2010 2nd Gen brake issue.
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Taimur khan, Mar 28, 2017.
  1. Taimur khan
    Taimur khan New Member
    Pakistan
    My prius is behaving weird from the last few days.... First abs, (!), and parking brake lights poped and today check engine and triangle of doom showed up too.... Please guide as my dealership is suggesting change of some abs motor to resolve issue which is going to cost me 1000$. IMG-20170321-WA0005.jpg IMG_20170328_220302.jpg
    52,849
    you will need a prius trouble code reader to track down the problem(s).
    how many miles on her? have you tested the 12 volt battery?
  3. Taimur khan
    Pakistan
    12 volt battery is fine and checked..... Total of 216000 km driven....
  4. andrewclaus
    andrewclaus Active Member
    993
    326
    Golden, CO
    It sounds like the brake actuator pump has failed. There is an extended warranty available in the US for that part. I hope you can get similar service where you live. Replacing that pump looks difficult, as is bleeding the hydraulic system, so it's probably best left to the dealer.
    If you can get the diagnostic codes from your dealer and post them here, we wouldn't be guessing.
    Taimur khan likes this.
  5. ChapmanF
    19,019
    I'd add that, so far, the only reason it "sounds like the brake actuator pump has failed" is because that's what the dealer's reported to have said. There's nothing else yet in this post to draw that (or any) conclusion, and yes, the trouble codes would be the first and most helpful information to add.
    -Chap
  6. wjtracy
    wjtracy Senior Member
    11,374
    3,609
    Northern VA (NoVA)
