2008 toyota prius will not go ready
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by winwinownu, Mar 11, 2018.
  1. winwinownu
    winwinownu Junior Member
    new york
    This is after I fixed the blown fuse which I had thread about that Help, 2008 prius will not start, no light on dash board or anything | PriusChat
    Now I encountered a new issue, Basically I cant start the car now. it takes me 2 push to turn on some icons on the dash light. If I insert the key and push the start button, then nothing happens. Any thoughts?
  2. Sam Spade
    Sam Spade Senior Member
    2,036
    1,024
    2017 Prius c
    You should have continued that original thread.
    I for one am not going to run all over the place looking for additional information.
    The obvious wild guess is a bad 12 V battery or bad connections to same.
