2007 Replacement Key: Different keys in USA vs Canada
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Hanging on with 286k, Mar 10, 2023.
Tags:
  1. Hanging on with 286k
    Hanging on with 286k Junior Member
    26
    16
    Ontario, Canada - 300,000+ miles
    Hello. I moved to Canada from USA a while back with my 2007. Today at the dealership, they told me that the key they ordered may be different and not have a metal key inside, because it is Canadian and the car is US. Has this happened to you? If it is just a FOB, I can order that on Amazon and program myself with The Chicken Dance.... ?
    Tombukt2 likes this.
  2. Tombukt2
    Tombukt2 Senior Member
    13,847
    2,515
    Durham NC
    I would think they would be ordering a key by your VIN number which would dictate that they would be ordering a key for a SKS or non-SKS USA based automobile? One would hope anyway. I'm assuming they took your VIN number and did all that stuff. But yes you could just order a cheap case on eBay or wherever from an American market car with or without the silver logo whatever it is you need and move your stuff from your old case to the new one and everything should work that is if it's working now if your green board is out or any of that nonsense then you need to get well the green board at least to dance with in whatever case you choose. If you have SKS and the little transponder chip don't forget to move that over to whatever case you're going to be using.
    Hanging on with 286k likes this.
  3. Hanging on with 286k
    26
    16
  4. alftoy
    alftoy Senior Member
    1,132
    519
    Saskatchewan, Canada
  5. dolj
    dolj Senior Member
    8,640
    4,391
    Wellington, New Zealand
    Both SKS and non-SKS have an RFID chip. It is the only part of the electronics in fobs that is common across all trim levels.
