2008 Prius does not turn on/no ACC
Discussion in 'Gen 2 Prius Technical Discussion' started by LukemNukem, Jan 15, 2019.
  1. LukemNukem
    LukemNukem New Member
    Texas, US
    Hello everyone!
    I am having a hard time with this Prius I purchased for my sister. A little bit of back story - I purchased a 2008 Prius w/SKS that had been sitting for a good amount of time. Initially when I first purchased it, the only issue was a P0AFA DTC. RIGHT before removing the traction battery, the ignition would no longer come on or go into ACC; it was working before/randomly stopped working.
    I didn't really think anything of it and continued with the removal of the traction battery. After sitting for 2 weeks while I refurbished the pack, I reassembled the vehicle to find it still had the issue.
    (To put this into perspective, pushing the 'start' button does absolutely nothing)
    I was unable to communicate with the ECU (obviously since the ignition will not come on) however, I applied power to one of the 'IGN' fuses in the interior fuse panel near the body control module and the CEL came on. I now can communicate but have an array of codes. Most of them I assume to be irrelevant considering the vehicle is not officially powered up. I managed to retrieve a B2796(?) (Memory foggy).
    I am a Ford certified hybrid technician and only have access to ALLDATA. Based on my testing, I have diagnosed the key slot at fault, but something doesn't seem right. I am not sure how the SKS operates, and the key slot doesn't sound like a logical fix, but that's what my testing yielded.
    Are these cars known for this issue? Does the key slot control keyless starting? Any guidance whatsoever will be sincerely appreciated.
    To generalize my symptoms:
    1.) Pushing the 'START' button does nothing (component tests OK)
    2.) RKE functions work properly (I can still unlock/lock the car from the fob as well as push the button on the door handle)
    3.) 12v battery is weak but I do have a charger connected (all testing done with system at 14v)
    4.) A small red icon with a key occasionally blinks on the dashboard. Removing the key from the vehicle yields a yellow key exclamation symbol. No change disabling/enabling SKS with button.
    5.) All fuses in both boxes are ok. I have not bench tested any relays.
    6.) Inserting the fob into the slot yields no change. Slot is illuminated. Power button is backlit but not lit up (small green/orange led inoperative)
  2. Skibob
    Skibob Senior Member
    2,912
    1,505
    Northern California
    Are you supplying the power to the battery or the jump terminals? Have you checked all the fuses?
  3. JC91006
    16,915
    8,633
    You may be experiencing some problems with the combination meter, which is the odometer reading/dash lights, they will go out. It'll give you a symptom that your car is not going into ACC mode. If your center screen (Multi function display) turns on, you are in ACC mode.
    I would check/do the following first.
    1. Charge the 12v battery and make sure all connections are tight, including the ground to car body.
    2. Disconnect the 12v battery for 1 minute and reset the car, see if things change.
    3. The AM2 fuse in the engine compartment is now a more common failure when the inverter pump is shorted, that will prevent the car from starting....but you should still be able to get in ACC mode.
  4. LukemNukem
    Texas, US
    Thanks for the replies guys. I am a charging the battery off of the terminals directly, connections clean as well.
    Since I work in a shop, I really only have time to mess with the car periodically, so I've been disconnecting the battery over and over. It has the same symptoms as the AM2 fuse, but fuse is good. Infotainment screen does not come on.
  5. LukemNukem
    Texas, US
    I have ordered a key slot for the car and it should be here in the next 2 days. I had to remove the hybrid pack again to replace the temperature sensor harness due to a biased sensor. I tried to start the car again for SnG's and ACC came on and the hybrid system even started and ran for about 10 seconds before everything lost power and reverted back to its original state of non-responsive power button. Although I have a new symptom now - the interior dinger no longer dings when the fob is inserted into the slot. :rolleyes:
  6. bisco
    52,673
    how many miles on her?
  7. Skibob
    2,912
    1,505
    Northern California
    Good grief man.
  8. LukemNukem
    Texas, US
    A bit higher than I anticipated going into it but I got for a steal, 250k
  9. bisco
    52,673
    heavens to betsy
  10. Raytheeagle
    Raytheeagle Senior Member
    11,267
    15,525
    Bay Area, California
    2019 Prius Prime
    This isn’t the only 3 words thread :p.
    dolj, bisco, Skibob and 2 others like this.
  11. LukemNukem
    Texas, US
    Well key slot did not fix it. In my rushed diag, I did not realize the key slot relies on other inputs; faulty inputs, faulty outputs. I have pulled the upper dash panel and went with another diag path. I have diagnosed the power source ECU at fault, but I am wondering if there is an input to the PSC that I am missing. Per the pinpoint test, connector P6 pin 11 voltage to ground should be 12v with power switch pressed and less than 1v not pressed. I am getting 0v either way.
    Applying power to that pin makes the MFD come on.
    I did also find P6-6 ground has 600 ohm resistance, however overlaying a ground had no change.
    I found another pinpoint test that I am going to run through, but so far I have PSC Ecu suspected. I also found a thread describing the same symptoms, but was never updated with what Toyota found: I think my Prius not starting is going to be much different than the other posts here... | PriusChat
