2007 Prius hybrid battery problem on a hot day
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by dani1166, Jan 4, 2014.
  1. dani1166
    dani1166 Junior Member
    25
    Australia
    Hi folks,
    Today I was moving house and being in Australia it was a very hot day. 40 degrees Celsius ( 104 degrees Fahrenheit) Anyway I packed up my car and headed off and all seemed normal with the battery for a while. I did have the air con on full ball and noticed very quickly the hybrid battery was draining so I turned off the a/c. It seemed to still struggle to get moving from a stop and go up hills as it was sitting on 1 pink bar (which has never happened to me before) so I continued to drive it around hoping for a charge. For a very long time I was circling the neighbourhood trying to get more then 1 pink bar. Eventually it managed to charge back up to a normal charge. I am still concerned about it. Is it normal for a battery to drain that low when it is a hot day and then take up to 15 minutes to charge one bar more up? Or is there a problem with it?
    Thanks
  2. dani1166
    25
    Australia
    I am also worried as the vents on the edge of the back seat was making a fan like sound.
  3. 3prongpaul
    3prongpaul Hybrid Shop Owner, worked on 100's of Prius's
    956
    735
    Boulder Hybids, Boulder, CO
    As hybrid batteries get older (use and time) they do deteriorate, especially in temperature extremes. The car will "deal with it" as best it can by adjusting the mix between gas/electric, running the battery fan near the back seat if battery gets hot etc. If there are no warming lights on the dash you are probably ok...for now at least.
    How many miles on your car? In the US it's rare for batteries to fail before 150k miles (241k km's)
  4. dani1166
    25
    Australia
    It's just under 90 000 km
  5. bisco
    52,878
    there's a fan that comes on inside the vent when the battery goes over a certain temp. you may want to clean the battery vent fan as some have found it clogged and not cooling the battery properly.
  6. Eclipse1701d
    Eclipse1701d Prius Enthusiast
    645
    224
    Nature coast, Florida
    Three Touring
    Have you ever cleaned your HV Battery Fan? It could be clogged. Please use instructions I provided some time ago, it may solve your problem!
    Clean HV fan when changing 12 Volt | PriusChat
    Also, have you checked your inverter pump by removing the cap from the inverter fluid holder? With the car in ready, remove the cap and check for turbulance. If not, your inverter could be over-heating and a replacement pump should be installed...
  7. 3prongpaul
    956
    735
    If car has 90k km's Hybrid system should still be under factory warranty. (what is the hybrid warranty in Oz?) Next time you go to the dealer have them "note your file" that you've noticed hybrid battery weirdness, that way if it ever fails there will be a paper trail.
  8. edthefox5
    edthefox5 Senior Member
    10,096
    4,840
    Clearwater, Florida
    You let the cabin get extremely hot while loading up. Cabin hot=Hybrid battery hot.
    I don't let my car sit for a moment without the shade in the window. They sell the custom shade here at the PC SHOP. It fits tailor perfect and is insulated. Highly recommend it.
    Then heavy load with car at full max ac with hot cabin. Then you demanded power from the car not realizing the Hybrid battery was in one pink. That power demand on a very low Hybrid battery will turn on the fan. This is all normal.
    Your car goes into one pink all the time you just never noticed. Unless you never go through a drive through? Or sit in stop & go. Then in one pink it commands the car engine to turn on. You'll immed. notice you have poor gas pedal response as the Hybrid battery is putting a load on the Inverter and the Inverter is putting a load on the mg to charge the hybrid battery.
    Not sure how hard you drive the car especially if it see's alot of hills but may be time for the full fluid tune-up. Change ICE coolant. Change the Inverter coolant. Replace trans fluid. Change motor oil.
    Check water pump belt. Check water pump for weeping. These are all due at 100,000 miles but alot of us here do these at 50,000. Have to ask yourself how important is it to me to keep the car running at peak performance and not give me any headaches?
    And check hybrid battery fan for clogging as mentioned. My 2007 hbf wasn't bad at all at 70,000 miles just a little dust on it. But I did remove the bearing dust sticker and lubed it.
  9. dani1166
    25
    Australia
    Thanks :) I'll be sure to do that next time I take it to the dealer. I guess for now I'll just keep an eye on how the battery charges and try to keep the cabin of the car as cool as possible. I guess the heat just really got to it yesterday. But It does seem to me that the battery life is getting bad. Loses charge quite easily sometimes but normally it still charges right back up.
  10. dani1166
    25
    Australia
    I'm pretty sure the battery warranty here in Australia is if the vehicle is under 8 years old it is fully covered for any issues the hv battery has.
  11. bisco
    52,878
    how long have you owned it?
  12. uart
    uart Senior Member
    4,220
    1,212
    Australia
    That's only about one more year, so please take heed of what people are telling you here and check that your rear battery fan is not clogged up.
    I bought my Prius second hand in Sept 2009, and on the very first summer I started getting exactly the same symptoms as yourself, poor battery performance and sometimes loud battery fan in the back seat. I pulled the panels in the rear hatch to inspect the fan and it was totally clogged with dust and fur. After I cleaned it out my problems went away.
    See my pictures here: Fur and dirt causing major battery problems | Page 2 | PriusChat
  13. dani1166
    25
    Australia
    The car itself is 7 years old. I have had it for about 4 years now. I took the car for a drive this morning and i noticed too that the battery life is at its worst when first driven for the day. It started off full and after only driving about 500m, it went down to 2 pink bars. it charged itself right back up quickly but i cant help but wonder if this means my battery has issues. I am not a car person and i dont know much about checking things in regards to the battery etc. I could take it to the dealer but i think they would charge me a fortune for something simple like cleaning the fan if the fan is dirty etc. It has never had these problems before and generally is a good car. I dont seem to have a problem with the battery losing charge if i have driven it around a bit earlier on in the day. it seems to be just the first drive. any ideas?
  14. bisco
    52,878
    could be your 12v.
  15. dani1166
    25
    Australia
    the 12 v battery was changed a year ago.
  16. bisco
    52,878
    still a good idea to test it.
  17. dani1166
    25
    Australia
    ok thanks ill get into it. just really want to find the cause of the problems
