as a commuter car ever since it was purchased. The previous owner just used it around town and didn't do many trips, so that's why the mileage was so low when I got it from him.
  4. uart
    uart Senior Member
    4,220
    1,209
    Australia
    Then put us out of our suspense ;) and just take a quick look if the inverter coolant pumps is running or not. It takes about two minutes to do.
    I posted some pictures of how to check it here: maintenance and repair in Anchorage AK | PriusChat
  5. Cgreer00
    Cgreer00 New Member
    Dealer just called and confirmed that the battery pack has failed. They are checking into coverage right now and will call me in a bit. I will update this thread with the latest info. What is shocking is that the car was getting 50 mpg the exact same day that the battery completely failed. So, in at least some cases, there is zero warning before your battery is going to crap out.
  6. ericbecky
    4,381
    3,242
    Madison, Wisconsin
    Get the codes. It will help identify how it failed and may provide other options.
    Overheat.
    out of balance
    etc
  7. PriusGuy32
    1,417
    514
    Harrison Township, Michigan
    Damn... I was sending positive vibes your way for a lesser problem but who knows- maybe Toyota will foot the bill and you'll be out nothing with a new battery! This might still have a silver lining after all... (y)
  8. Cgreer00
    Cgreer00 New Member
    Just got a call from the dealership. First of all, he says his "technician" said that it is a 7 year/100,000 mile warranty. Everyplace else that I look online shows it being 8 years. Second of all, he said that nothing can be done. No accommodations whatsoever.
  9. ericbecky
    4,381
    3,242
    Madison, Wisconsin
    Thanks for keeping us up to date on this.
    I'm sure there are plenty of low-mileage hybrids that do just fine. My shop, and the forums just tend to hear about the ones that go bad.
  10. Cgreer00
    Cgreer00 New Member
    Can anyone confirm with me that the warranty should in fact be 8 years/100,000 miles on the 2006 Prius purchased in Georgia?
  11. PriusGuy32
    1,417
    514
    There are other options if you are no longer covered by the battery warranty, and I think somebody might have reviewed already but if not, here goes:
    Note: no labor price included
    New battery from Toyota $2300 or so
    Dorman battery: $1760
    Rebuilt battery from various rebuilders: Around $875
    Salvage yard battery from lower mile Gen2 Prius: $300- $800
  12. PriusGuy32
    1,417
    514
    Heres what I found, after doing a search on the site:
    The HV battery is warranted for 10yr/150K miles in CA and states that adopt similar emission standard.
    Read the following copied out from Toyota eBrochure for CA.
    Basic: 36 months/36,000 miles (all components other than normal wear and maintenance items).
    Hybrid-Related Component Coverage: Hybrid-related components, including the HV battery, battery control module, hybrid control module and
    inverter with converter, are covered for 8 years/100,000 miles. The HV battery may have longer coverage under emissions warranty. Refer to
    applicable Owner's Warranty Information booklet for details.
    California Emission Control Coverage: In California and any other state that adopts California emission warranty provisions, defect and performance
    warranty is 15 years/150,000 miles. The Hybrid Vehicle Battery is warranted for 10 years/150,000 miles.
    Read more: http://priuschat.com/threads/2007-prius-10-year-or-150-000-mile-hybrid-battery-warranty-whichever-comes-first.26588/#ixzz2uvITdyqK
    Follow us: @PriusChat on Twitter | PriusChat on Facebook
  13. ericbecky
    4,381
    3,242
    Madison, Wisconsin
    Should be 8 years.
    Can you see if they are willing to do a balance charge on your battery?
    It may breath some life back into it.
    Cheaper than a new battery.
    Otherwise, do you know anyone locally who has a grid charger? They could grid charge it for you and see how that works for you.
    Or else you can buy a grid charger for ~$500 and install it yourself.
    (I don't have my price sheet in front of me.)
  14. PriusGuy32
    1,417
    514
    Apparently, the warranty is 8 years. The "technician" is full of crap. I would ask to speak to somebody in the service department who is in charge, or somebody who knows what they are talking about.
  15. Cgreer00
    Cgreer00 New Member
    I insisted that they check with their regional rep and so they are doing that now. I really feel this needs to be covered at least partially by Toyota.
    PriusGuy32 likes this.
  16. PriusGuy32
    1,417
    514
    Uhhh if you are still under the 8/100 warranty, it should ALL be covered by Toyota.
    I would also call Toyota and get their reassurance that it IS covered. They can call the dealership perhaps and educate them:
    Support | Toyota.com
  17. Cgreer00
    Cgreer00 New Member
    The car was put into service on Jan 26th, 2006, so technically my warranty is over, however JUST BARELY over. I have done nothing but praise my Prius to every friend and family member I know, and I want to be able to keep praising it!
  18. PriusGuy32
    1,417
    514
    Gotchya. I didnt realize you were over the warranty period.... I was thinking you had been misled thinking you had 1 less year.
    Toyota was usually pretty good at helping with this kind of thing. However, I heard as of recent they had tightened their belts so to speak. Keep us posted!
  19. Cgreer00
    Cgreer00 New Member
    Great news! Toyota is going to cover the battery and I will pay the $500 labor charge of installing it. I am going to have them run the diagnostics again to make sure there is nothing else that could cause a premature battery failure. So very happy that Toyota stepped up and made good on this. I can continue to recommend the car to my friends/family.
    Thanks for all of your advice and tips on this as well!
    uart, Joe 26, The Critic and 3 others like this.
  20. PriusGuy32
    1,417
    514
    I heart Toyota :love: and Im so glad it worked out for you!!
    You got your birthday present early! lol
