2006 Prius tail lamps do not work
Discussion in 'Gen 2 Prius Technical Discussion' started by johnocooper, Jan 28, 2012.
  1. johnocooper
    johnocooper Junior Member
    The facts:
    1. neither tail lamp lights
    2. licence plate light works
    3. front parking lights work
    4. both tail lamp bulbs are fine (visual and continuity both check)
    5. no power at the bulb socket on either tail lamp
    6. tail lamp ground in both bulb sockets is fine
    7. fuse under dash is not blown
    8. All brake lights work fine.
    9. All other lights working.
    HELP!
  2. bogeybob513
    bogeybob513 rtc513
    147
    Myrtle Beach, SC
    Replace or continuity check the fuse again, plus make sure that the fuse you are looking at is the right one.
  3. Hal W
    Hal W New Member
    872
    53
    Grand Forks,B.C. Canada
    Also check the relays and fuses in the engine bay! Hal
  4. seilerts
    seilerts Battery Curmudgeon
    3,326
    1,520
    38
    Santa Fe, NM
    This is a conundrum. The license plate lamps get power from a branch of the taillight circuit. So the fuse+body computer is not the problem. There isn't much wire from that branch point to the driver's side taillight socket. So the problem has to be in the wiring harness behind the driver's side trim panel, the big 2' by 4' piece. That's where the ground point is as well, even though that apparently is not the problem.
  5. shaneb
    shaneb New Member
    Cairns Australia
    Hi
    Check the 12v earth that sits below the hatch latch on the rear of the body.If you remove the spare wheel cover you will see it near the wiring harness below the latch.
    I have had a few cars that have chafed the earths and created problems with the tail lights.
  6. routtcountyrob
    routtcountyrob Junior Member
    I'm having the exact same problem as johnocooper on our 07' Gen II.
    @johnocooper ........... what did you do to rectify the situation?
    I'm trying to arm myself with as much good/pertinent info as possible before I start disassembling the interior panels and coachwork.
    Thanks All!
    Rob
  7. dolj
    dolj Senior Member
    8,657
    4,406
    Wellington, New Zealand
    You might be waiting a while, johnocooper was last seen on PC on Feb 1, 2019
    Just use good wire tracing diagnostic techniques to find the (presumed) open in the circuit. Having access to the 2006 Prius Electrical Wiring Diagram might help.
    #7 dolj, Aug 7, 2024
  8. mr_guy_mann
    mr_guy_mann Senior Member
    4,120
    2,018
    NJ-USA
    Exactly which lights do or do not work when you turn on the headlight switch? Front or rear parking lights, dashboard illumination lights, license lights, glovebox light, etc.
    Do you have 12V at the 10A TAIL & 7.5A PANEL fuses when the parking lights are switched on?
