2007 MFD issue or what???
Discussion in 'Gen 2 Prius Technical Discussion' started by Birdie2019, Dec 2, 2019.
  1. Birdie2019
    Birdie2019 New Member
    San Angelo, TX
    I
    So I was driving down the road the other day in my 2007 Prius and hit a massive pothole. Right after that the mfd went offline, no mpg showing and "check connection to A/C". So I read up a bit on the forum. Also, I have a 2005 Prius that is wrecked. So I pulled my mfd out of the 2005 and installed it into my 2007 and still no luck. I checked the voltage on the 12V battery and it came back at 13.8 Volts while the car is running. I checked the fuse under the dash and changed it out. Still the same problem, and yes the mfd from the 2005 was operating correctly when removed. The only thing I have not checked is that there is suppose to be a resistor inline when a aftermarket radio is installed, maybe it got bounced around or something? I'm at a loss and I don't particularly want to take it to a dealership. I have some mechanical skills, I replaced the ABS module in my 2005. Any help is appreciated.
  2. SFO
    SFO Senior Member
    5,302
    4,252
    Northern California
    Welcome to PriusChat!!
    Which OBD2 DTCs (fault codes) are being reported?
  3. Birdie2019
    San Angelo, TX
    I
    Thank you for the response! There are no codes present on the ecm. I checked it with 2 different scanners.
  4. SFO
    SFO Senior Member
    5,302
    4,252
    Northern California
    Did either of the scanners involve using a mini-vci cable and a copy of techstream?
    Are there any lights on the dash?
    Does it run/drive?
  5. Birdie2019
    San Angelo, TX
    I
    Runs and drives just fine, no lights on at all. Aftermarket radio still functions properly, everything works fine except for the mfd. And no I don't think the scanners have techstream capabilities.
  6. SFO
    SFO Senior Member
    5,302
    4,252
    Northern California
