2008 Prius No READY + Red Triangle + No Inverter Coolant Flow
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Brius10, Apr 22, 2026.
  1. Brius10
    Brius10 New Member
    Antigo,WI
    I’m having a no-start / no READY issue with my 2008 Prius and I’m trying to confirm the root cause before replacing parts.
    Here’s everything that’s happened:
    The car originally would start (go into READY), run briefly, then shut off with a red triangle and “PROBLEM” message. After that, it got worse and now it won’t go into READY at all. It powers on like normal (dash lights, etc.) and sounds like it’s about to start, but “READY” never appears.
    I replaced the 12V battery with a new one, and all connections are tight and clean. Brake lights work, so the brake switch seems fine. I also checked the main fusible link and basic fuses—they appear good.
    I pulled codes with a basic scanner and got a bunch of seemingly unrelated codes (MAF, throttle, O2, lean condition, etc.), which made me suspect a voltage or system issue rather than all those parts failing at once.
    Here’s the key observation:
    When I was able to get the car to start briefly, I checked the inverter coolant reservoir and saw NO movement at all—only slight vibration from the engine. I also put my hand on the inverter coolant pump and only felt a brief vibration at startup, then nothing. No steady humming.
    From what I understand, the inverter coolant should be visibly circulating when the car is in READY, even if the engine isn’t running. Mine is completely still.
    Now the car won’t go into READY anymore at all (just powers on but doesn’t start), and I still have the red triangle.
    Based on this, I’m suspecting a failed inverter coolant pump causing inverter overheating and a hybrid system lockout.
    Before I replace the pump, I just want to confirm:
    - Does this sound consistent with inverter coolant pump failure?
    - Would a failed pump cause the car to eventually refuse to go into READY at all?
    - Is there anything else I should check (wiring, fuse, etc.) before replacing it?
    Appreciate any help—trying not to throw parts at it blindly.
  2. JC91006
    16,939
    8,647
    All those "unrelated codes" you pulled, are problems with your car. MAF, throttle, 02, lean condition. They all need to be fixed and shouldn't be ignored or classified as "unrelated".
    There should be a code for the failed inverter pump, P0A93. But this is most likely the issue where the car will go into Ready and then the red triangle will come on when the car gets too hot. This is probably where you should start your repair journey. As all the other items will need to be replaced/repaired.
  3. Hayslayer
    Hayslayer Active Member
    539
    331
    A failed inverter coolant pump will not prevent a Gen 2 from going to READY mode. Usually the car can even be driven form long distances at up to 40ish mph and never get hot enough to throw a code. Often when the pump fails, it pops the AM2 fuse, which basically completely kills the car, but there is a possibility the ICWP can be failing and draw down that circuit voltage low enough to cause a problem, yet not blow the fuse. You can remove the pump from the circuit by unplugging the single wire plug just above the underhood fusebox. The car does not have to be "ready" to test the pump. It should run even when in ignition on state. Press the power button 2x with your foot not on the brake. This way the engine will not start and it makes it easier to feel if the pump is running or easier to recognize ripples in the reservoir.
    Brian1954 likes this.
  4. Brius10
    Brius10 New Member
    Antigo,WI
    Update on 2008 Prius issue (no READY / red triangle / sputtering)
    I wanted to give an updated status after working through multiple issues.
    Original symptoms:
    • Car would start but not always go into READY
    • Red triangle and “Problem” message on screen
    • Engine would sputter and sometimes shut off
    • Speedometer not reading after front-end work
    What I have done so far:
    • Replaced inverter coolant pump (coolant is now clearly circulating in reservoir)
    • Replaced both front wheel speed sensors
    • Installed driver-side tone ring
    • Cleaned throttle body
    • Cleaned MAF sensor
    • Fixed a loose air intake / airbox issue (it was allowing unmetered air)
    • Reset 12V battery multiple times
    • Tightened all battery connections
    Important discovery:
    • Previous owner had a jumper wire from the “P CON MAIN” fuse to a blue wire (clearly not factory)
    • I removed that wire
    Current behavior:
    • Car now runs and can go into READY (sometimes on first push, sometimes not)
    • When it does go into READY, it runs mostly smooth
    • Slight sputter mainly right after startup or when load changes (heat/fans)
    • If the “Problem” message appears at startup, the car will NOT go into READY
    • If the message does NOT appear, it will go into READY and run
    • Once running, it usually smooths out and drives
    • Fuel gauge corrected itself after running (was previously inaccurate)
    Key pattern:
    • “Problem” message = no READY
    • No message = READY and runs
    Code reader results:
    • Basic scanner shows 0 codes (I understand this may not read hybrid system codes)
    Current suspicion:
    • Intermittent hybrid system or control fault being triggered at startup
    • Possibly something the previous owner was trying to bypass with the fuse jumper
    I have a Bluetooth OBD adapter arriving tomorrow and will be using Dr. Prius to pull hybrid-specific codes.
    Any guidance on likely causes based on this pattern would be appreciated.
  5. JC91006
    16,939
    8,647
    sputtering when it's cold, then running fine afterwards, is a sign of bad fuel injectors. You can look at some live data, with the right equipment, to see which cylinders are misfiring. that will be your bad injector
    If the plugs or coils were bad on the cylinder, the car would usually not get smooth after it warms up.
  6. dolj
    dolj Senior Member
    8,652
    4,404
    Wellington, New Zealand
    The wire you removed fixes the warning message you get on the MFD, which says:
    Caution
    The transmission P lock mechanism is
    abnormal. Park your car at a flat surface place, and
    apply the parking brake completely.
    If that's the message you're now getting, then the fix for that is to reinstate the blue wire. In any case, you'll need to reinstate that blue wire.
    See this thread (among many), ➡️ P Lock C2310 Fix Fixed Solved Solution ⬅️, that talks about the fault and the fix.
  7. Hayslayer
    539
    331
    I have to apologize for laughing when I saw this just now, but it's more important than you realize, as mentioned above. All I could think was "oops" . Hope that fixes your intermittent problem.
  8. pasadena_commut
    pasadena_commut Senior Member
    3,071
    956
    Southern California
    Get a scanner that can read all the ECUs. Read the codes, post them. Posting in vague terms about codes doesn't provide enough information for other people to make well informed sugestions.
    "Speedometer not working after front end work". What kind of work might that be? Changing the struts is one type, rebuilding the front of the car after a crash is another.
